Question about Kenmore Elite 45986 Front Load Washer
Does not rinse or completes washing
My washer continues to stop and says SUD or F02. It does not rinse and I need help in figuring out what to do.
Hey I have mine appart right now and the pump is busted, with a sheared keys on the impeller shaft. If you get it appart and can pull the impeller shaft out of the armiture you have sheared keys; this shaft should be nearly impossible to remove if the keys are still good. Mine look to have been a bit rusted. Likely cause is inferior steel succoming to bleach; which we use all the time to rid the washer of the persistant mildew.
Al the robot guy
Posted on Nov 08, 2008
Sud error code
I found that mine was having a sud error. I removed the lower front panel and removed the filter. It was full of lint and loose change. I reinstalled the filter and haven't had a problem since. On a side note I found something interesting laying inside. A service tech guide wich stated to do exactly what I had done.
Nov 27, 2012 | Maytag EPIC MFW9700S Front Load Washer
Washer won't complete cycle. F02 flashing
F02 = long drain
try this
If the drain time exceeds eight minutes, the water valves are turned off and "F02" is flashed.
Press PAUSE/CANCEL two times to clear the display.
NOTE: After four minutes the "Sud" error will be displayed, then four minutes later the "F02" error code will be displayed..
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filterfor foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Oct 23, 2012 | KitchenAid KHWV01RSS
Does not rinse
see the cause and fix it. God bless you
f the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Sep 22, 2012 | Whirlpool GHW9150 Duet Washer
How do I fix my washer that only says 'sud' constantly and won't work at all? Whenever I try to start a cycle nothing happens. Whenever I push a button nothing happens. Please Help.
http://whirlpool.custhelp.com/app/answers/detail/a_id/2948
Hi please go to this above link, it is all explained at length what is going on and what to do.
This error code indicates that excessive detergent suds occurred during the cycle.
If a "Sud" or "Sd" error code is displayed, or if you can see excessive suds in the window:
There are too many suds in the washing machine. The washer will not be able to spin out water with the excess suds. When "Sud" or "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the tumbling and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This pause and rinsing are necessary and may occur several times to eliminate the suds. See the animation below for more information.
  • If you see "Sud" or "Sd" with the Rinse status light on, the washer is in the process of removing suds. Let the cycle continue.
  • If you see "Sud" or "Sd" and the Cycle Complete light is on, the washer detected too many suds during the cycle and your load may not be fully rinsed or water may not be fully removed. You may want to select a Rinse/Spin cycle for further rinsing.
Aug 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does SUD mean?
SUD means a detection of suds in the machine. These machines are very sensitive to over sudsing. Try adding just plain water or bleach to break down the suds level. They say to use 1/4 of the detergent you would use in an older machine.
If you see "Sud" or "Sd" with the Rinse status light on, the washer is in the process of removing suds. Let the cycle finish
Jul 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F02/Sud error message fabric softner will not dispense
The pressure switch is sensing that there is still water in the unit,it sits at the top of machine under the top cover,it is round and usually red in color remove the hose/tube from it and blow through it to make sure it is clear,you can also remove the switch itself and lightly blow into it you will hear a couple of clicks put it back together and give it a shot..
Sep 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F02 code flashes and stops rinse cycle
Long Drain If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be disp NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the displaylayedPress PAUSE/CANCEL twice to clear the displayCheck the drain hose and make sure it is not plugged or kinkedCheck the electrical connections at the pump and make sure the pump is runninCheck the drain pump filter for foreign objects.g. If the above does not correct the problem, replace the pump.
Jul 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WONT RUN COMPLETE CYCLE WITHOUT F-2 OR SUD
sounds like you have a clogged/bead pump. removethe lower acess panel and from there youll see the pmp clean put remove thescrewout, and clearthe debris. BE WARNED THER WILL BE WATER BEHIND grab a towell or 2
Mar 01, 2009 | Kenmore Elite 45986 Front Load Washer
F02 Error Code & SUD message
Knowing from our washer, the SUD code is too much foam from the detergent. Since most soaps today are highly concentrated, or High Efficiency soap, try using less soap as a starter. :)
Nov 17, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Whirlpool Duet Washer-error code "sud"
Just take off the bottom kickplate (3 screws on the bottom). You'll see the pump front and center. Twist the front face of the pum slowly to the left. All the trapped water will flow right out towards you. There could be a sock or some other debris there. Unclog, screw that faceplate back in and start it up.
Sep 06, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
51 people viewed this question
Ron Lankford
Archaeology
Archaeology
reliableservice
