Question about Maytag Microwave Ovens
I have a Maytag Model MMV5207BAB over the range microwave oven that crapped out after 11 mos use. No warning, just no power. The outlet is fine I have no power surge problems in my house. This is the second one of this model that I have had in the last 4 yrs. The 1st one took a dump after 3 yrs. Are these just junk? I called because it is under warranty and have an appointment next week. is this something common that I can fix myself? A fuse maybe? Thanks, Paul Warminster, Pa
After 4yr my maytag mmv5207bab will stop running after about 1 sec I wait then set clock time, then time to cook hit start then it starts and off 1 sec later also if I set time again light under it will shut it off just as fast
Posted on Aug 18, 2010
    Scholar:
  • 112 Answers
There is an internal fuse which is located underneath the side\top shell. If you have no lights or control panel, this is the most likely cause. This is not difficult to replace.
Posted on Nov 08, 2008
I have a Maytag Microwave Model MMV5207BAB. The door handle broke off and I would like to replace it. What parts do I need to buy?
The support page for model MMV5207BAB is here. Your exploded view with parts list is here.
The service manual is here, and it will you important safety and disassembly information.
Unfortunately, the door handle is not available separately. You would have to order the entire door assembly.
It is part number DE94-01381J and it runs $106.99 from Sears here. (prices subject to change)
William E. Miller
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Jan 15, 2017 | Maytag Microwave Ovens
Sharp Carousel Microwave Mdl 1875 for our RV is dead
>> We also tried plugging our toaster into the microwave plug outlet, and the toaster wouldn't work in that outlet, but worked just fine in a different outlet in the RV.
This means the outlet you plug your microwave into needs to be fixed in addition to fixing the oven. Breaker? Fuse?
>> I understand from another RV forum that microwave ovens for RVs have "special circuitry and cooling features" not found in regular countertop ovens for household use.
Not really in my experience. Any microwave supplied with clean AC power and proper venting space will be fine.
But I'd bet your microwave can be fixed affordably.
The main internal things which can result in this model being dead (no display, no light when you open the door, no beep when you press a pad on the keypad) would be the 20A fuse and the magnetron temperature fuse. There could also be bad connections on the noise filter board.
Also, sometimes a power surge can cause the power to be interrupted to the low voltage transformer on the board, and I regularly repair those boards. I can also write a technical statement to your insurance company or to an RV park as needed.
At my Web site, I have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
The relevant service manuals for this model are here and here.
You can order Sharp parts from Sears or Encompass.
Contact me directly if you need more help.
- William E. Miller, AS-EET
pupista@gmail.com
Microwave Oven Control Panel Repair Nationwide "Recycling by repairing since 1982"
Mar 08, 2017 | Sharp R1875: Over the Range Convection...
My Maytag over the range microwave is only 3 years old. No power. Changed the fuse - made sure the outlet worked on other appliances.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 14, 2011 | Maytag MMV5207BAW Microwave Oven
New maytag power shuts off and comes back in half hour
Depending on the model you may need a 15 or even up to a 20 amp circuit to operate the microwave. Check the installation instructions to be sure. What is most likely happening is the circuit in your home is not powerful enough to run the load of the microwave oven. If this is the case it could be dangerous. I would strongly recommend you have an expert examine the house wiring prior to starting the unit again.
Apr 20, 2010 | Maytag MMV4205 Microwave Oven
The microwave had been working fine we now have no power at all
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Feb 21, 2010 | Maytag MMV5207AAS Microwave Oven
Maytag MMV5207BBA Internal Light Access
The owner's manual covers that on page 24.
If for some reason you don't have yours, you can download it free here.
You can find links to helpful exploded view diagrams and part & accessory ordering help here.
I recommend that you bookmark that link to your favorites.
Dec 12, 2009 | Maytag 2.0 Cu. Ft. Over-the-Range...
My Maytag MMV1153BA Over The Range Micro suddenly lost power.
problem is a blow fuse inside the microwave, you need to call a appliance repair tech
Jun 28, 2009 | Maytag MMV1153A Microwave Oven
Maytag Microwave
Mine is a model UMC5200AAW. Same problem as above, no power. Is there a reste button?
Nubi541
Oct 07, 2008 | Maytag MMV5207A Microwave Oven
GE Profile Over the Range stopped dead
INTERNAL FUSE IF THERE IS NO POWER AT ALL!
Sep 02, 2008 | Whirlpool GH8155XM Microwave Oven
Microwave Ovens Logo
324 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
