Question about Behringer EUROPOWER EP2500 Amplifier
Unit behringer xenyx 1204 fx does not work - Behringer EUROPOWER EP2500 Amplifier
  • 1 more comment
  • Anonymous Mar 28, 2009
    It lights up however it does not produce a sound.
  • Scott Frye
    Scott Frye May 11, 2010
    Hi...
    Does anything light up on the mixer?
  • me _bryan May 11, 2010
    what is the problem you are having with the 2500?
I'm trying to find the circuit diagram for a xenyx 1204 mixer
Posted on Mar 23, 2009
I need driver update to connect with pre sonus artist one software
If you use the Behringer ASIO drivers (available from their web site) it will connect just fine, you should also be able to use the sound card drivers that came with the computer as they should pick up on the mixer (assuming it is a USB version) but you do not say if you have a Mac, PC or what operating system you are running so it is impossible to be precise
Mar 15, 2016 | Behringer XENyX 1204 XENyX 1204 12 Channel...
What causes my cd/tape input doesn't work anymore.
Make sure that the cable going to the left and right inputs is OK. Try another cable or test with a different recorder.
Oct 01, 2014 | Behringer XENyX 1204 XENyX 1204 12 Channel...
How do i set up my behringer xenyx 1622fx multi-fx
First read the instructions they contain some amazing information. I can not help you because I have no idea of what you want to know.
Jun 02, 2014 | Behringer Xenyx 1622fx Mixer Multi-fx...
Xenyx 2222 fx diagrams bebringer
You are unikely to find these as Behringer are very protective and anyway it is VERY unlikely you'd be able to make a cost effective fix even if you did get one.
Nov 12, 2013 | Behringer Xenyx 2222fx
Owners manual for Behringer xenyx 1204 USB
Behringer has the documentation for the Xenyx X1204 USB Mixer on the product page: http://www.behringer.com/EN/Products/X1204USB.aspx . See the drop-down menu labeled Documentation on the left side of the page; it's below the list of stores that sell the unit. The owner's manual is at the bottom of the list in that menu.
The file is a PDF so you will need Adobe Reader or a similar program to display the 3.1 MB file.
I hope this helps.
Oct 24, 2012 | Behringer XENYX X1204USB/1204 USB...
I have a Behringer xenyx 1202 fx. I get static when I turn up the main fx to main control. I've had the unit for a year working fine until now.
Sounds very much like the control knob is dirty, needs a good cleaning!
Sometimes just giving the knob a good exercising (turn it up and down quickly a few times) can help it.
Some cleaners can leave behind a residue and make it worse, so ask at an amp repair place what product is best to use.
Hope this helps!
Jul 13, 2011 | Behringer XENyX 1202 FX Bundle
Can I use a footswitch for the reverb, to allow me to switch it off when talking ON MY Behringer Xenyx 1202 FX
Sorry, the Xenyx1202FX does not have a footswitch input. I would suggest if this function is needed to use an external FX unit which has a footswitch input.
Apr 26, 2011 | Behringer Xenyx 1202 12-input 2-bus Mixer...
2442FX. When the mixer is switched on the numerical displays on the twin digital FX units flash and the FX units don't work.
The flashing means the FX hasn't been activated yet. Dial up the number you want THEN push DOWN on the knob to activate and the flashing stops and the FX takes effect.
Mar 29, 2011 | Behringer XENYX 2442FX Mixer
Behringer xenyx 2442fx : I need to know the correct voltages out of power-supply. Mixer has been seen by a previous tech and now FX area and mixer level leds are off (I've been a user of this mixer...
You should find pwer supply voltages of +/- 15 volts going to most of the op-amps.
You should find 48 volts for the phantom power source.
You should find 5 volts for the FX DSP or any other logic circuits.
You should find a +12 volt.
Here is a manual close to your unit (yours is an expansion of it):
http://elektrotanya.com/behringer_xenyx-1222fx_v1000_dpm5m_ub-spsu2_sch.zip/download.html
Feb 13, 2011 | Behringer XENYX 2442FX Mixer
Iam trying to make my behringerXENYX 1204fx mixer, / connect
I have trouble my new behringer xenyx 1204FX VU led dead , like new VU it must play , how to repair this unit VU light
Mar 13, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Behringer EUROPOWER EP2500 Amplifier Logo
765 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
