I got a new MACBOOK PRO & EPSON RX 595 printer last week. Installed the epson software and now every time I start up the laptop the Epson print monitor pops up. I have to use force Quit to get rid of it .
What's going on How do I stop the popup??
-   We have 6 epson 4880 printers installed. We print with all 6 all day long.
Now with the new Print Monitor every print job comes with a pop-up
Please help!!!-   jeroen1171
Hello I think I might have a way to solve this problem. I had a similar issue, and it was caused by having a file in the print queue that would not print.
Open Print and Fax Preference, then open the Print Queue button. Highlight any files in the queue and delete them.
Hope this works for you
Uninstall the driver. You can find it in control panel --> add or remove program --> epson print driver after uninstall turn off your printer and turn back on, windows will notify a new hardware and automatically install for the driver just insert the print driver cd.
Comments:
Mar 12, 2009
- Uninstall the epson print driver via control panel and install it back. it usually happen when the print monitor terminated abnormally
Mar 12, 2009
- Uninstall your epson print driver via control panel add or remove program and install it back. it happen because the print monitor abnormally terminated
I'm using an iMac G5 with an Epson an Epson RX595 printer. Everything worked well for a long time....
(More)
I'm using an iMac G5 with an Epson an Epson RX595 printer. Everything worked well for a long time. Now ... the printer just shoots paper through constantly without printing. I've re-installed the newest drivers from Epson.
paper printing okay, but cd printing has stopped working. message reads cd tray not loaded correctly...
(More)
paper printing okay, but cd printing has stopped working. message reads cd tray not loaded correctly although tray loaded as normal
i was using refillable ink cartridge and it was working perfect. then i bought the epson cartridge...
(More)
i was using refillable ink cartridge and it was working perfect. then i bought the epson cartridge because i wanted to print some photos and then i put back my refillable cartridges and now the printer refuses to print the the refillable cartridge. it breaks up the paper everytimes. as soon as i click on print the rollers mess up the paper and print sideways and then i get the message paper jam. I do the instructions for removing paper jam and i try again and the same thing happens. i did reset the printer to default setting. what am i doing wrong?
