Question about HP OfficeJet 7310 All-In-One InkJet Printer
Vertical lines when scanning using automatic document feeder...Glass is clean
I have cleaned the glass. There is no problem when I lay a document on the scanner and scan that way. There is no problem printing. The only time that I always get vertical lines is when I scan using the ADF.
Any thoughts or suggestions on a fix?
  • Johnny Massengill
    Johnny Massengill May 11, 2010
    Did you clean both of the pieces of glass on the top of the ADF/flatbet scanner? There is a small piece of glass on the left that is used only during the ADF scanning/coping.
    Problem Solver:
  • 14 Answers
It is not in the glass. More than likely it is in the rollers of the ADF feeder. If you open the cover of the ADF feeder you can see there are 3 screws (! is found under another small cover furthest to the back of the machine. Once these three screws are removed you can left the entire ADF feeder from the unit. You will then be able to clean all the rollers. Do not use alcohol as this will dry our your rollers and cause them to eventually crack. Just use soap and water to clean the rollers. Then reinstall the ADF feeder assembly back on the machine.
Posted on Nov 14, 2008
Why are pages scanning with lines running through them, but printing perfectly fine?
Try cleaning the rollers. Usually you have to remove the cartridge to get to the rollers that moves the paper.
May 02, 2014 | HP Officejet Pro 8500 Wireless All-In-One...
Vertical Black Line
Probably there is nothing wrong with that scanner, just open and clean document feder with alcohol or glass cleaner.
Mar 29, 2013 | Canon PIXMA MX870 Wireless Office...
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
When I use the feeder either for scanning or copying, the page has a black vertical line . When I make normal copies or print outs it is fine, only the feeder makes the black line. Thank you
Under the Automatic Document Feeder is a small glass.
This glass becomes dirty, creating lines on the page.
open up the scanner cover and clean the glass
Feb 17, 2011 | HP Officejet 6500 Wireless All-in-One...
When i make copies a line appears on the right side of the copy. This problem does not occur when i scan to copy only when the document runs through the feeder
Clean the document feeder scanner glass. This is the much smaller strip of glass that is to the right of the large main glass. This strip of glass is used ONLY when using the feeder. So if you are getting a dark line when using the automatic feeder but not when laying a document on the glass then just clean the strip glass. 100% sure this is your problem. You may need to clean it several times as I have seen stuff get stuck to this glass.
Good Luck and Thank You for using Fixya.
Jun 02, 2010 | Xerox WorkCentre XD120f Copier
Brother MFC-7820N Printer--vertical lines
You need to clean the scanner glass. Also known as the strip glass. It is a 1 inch wide strip of glass that runs from the front to the back. Your documents pass over this glass when they are scanned. Some of the wax crayon probably smeared off onto the glass and now when you scan the scanner sees these marks as stationary and thus records them as solid lines. Just look into the scanner section where your documents are fed in or depending on model, some are just to the left of the large original glass.
Good Luck and thank you for using Fixya.
Feb 25, 2010 | Brother MFC-7820N Printer
When the Automatic Document Feeder (ADF) to copy I
There are two scan modes when copies are made.When you make copies through ADF you originals go past small **** glass located to the left of the main exposure glass.Any small mark on this **** glass( correction fluid mark,ink mark,small scratch,dust particle and so on)will show as a line on your copy.So to get rid of these vertical lines on your copies you need to clean this small exposure glass.
Oct 04, 2009 | Epson Stylus CX9400Fax InkJet Photo...
Vertical line appears in scans using the ADF, but not with copies
happened to me after i fed a page with not-too-hard whiteout on it. the feeder makes the page run through a different piece of glass and i just had to clean it.
Aug 18, 2009 | Brother MFC 7840W Printer
Black vertical lines on faxes sent using auto document feeder
If you lift up the lid on your scanning device you will notice a glass strip about 1 inch thick and then the large area of glass used for flatbed scanning. The 1 inch strip is used for ADF scanning. Because your papper is moving across the glass strip, any dot, smudge or scratch will affect your scanning and cause verticial lines down the page. Sometimes the dot is not visible to the eye. Get some glass cleaner that has alcohol in it and thoroughly clean the glass strip and it should solve your problem. If it turns out to be a scratch on the glass then cleaning won't help.
Nov 15, 2008 | HP Photosmart 375 InkJet Printer
Line in copies that go thru feeder
Over time the automatic document feeder (ADF) will get dirty, occasionally causing vertical black streaks or lines in scans and copies .
Manual cleaning of the ADF might be necessary. Follow the procedure below to manually clean the ADF .
You will need the following materials:
  • Soft lint-free cloths
  • Glass cleaner
if you look carefully on the left side of ADF ( top feeder ) there is an assembly which u can lift , there wud be a set of rollers if u lift that part there would be a glass strip . u are suppose to clean that strip .
While holding up the inside of the ADF, clean the glass in the location of the vertical streak with one of the cotton swabs. Try cleaning the glass first with a dry cotton swab. If that does not correct the problem, then moisten the swab with glass cleaner .
If the vertical lines or streaks still appear, go through the above cleaning process again, this time cleaning the entire surface of the ADF scanner glass.
and after this try the following steps as well .
CAUTION: Use only glass cleaner. Avoid abrasives, acetone, benzene, and carbon tetrachloride, all of which can damage the scanner glass.
Apr 19, 2008 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
1,022 people viewed this question
Ben Johnson
