It is a 1969
SOURCE: I have a Moto-Mower tiller
check local small engine stores bit if not more than likely you boke the crank key under the engine they are aluminum so they brake easy if to much pressure or you broke the spider gears in the shaft
SOURCE: where can i find the parts breakdown of the recoil
Click here for the Searspart direct page for this engine.
It is item 28 and cost $25.00
Best regards
Mike
SOURCE: How can I find a parts manual/breakdown for an
http://www.mtdparts.com/webapp/wcs/stores/servlet/OperatorManualView?storeId=10101&catalogId=19502&langId=-1
Go to this website and type in horse for your model number and you should be able to find a parts break down for your tiller. If the serial number is 874639 it was made in 3/88 and will be a four speed PTO model.
I find a lot of parts on Ebay for these tillers, your can order parts through MTD but they will be a little pricey. MTD aquired Troy Bilt out of bankruptcy in 2001 and still carries parts for the tillers.
Frank
SOURCE: I am looking for Atlas
I was going to cut some brackets of of steel and drill holes where the threads are. No reason why it's threaded, as there is enough room for nuts and lock washers on the backside.
