Question about Water Heaters
Gas water heater kenmore model pilot will not stay lite
Pilot light will not stay lite
  • 2 more comments
  • mifnemail Apr 09, 2009
    Mine won't stay lit as well, I was told it is possibly the thermo-cupler/ or needs cleaning. Is it a DIY.?
  • rugovener Apr 28, 2009
    My problem is lighting the pilot light. I have a 2000 model. The light went out. I followed the steps to light and it wont remain lit. Kenmore Economizer NG 40 Gallon.
    I dont know diy?
  • Anonymous Mar 15, 2014
    pilot light wont stay on
I have the same problem. Water heater operates on a very simple principle. of thermo-mechanical feed-back and response. In my case, I have a Kenmore Power Miser 6, NG heater with an electronic pilot ignition system. The heater is just over one year old and last month (conveniently just after the 12 month service warranty expired) the pilot light started extinguishing on a very regular basis. I find it interesting that the very problem I am experiencing, is happening to other Kenmore owners (victims). The solution can be found in replacing one of two possible components; the pilot assembly or the gas valve manifold. The price of DIY pilot assembly replacement is approx. $60 . The valve component is significantly higher. Water heaters are designed and built to provide years of trouble-free reliable service. This is the first Kenmore product I have owned. From a customer perspective, with regard to product performance, Sears/Kenmore needs to take a strong look at their supplier quality. Oh, by the way, contacting Sears for remedial relief only managed to frustrate and infuriate me. You see, I am in Quality for a world-class aircraft company. I understand what ethical steps are required to satisfy a valued customer. I plan on ripping out the defective unit this weekend and replacing it with a reliable Home depot special. At least with HD, if the heater fails to perform , I can return it. Hey Sears in Chicago, don't come crying to the consumer when you are looking for the trendy "bail out". Signed- "Burned Out" in La Habra, California.
Posted on Apr 10, 2009
This problem is due to the gas control valve going out. Good luck getting help from sears, you can buy the part from them for like $90, then you will also probably have to buy the pilot assembly (around $30) or the whole burner assembly with pilot (around $66).. so in the end, you might spend up to 180 after shipping, or if you like, you can have them overnight it for about $50 extra. The best solution I came up with was to buy a new whirlpool waterheater from lowes, and buy the lowes 11 year guarantee for $90 and then dont buy another thing from Sears except the craftsman tools.
Posted on Aug 21, 2009
I too have a Sears water heater and after several years of use the pilot light would not stay lit for more than 15 - 30 minutes. My problem was that the water heater was not getting enough air, so the flame went out. Here what I did. First be sure your water heater is off. Then remove the dust cover at the base of the water heater and vacuum inside the base of the water heater. The air inlets can clog easily, and a flame has to have air. This solved my problem. My pilot has not gone out in over a year, and I didn't have to pay sears to replace parts that didn't need replacing.
Posted on Jan 21, 2011
Apartment owner and have had numerous water heaters go out just after warranty. Was advised to blow and **** out all dust from under and make sure the screen is clean. Done that, didn't work. Changed pilot assembly and gas valves, didn't work. This I am finding has been a problem for a few years now. Has anyone have any new info on why these keep going out????
Posted on Feb 23, 2010
IT CAN be a breathing problem related to clogged filters, BUT ALSO
can be FIXED by reducing the gas pressure to the unit by slightly
turning the knife switch so the gas isn't so "full blast". The pilot light
actually goes out when the unit turns off and stops heating and the
air flow then is violent. Less violent flames, less air needed, stays lit.
Yes, and clean filters too! THIS WORKS AND IS SOOOOO EASY!
Posted on May 08, 2012
  • 37 Answers
Hi, Its most likly you have a draft problem. Take a thin strip of paper and put it where the pilot light is.If it moves, thats your problem. Let me know if this is not the problem.
Thanks for using FixYa
Posted on Nov 10, 2008
  • AL Turcotte Nov 22, 2008
    Hi, can you write back, if this was a good answer.
My Kenmore Power Miser 9 pilot light kept going out. It would light right up and when I turned the gas valve to "on" the burner took right off. A short time later everything would be off again and cold water. I read about this screen getting plugged. Its in the garage and there were mega cob webs and dust under there. A few swipes with a swiffer dusting tail for ceiling fan blades and its been good for 2 weeks now.
Posted on Aug 30, 2014
Why does my pilot light on my hot water take not stay lite
It depends on many factors, including brand, type of heater, age, gas pressure, maintenance, venting, proper installation of thermocouple, bad thermocouple, air intake cleaning, if the flame is clear blue etc.
Copy following link to read more:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#pilot
Sep 20, 2012 | Water Heaters
Gas water heater
More information is needed.
What brand and model of water heater, and about how old is the heater?
Get more fresh air to the unit, and clean the air intake.
Copy following links for pilot troubleshoot, and general troubleshoot.
Aug 24, 2012 | Water Heaters
Reliance 606 Hot water Heating element (Pilot light) won't stay lit
Gas water heaters don't have elements, so I am confused about what type water heater you have..
Look on the side of tank for the label.
Find the brand, and type. Does it show BTUs? Or does it show wattage?
Then re-post question with this information, for best possible answer.
Also post question on Tank forum.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Aug 12, 2012 | Water Heaters
Rheem NatGas hot water heater model 41V50, basement flooded pilot went our how do I relight?
At the controls there should be a knob that says " Pilot"... "ON" Turn the knob to pilot and hold it down while lighting the pilot lite. Keep holding it down until it gets warm enough that when you leave it up the pilot stays on. Once the pilot lite stays on on it's own turn it to on.
Mar 14, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
I have a Kenmore water heater model number 153339461. Tried to light per instructions and pilot still is not lighting. What else should I do?
If the pilot is not lighting, you may have a lot of air in the gas line. If the pilot light is not staying lit, you may have to change the thermocouple.
Sep 07, 2010 | Water Heaters
Pilot Light problem
By controler I am guessing you mean gas valve? The next step, and I am not sure the water heater age rates this ,is to replace the gas valve.
Mar 13, 2009 | Water Heaters
Water Heaters Logo
8,748 people viewed this question
Top Water Heaters Experts
paulcarew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
