Question about Mitsubishi WS-55809 55" Rear Projection Television
Mitsubishi we are having aproblem with our mit tv also it comes on for a few seconds and then shuts off and you help me
    Problem Solver:
  • 31 Answers
If the pic is concave you have a convergence circut problem, check the +/- 24 volts supply, if is down repair it and replace the stk's
Posted on Dec 02, 2008
WHY DOES IT KEEP TURNING OFF
Yes. Rear-proj.with 3 picture tubes. These, like most newer tvs have self-checks that shut the tv off if the fault could worsen problems for the TV (such as damage picture tubes.) or it's not able to put a picture up.
After it shuts off, you can press menu and input/device together for 5 secs, and it will flash a 2-digit code (such as "23" or "24", etc.)(vertical or horizontal error.) Though you will need to call a repair shop for repair. It's usually better if they are Mits. factory authorized, as they'll likely have more exper. on Mits.
Apr 24, 2014 | Mitsubishi WS-65511 65" Rear Projection...
Same problem with Mits WD-52531
The first thing to try is to reclose the access door to the lamp area. There are interlocks there that may be marginally connected. Try to reclose all access doors and report the results here.
Thanks,
Dan
Jun 29, 2009 | Mitsubishi WD-52531 Television
TV turns off because of air flow
It is probably a bad temp sensor inside the TV. My 73" started shutting down before it was a year old. I moved it way out from the wall and it got a little better. A tech was just out to change the bulb under an extended warranty and he said there is a service bulletin about the temp sensor. If your TV is out of warranty you might call Mits and see if they will cover the sensor replacement. Tech said it takes about a 1/2 hour in the home to change it...
Apr 20, 2009 | Mitsubishi WD-62525 62" Rear Projection...
When turned on, my Mitsubishi TV shuts off after a few seconds.
the lamp is simple; yet you can run into problems with this tv. be very careful replacing lamp. the plug in the tv can be damaged. (due to the design)
lamp part #
915P028010
Mar 13, 2009 | Mitsubishi WD-62526 Projection TV
Mitsubishi model WT-A42
maybe theres aproblem between the power supply and in the horizontal circuit of your tv
Jul 03, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WS-65313 - Will not turn on
The most common failure are the two convergence integrated circuits part # 267P173010. The two pico fuses may be open as well, which come from the power supply and provide +24 volts and -24 volts.
Feb 15, 2008 | Mitsubishi WS-65313 65" Rear Projection...
Mitsubishi VS-55707 Shuts Down
I would not recommend working on a TV unless you have a great deal of knowledge about them.
it is probably your power relays do you have a part # i could help you look around
Jan 26, 2008 | Mitsubishi VS-55707 TV
2 PROBLEMS
Your two problems are different . Your tv shutting down is not due to the tuners . First thing i would check is to unplug set and take the back off . On the left side is the board with your tuner on it . Look on that board to see if these is any liquid buildup on it. One of your picture tubes could be leaking causing set to shut down . This can also be causing your snowy picture problem as the liquid has started to spread . The metal braket above this board is where the liquid starts to trickle down from . Use a flashlight to see . If you see no liquid then you have hv sweep problem which would need to be checked out. If you still want to get a board www.ptscorp.com May have your board in stock . Good luck
Jan 16, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
29 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
