Question about NEC HT410 Multimedia Projector
Random dots and no picture
My ht410 was fine and shut down as usual, on start up the next evening the unit lights showed normal initialization organge light to flashing green to solid green....light is eminating from inside the unit but all it displays is small random dots that change only when i turn it off and back on. a diff pattern of dotsimerge it resembles the stars at the start of starwars movies...it should be a solid blue display with no source and picture with source nothing is displayed except dots..no onscreen menus are accessable. any help would be greatly appreciated thks dakkota10
Okay, I had the same problem exactly.
You can't fix it yourself. I took it to the NEC lab and they changed a card. luckily it was covered by the warranty.
danielmarks@walla.com
Posted on Apr 30, 2008
How to fix 3 flashing lights?
Look for a thermistor near the lamp and ballast
Aug 22, 2015 | Samsung HLS6186W
Monitor's backlight inverter shuts down.
what is the exact model maker of the tv...? and also if you can provide the part # that would be great.!
Oct 31, 2008 | HP f2105 21" LCD Monitor
Leapfrog ipad ultra black screen white dot
During a normal shut down, the screen image on a LeapPad will reduce to a white dot, which will disappear in five to ten seconds.
In rare circumstances, the white dot will not disappear and the LeapPad will not fully power down. If the LeapPad does not complete the shutdown process and the white dot remains on the screen for more than ten seconds, complete the shut down by pressing and holding the power button on the LeapPad for ten seconds. This will fully power the LeapPad down, and it will start up normally next time you power it on. For more information contact essay writing service reviews
Essaypaperreviews com Best Writing Services Reviews online
Dec 27, 2013 | LeapFrog Toys
Acer aspire 4736g shut down unexpectedly
try using a cooler pad for your laptop for heating issue,
try changing the RAM also sometimes the faulty RAM also does this
Jan 17, 2013 | Computers & Internet
My Goodman model GMS90703BXA has a problem wherein after a cycle, the ventilator / discharge fan doesn't shut down properly. It stays on after the burner has shut off and after the main fan has shut off. ...
Hello, usually this happens when the pressure switch remains open, this could be due to a blocked flue pipe, water inside the tube between inducer motor and pressure switch, or the switch itself is going bad. Condensation can form and leak back to the pressure switch through the tubing and causing an intermittent problem with the inducer motor running continuously
Mar 01, 2011 | Goodman GMS90703BXA Heater
Laptop randomly shuts down and shows a blue screen saying
Make sure you don't have any unecessary programs loading up into windows when your laptop boots up. The next time the system randomly reboots check to see if the laptop feels a bit warmer then normal. Could be that your air vents are being blocked by dust. That would cause the air not to flow properly. Take a can of air and blow the vents clear so the air can flow properly and that would take care of the problem.
Jul 05, 2010 | Gateway CX2618 Notebook
Just shuts down, then wait about 5 min. then turn off then on and it's OK -Totally random. Does not appear to be a heat problem
These units have a protection device that will trip an internal breaker and shut off to prevent damage. This feature will function normally if: 1. the volume is too loud. 2. You have a stray wire touching either metal on the unit or the wire from an adjacent speaker. Check all of your speaker wire connections. Also, it can't hurt to make sure that the speakers are all properly phased (+ and - connections are consistent on all speakers.)
As an afterthought, I've seen this happen too if the wires are too long or if there have been multiple splices. When the amp cant push the speaker and is overworking itself, the breaker will turn off.
Apr 19, 2009 | Koss KS3102 System
LAMP not switching on NEC HT410
I had the exact same problem and solved it. After calling NEC tech and getting no help, my son and I decided to:
  • Remove, clean and reset lamp.
  • Completely clean (with compressed air) system.
And it worked. Here's what we did.
  • Removed lamp and cleaned with compressed air (in cans).
  • Used two cans of air to completely remove all internal dust. In our case long over due.
  • Reinstalled lamp and reset meter. (To reset: Turn on machine, wait 2 minutes or so, then hold down the "Help" button right next to the infrared sensor on the front of the machine).
Works fine now! Dont know if it was technical solution but solved it for us! Good Luck!
Jan 25, 2009 | NEC HT410 Multimedia Projector
NEC VT670 projector
You need to take it to the service. they'll change a card.
Dec 27, 2007 | NEC HT410 Multimedia Projector
NEC HT410 Multimedia Projector Logo
174 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
