Minolta ep 1080 copier document feeder will not feed
It starts to feed and suddenly stops and shows a paper jam, but there is no jam, could this be a sensor , or maybe a circuit board, maybe dip switches..
had some sticky stuff on rollers, but I cleaned those up. no change.
  • 1,326 Answers
What kind or adf do you have? Will it only do one sided copies (AFR-1) or can it do duplexing (AFR-9) ? If you have the one sided doc. feeder the sticky stuff you cleaned off is mostly the paper feed roller are mealting away.... Is the paper stoping right where the rollers are? If so you will need to replace the rollers and the shaft, there are one piece and one part number... It is a BEAR to replace the shaft, if you have never done it before. Also, that may be a hard part to find, it is a olld feeder. One other thing to look for is the paper stopping in the same spot & is it being shifted to one side like it is being blocked, you may have staple or paper clip or a post-it note stuck there. Good Luck
Posted on Nov 09, 2008
Paper keeps jamming
Where document feeder or hot area (fusing unit) or paper draw?
Jun 23, 2014 | Minolta DiALTA Di183 Copier
Minolta DiAlta model 151f, when i try to use the automatic paper feed on the top of the machine the paper goes in about half way then stops then a message comes caution original doc jam
Try cleaning the pickup wheels that pull the paper into the feeder. There might be an electrical sensor problem also that is not sensing the right paper size. So lets start with cleaning the feeder
Jan 04, 2010 | Minolta Office Equipment & Supplies
Konica 7025 paper jam
Does this happen when he orginals go thur the document feeder? How does the copy look if the orginal is placed on the glass. Vertical feed problem mite be dirty rollers or dirty clutch,
Aug 13, 2009 | Konica Minolta Office Equipment & Supplies
Konica Minolta bizhub 250 jammed but no paper
Please check the sensors and actuators ,open & close front door to reset nisfeed.Clarification Top feed = Automatic Document Feeder?If YES,please verify misfeed paper beetween coverplaten and feedbelt(Yellow).Is necessary disassembly the ADF.Good luck.You will find a little paper.
Jul 31, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
you can disconnect the sorter.if that's all you need
Oct 16, 2008 | Minolta EP1083 CS/PRO Copier
Ep1083 copier
If the machine sees the ADF ( auto document feeder) but does not feed the paper? Does it try to feed the paper? Does it pull the paper is a little and jam? If the machine sees the ADF and it starts to feed the paper but jams --- clean the feed rollers/ tires with rubber restorer or a high alcohol base cleaner. Also a mylar could be pulled into the paper path blocking the feeding of the paper. Take a thin piece of cardboard ( like the devider in a case of pop) and slide the cardboard about 3- 6 inches into the feed just past the feed roller. Gently pull back out and try to feed paper again. If those do not work and the machine does see the ADF, you may need switch, sensor, actuator or feed motor.
Aug 27, 2008 | Minolta EP1083 CS/PRO Copier
Document Feed
first u switch off and switch on the machine, that time ur document feeder get rotating its not feeder problem. otherwise pls u check ur feeder driveres.
Jul 23, 2008 | Office Equipment & Supplies
Document feeder
Does the adf show a paper jam? If so remove it or look for some thing blocking the paper path and remove it. Also try to turn off the copier and disreconnect the doc feeder and turn it back on and see what happens.
Feb 19, 2008 | Minolta Di3510f Bizhub Copier
Document jams ep 4000
Ceck the rubber rollers on the doc feeder. They are probably real soft and mushy. If so they need to be replaced!
Dec 14, 2007 | Minolta EP4000/5000 CS/PRO Copier
303 people viewed this question
