Question about SanDisk Sansa e250 MP3 Player
DELETING PROBLEM I CAN'T DELETE FILES DIRECT FROM MY SANSA
  • kiranasif08 Nov 11, 2008
    thanks for ur help
  • 758 Answers
To delete songs from your device follow the steps below
You have to make sure that the device is on MSC mode...then make sure your device is plug in to the computer..Then go to programs - accesories - windows explorer, find the SanDisk in my computer, go to media, music and delete them from there.
Either under sync panel in your windows media player it will show your music when it's connected. just click the plus signs for what song you need to get rid of, right click and click delete.
To format it..on your device..go under..menu, setting and there should be a format option option there..let me know if that doenst work for you...
Hope this helps
Thank you
Computerrep
Posted on Nov 08, 2008
Deleting Files
Set the player USB mode to MTP then connect to PC, go to the player from My Computer then select the files to delete. After deleting files disconect player from computer to restart and reload files, Once player has reloaded it can be reconnected to computer to sync new files.
http://www.sansaworld.com/
http://www.sansaworldmp3.com/
Apr 04, 2009 | SanDisk Sansa e250 MP3 Player
IM TRYING TO DELETE MUSIC FROM MY MP3 PLAYER
Windows Media Player is the program you will be using to delete files off your Sansa. To delete files from your mp3 player using Windows Media Player 10:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/mediaadvice/0085.mspx#EDF
To delete files from your mp3 player using Windows Media Player 11:
My Directions:
1. Connect your mp3 player to the computer
2. Open Windows Media Player
3. Click on the icon of your Mp3 player on the left-hand side of the Library
4. Click on the Songs, Tracks, or other Music Folder
5. Find a song or songs that you want to delete
6. Left-click the song once to highlight it
7. Press the “Delete” button on your computer’s keyboard
if (!window.netshel_ord) { netshel_ord=Math.random()*1E16;} if (!window.netshel_tile) { netshel_tile=1; } document.write(''); netshel_tile++; window.google_render_ad();
Mar 23, 2009 | SanDisk Sansa e260 MP3 Player
SANSA CLIP MP3
There are two ways to delete files on your Sansa player.  You can delete them from the player directly or using a PC.
METHOD 1 - Delete files directly on the device
1. In playback mode, press the Submenu button.
2. Select Delete
METHOD 2 - Delete files using a PC
1. Connect your device to the PC.
2. Select Open device to view files using Windows Explorer on initial connection.
3. Locate the folder where your files are stored.
4. Click to select the files you want deleted and delete the files.
NOTE: If songs still exist after deleting, you may need to switch USB modes from MTP to MSC or vice versa. Seeanswer ID 447 for more details.
Rock....!!!
Feb 19, 2009 | SanDisk Sansa Clip MP3 Player
Deleting songs.
Your DB might be corrupt. Folow the delete procedure one more time:
Delete Music Files
1) Connect your Sansa to the computer.
2) Select Open device to view files using Windows Explorer on initial
connection.
3) Select the place where you want to delete music files from
4) Highlight and delete the music file/s or folder from My Computer\Sansa
e200\...\MUSIC
folder. (You can also select from a variety of music
software programs to transfer/synchronize your files).
If that fails, go ahead and update the firmware - it will delete everything, and allow you to start over from scratch among other things.
-Tha Mp3 Doctor
Feb 16, 2009 | SanDisk Sansa E280 MP3 Player
Deleting music on sansa e200
My solution would that you uncheck the albums from the Program that you use to sync your music or vids. Usually that means unchecking song by song or it all depends on how you have your files organized. See if that helps
Oct 02, 2008 | SanDisk Sansa e200 MP3 Player
How do i delete music off my sansa mp3 player?
Source: http://www.ehow.com/how_2023687_delete-files-sansa.html
Step 1Connect the USB cable to your Sansa MP3 player, then hook the other end to a free USB port on your computer. Step 2Give the computer time to recognize the Sansa MP3 player. Once it has, double-click on the MP3 player’s icon to view the music files stored to memory. Step 3Scroll through the list of audio files until you find the ones that you wish to delete from the Sansa MP3 player. Step 4Click on single items or click and lasso multiple files. Step 5Right-click on the highlighted files to pull down an action list and from there select Delete. The computer will ask if you really want to throw the file away. Select OK. Step 6Exit from the window, then disconnect the USB cable from the Sansa MP3 player. The player will automatically turn off. The memory will update the first time you turn the player on after deleting songs. Tips & Warnings
  • Optionally, you can left-click on a file and drag the file icon to the Recycle Bin. Either way, you can delete music that you don’t want from your Sansa MP3 player.
  • Unlike other documents and files, once the music file hits the Recycle Bin, it’s gone. Make sure that you are deleting the correct file.
For more help: http://www.supportrix.com/
Jul 30, 2008 | Audio Players & Recorders
I want to delete some files off the sansa. I thought that deleting the files off the computer would solve that problem. It didn't. I did however conect the sansa to the computer while trying to delete the...
Please give me a response on how to solve deleting from MP3 sansa m200 series.
I downloaded a cd to my sansa now how do I go about deleting from the player.
I'm on window media player 10 Thanks.
Feb 27, 2008 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Deleting songs on player e250R
Step One
Step Two
Step Three
Step Four
Step Five
Step Six
I hope that helps!!
Jan 23, 2008 | SanDisk Sansa c140 MP3 Player
Deleting music off of my sansa E250r!!HLP ME
If you originally used rhapsody (or began in Rhapsody mode) , you have to use rhapsody to remove the songs. If that doesn't work, you can manually open the music folder by enabling "hidden folders" under "tools" -> "folder options..." -> click the "view" tab -> scroll and check "show hidden files and folders". Then go to My Computer -> Sansa e250 -> "system" -> "music" -> then delete the songs. I don't know the effects of using this method, so use it at your own risk.
Btw, Real Player should do fine as well.
Dec 22, 2007 | SanDisk Sansa e250 MP3 Player
Deleting files
You can format the device thru My Computer. Right Click on the "Removable Disk" under My Computer and select Format. This will delete everything off the device. Best of Luck.
Sep 18, 2007 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
