Question about Califone International 1030AV Turntable
Califone 1450k Well I turned it on and played a record it sounded so good, but the unit was dirty so i put it in my bathtub to wash it, it did not work so well so i put it in my washer, and put some soap in, after that was over i pluged it in and now all it does is make a ******* sound.. why please help, i think i sould have used non sented soap.
    Problem Solver:
  • 7 Answers
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO!!!!!!!1
Posted on Nov 09, 2008
Califone 1435k This record player from the 70s runs great and came highly recommended but the 33 records we're trying to play are sounding much too fast. Any ideas on how to fix this?
This is an idler wheel drive turntable that uses a small rubber wheel, that when engaged pushes on the motor spindle and also on the rim on the underside of the platter. The spindle on the motor is stepped so as you shift speed the idler wheel moves up or down the spindle and that changes the speed of the platter. It could be the the shifting mechanism is dodgy You can try to loosen it by gently shifting the speed from 78 to 16 and back again. But the idler wheel rubber might be in trouble too.
Dec 29, 2016 | Califone International Audio Players &...
Poor sound quality from external line
it may be the recorder itself.. these smaller recorders arent known for excellent recording quality..what is it set for..also check the recording lens and clean with a duster spray..it may be dirty..
Jan 19, 2014 | Tascam BB-1000 Portable CD/SD Recorder
Califone 1030AV turntable plays slow
The usual cause is a dirty idler wheel. Clean the tire on the idler using alcohol or rubber cleaner. Make sure everything turns easily and check the height adjustment on the idler wheel. You may have to take the motor apart to clean and oil it (if not spinning freely).
Feb 19, 2013 | Califone International 1030AV Turntable
Broken volume control on 1430K Califone
There is a mute switch on the headphone jack, inside the unit. If you feel competent, open it up and replace the jack.
murf427
Aug 30, 2012 | Califone International Audio Players &...
Just inherited an old califone 1010av. It turns on, but when I put the record on the turntable and bring the needle down, there is no sound and the arm slides to the center of the record very quickly. I...
SOUNDS LIKE NEELDE BROKEN.TO TELL PUT FINGER UNDER NEEDLE PULL BACK FINGER GENTLEY AND YOU SHOULD FEEL A POINT ON THE END OF THE NEEDLE.IF NOT OR UNSURE SEE IF YOU CAN SEE THE END OF THE NEEDLE THERE SOULD BE A SAFIRE OR DIOMOND IN THE END OF IT THAT SITS ON THE RECORD IF NONE IS SEEN REPLACE NEEDLE.
HOPE THIS HELPS
NORMAN
Aug 23, 2011 | Califone International 1010AV Turntable
Plugged it in and turned it on. Put a record on and moved the needle over. Nothing happened.
Hi.
From your description it sounds as though the drive belt requires replacing. If you are experienced, remove the platter to get the belt out carefully.
If you are not tchnicallly minded, take it to your nearest audio/hifi repair shop. should be no more than £20.00.
Jan 14, 2011 | Califone International 1005AV Turntable
When boss dictates a letter I can barely hear any sound!
The tape might be getting old, replace it and see what happens.  If it is still acting up, It might be he is not recording properly or the recorder is bad.  Try talking directly into the mic and see if it is better.  If it is, he needs to talk louder or needs to hold it close.
Mar 04, 2009 | Dictaphone 3225 Handheld Cassette Voice...
Adjust pitch on a Califone turntable.
This one is actually fastened from underneath (inside). You need to open the player up and you will see the usual C shaped fastener on a cleat near the motor assembly. Most old direct drive record players have a C pin around the spindle that you can unfasten (pry with a twist) with a screwdriver. Irealize you figured this out yourself, but I'll take the guess work out for someone else... yeah..l you gotta take it apart!
Feb 15, 2009 | Califone International 1030AV Turntable
Califone 2385AV-02
PUT AN CLEANER DISK INSIDE(DISK WHICH CLEAN OPTICAL PATH INSIDE)-YOU CAN OBTAIN IT FROM NEAR RADIO SHACK.
PUT AN GOOD CD AND TEST.
Jan 04, 2008 | Califone International (2385AV-02 ) Single...
Califone 1450K
Ya, this is a tough one. If it was on it's side, and not handle properly, something may have come loose and caused some damage inside. If you have absolutely no power, then more than likely the power transformer fried. Not much else in these things that could have caused such an issue. At this point, you have to decide whether it's worth getting repaired, or buying a working used one. They go on ebay for about $30-50, which is much cheaper than getting it repaired. Transformers for these units run around $20-30, then you have to tack on labor, which will be in the 40 min range - that's if its the transformer. But I do understand if it has some personal value, so that is something to consider. Hope this helps some. - Justin DJPROAUDIO
Aug 02, 2007 | Califone International 1030AV Turntable
Califone International 1030AV Turntable Logo
612 people viewed this question
Top Califone International Audio Players & Recorders Experts
Michael Galve
Michael Galve
Michial Gueffroy
Ben Armstrong
Are you a Califone International Audio Player and Recorder Expert? Answer questions, earn points and help others
