Question about Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424
Kenmore Upright 13 cu.ft freezer- uneven freezing
This freezer is at least 15yr old but has worked like a charm until now. It seems that the temperature at various spots in the freezer vary. One area freezes well while another shelf only partially freezes items. Is there more than one fan on these units and is there supposed to be air flow at the bottom equal to the air flowing (blowing) from the top? We just wondered if it was an air circulation problem.
  • 120 Answers
No it sound like there is a problem with the seal system where the freon is kept this model does not have a fan because is the shelves get frosted so there is a leak or restriction so try calling a tech but i would just buy a new if i was you since to fix will cost about the same
Posted on Nov 10, 2008
Freezer door does not make vac sound
Might need a new seal.
A better test than sound is the put a dollar bill in sealing area and close door. Check how hard it is to pull dollar out (check tightness).
Do this all around the door in various spots.
Jul 22, 2013 | Freezers
Loud clanging noise from Kenmore upright freezer
Check the condenser fan (outside at the rear) and check the coil isn't baking hot. Electronics or board wouldn't cause your symptoms. Check the simple things first!
Jul 10, 2012 | Freezers
Frigidaire freezer has ice accumulating and not freezing properly. Ice cream will not freeze.
Try turning the temperature control to off, unplug the electrical power cord from the power outlet, defrost the appliance, clean the condenser, plug the power cord into an electrical outlet, set the temperature control to a low setting, lay a thermometer in the freezer for a few hours and see what happens to the temperature in the machine.
Check the integrity of the seal of the door gasket by seeing how the door seal will hold a slip of paper in various locations along the freezer door gasket. A loose hold on the slip of paper shows an area where hot moist air can get into the freezer and cause ice build up.
Aug 27, 2011 | Kenmore 16.7 cu. ft. / 473 liter Upright...
My Kelvinator refrigerator temperature varies a lot; thermostat problem?
check to see that the door closes tight and it is not losing cold air. If it seems to be ok I would check the thermostat
Oct 07, 2010 | Kelvinator 12 cu. ft. / 340 liter Chest...
Kenmore upright freezer only 3 years old running ,no clicking noise, no ice build up but won't completely freeze although set to 7 (lowest temp)
check door seals, also check vent direction, a dial or lever in fridge, it adjust how much air goes to fridge and freezer
May 07, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
My freezer seems to be running all the time.
This is normally due to faulty thermostat,if it has a temperature knob to raise or decrease temp try turning down until stop then apply a bit more pressure and you should switch it off .If not try turning other direction ,the tight spot at the end should switch it off .
If not replace thermostat
hope this helped
Mar 14, 2010 | Freezers
Hi, my kelvinnator frigde seems to not be as cold as usual, I turned down the fridge thermostat hoping that it would fix the problem, but not yet. I also noticed water droplets forming on the inside top...
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Mar 01, 2010 | Kelvinator 12 cu. ft. / 340 liter Chest...
New upright kenmore freezer temp varies +/- 10 degrees
Over what period of time did this variation occur?
The freezer should have an automatic defrost cycle. The temperature will rise while it is going through this cycle.
Oct 18, 2009 | Freezers
Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424 Logo
516 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
