Question about AEG Santo 7085 KG Side by Side Refrigerator
AEG Santo Fridge light flashing
AEG santo 3774-6KA PNC Nr 927966320 When I open door, lights on top flash on & off, about once a second, interior light flashes at same frequesncy, noise of relay going on and off at same frequency. This has been going on for some months. Fridge cools fine What do I need to do? Thanks Frank
  • 5 more comments
  • Anonymous Nov 08, 2007
    I have flashing internal light , every second with clicking noise.
    I have a 3774 - 6KA fridge.
    I have changed the bulb and reset temperatures
  • Anonymous Dec 03, 2007
    Hey, mine started doing the same stuff (audible relay-clicking, interior light flashing on/of with about 1s intervals...), but this unit (Santo 3675-6KA) does it even with the door shut. Can't reset the machine, since it clickers on/off too quick for it to do the 3sec countdown to shutdown. Pulling the power cord off the wall and waiting a tad before replacing won't solve it, so it's a hardware issue.
    This is now our third AEG breaking down within 3yr of purchase (lucky we got the extended 5yr warranty, hehe). Totally lost confidence in AEG. AND the repairs. The guy couldn't fix our freezer, and our dishwasher was doomed too expensive to repair. Both were replaced with current AEG models. Bad: noe we need to prepare for another massive breakdown in a few years time - after warranty's expired!
    Any info on what's wrong with the flashing symptom? It seems it's commont to many AEG models, so there should be a fix - just need to figure it out!
  • alandjax Dec 05, 2007
    we have an AEG santo 3688-6 upfright fridge with the same problem light flicking on & off, clicking noise, etc if you can help please do ...thanks
  • Anonymous Nov 26, 2008
    Same problem here. 5y old computer flashes light. Trying the fix.
  • Frank Michaux Jan 14, 2009
    I replaced the main circuit board and that fixed the problem
  • gilesyboy Apr 21, 2009
    Same problem with one of the Santo line of fridges. Will not stump up £120 for a new PCB - AEG already made £600+ out of me for a fridge that lasted a little over two years. Would love to try the capacitor fix. Could anybody please point me to somewhere (online or other) who sells the replacement part. An online search has come up blank. Many thanks in advance.
  • Anonymous Mar 18, 2014
    ice maker
Just want to say a massive thank you to rwsummers and kikka mikko for posting those links to the x2 capacitor solution. Cost me 68 pence in a trade electronics shop (but if you're in the UK Maplin have 1uf caps for about 3 quid and there are those stores in most major cities. The solder job took about 6 minutes and the fridge now works like new! One in the eye for AEG - gangsters. Many Thanks again
Posted on Jun 06, 2009
AEG santo 1683-TK7
I guess this is a problem with other santo models that use a similar circuit board. Change the 1 uf 250v capacitor as in the article santo
-fix.html" target=_blank rel=nofollow>http://www.elisanet.fi/mtj/santo/AEG-santo-fix.html
Also cures intermittent no compressor start, due to relay not holding. Causing rise in temperature.
Posted on Oct 07, 2008
  • rolyr Aug 12, 2011
    Thanks for the information. Having already once changed the contol board about five years ago, the flashing light syndrome returned again this spring and I was expecting another masive blll for a second replacement. The capacitor solution seemed worth trying and it has worked.
I similarly would like to thank rwsummers and kikka mikko for posting those links. Having bought the fridge S3688-6KA sometime in 2003, I had the PCB replaced for the first time in Aug 2007 at a total cost of £223.50 !! inc labour. This time I really didn't want to have to do the same, so tried the solution above. So far so good, I bought the capacitor (N74CN) , a soldering iron and some solder for £16.30 so have already saved more than £200 and it seems to be working fine now (touch wood).
Btw I am a housewife who has never soldered anything before :-) !!
Thanks again
Posted on Feb 26, 2010
  • happybunny1 Feb 26, 2010
    EDIT: I bought capacitor and soldering iron etc...from Maplin
    New Friend:
Just wanted to say that the fix works.
http://www.elisanet.fi/mtj/santo/AEG-Santo-fix.html
My fridge is slightly different from the one on the guide, but it still worked. Some people claim to have changed 2 capacitors, but I only changed 1 capacitor, like the guide shows.
The fridge stopped blinking, and the compressor works fine. I can't believe it.
The hardest part was removing the top lid of the fridge, and putting it back on. But with a little bit of patience, it's super easy.
I removed the original capacitor by slightly melting the solder holding it together. This was done by simply putting the soldering iron on top of the existing solder joints. When the solder was loose enough, I gently pulled the capacitor and it came off. Super easy.
Soldering the new capacitor was also easy. Everything works fine, despite the final soldering job being far from perfect.
Posted on Jan 22, 2017
    New Friend:
Refrigerator engine also generally reluctant to turn it on only when the lights blink.
Posted on Oct 22, 2016
    New Friend:
I can not get the top panel off. Do you have to remove the door as well to get the top panel off?
Posted on Nov 18, 2014
  • Rajiv Sharma
    Rajiv Sharma Nov 22, 2014
    Managed to change both the X2 vapacitors, one for 1 microfarad and the other for 22nFarad but the flashing symptoms persist. The fridge cools but this light flashing is annoying me. Any help?
  • 237 Answers
Did you ever get any advice for this problem? Please repost if not.
Posted on Dec 23, 2006
  • Marc Wilson
    Marc Wilson Dec 26, 2006
    What's with giving out a "poor" rating when being asked to repost so it will cue up again? Items over a month old are usually "stale" so you are asked to repost if you still need help.
  • Steven Sloan Jan 06, 2013
    Also had success by changing the capacitor - many thanks! The fridge is now working perfectly - or almost. For some reason, I no longer have any LEDs lit on the display - not even the temperature. Any ideas?
SOURCE:
Where is the model no on our aeg white double oven competence about 8 years old
Open the door, usually engraved within the door panel. Either on the sides or Top.
Most important number is called the PNC. If not found there, look for a sticker on the Oven Cabinet upper, after opening the door.
Good Luck :-) - J.Q
* If you found this solution helpful, please vote positively.
Feb 16, 2011 | AEG Ovens
Tip
How to set & cancel theft deterrent system or how to set & cancel security...
Theft deterrent system (on some models)
Theft deterrent system is designed to deter vehicle theft. The system flashes the turn signal lights and turns on the interior light or the signal lights only (depending on the model), and sounds security horn and vehicle horn when it detects abnormalities such as follows:
• Any door or hood is forcibly opened.
• The batter terminal is disconnected and then reconnected
• The system control is disconnected and then reconnected.
• Abnormal impact is detected when the impact sensor function is on.
The system flashes the turn signal lights and turns the interior light or the signal lights only (depending on the model), and sounds security horn and vehicle horn if someone attempts to damage or break into your car.
Setting the system
You can set the system with or without the impact sensor function. For details, see "Canceling the impact sensor" below.
1. Turn the ignition key to "LOCK" and remove it.
2. Have all passengers get out of the vehicle
3. Push the lock (set) switch on the wireless remote control key once. At this time, the turn signal lights flashes once and the security indicator light comes on.
The system is set after 30 seconds. At this time, the security indicator light start flashing slowly.
Once the system is set, you cannot start the engine until you cancel the system.
The system will not be set in the following cases.
• When any of the door is open; security horn sounds for 1 second, close the door and set the system again.
• When the hood is open; close the hood securely.
Canceling the Impact Sensor
The impact sensor can be cancelled to prevent false alarms from being triggered incase of the following conditions:
• When parked in the noisy area
• The vehicle body or glass is subjected to a strong impact from the (such as in highly pressurized car wash).
• When transporting by a car carrier or ferry.
To cancel the impact sensor;
1. Lock the door by pushing the lock (set) switch on the wireless remote control key once, and turn signal light flash once
2. Then push the lock (set) switch twice within 5 seconds. At this time, the turn signal flash 5 times to indicate the impact sensor function is disable.
The impact sensor is deactivated as long as the system remained armed.
Canceling the system
The system will be cancelled by the following two ways:
• Turn the ignition key from "LOCK" to "ON" position.
• Unlock any of the doors by pushing the unlock (cancel) switch
If the turn signal lights flash 3 times, the system has been alarmed. Check to see if there is any abnormality with your vehicle.
If any of the doors is not opened within 30 seconds, all doors will be automatically locked and the system will be set.
When the system is set
Activating the system; When the system detects abnormalities such as follows, it flashes the turn signal lights and turns on the interior light or the turn lights only (depending on the model) and sounds the security horn and vehicle horn of 30 seconds.
• Unlocking any door without using wireless control
• The battery terminal is disconnected and then reconnected.
• The system control assembly is disconnected and then reconnected
Reactivating the alarm;
Once set, the system automatically resets the alarm after the alarm stops.
The alarm will activate again under the same circumstances described in "Activating the system".
Stopping the Alarm
The alarm will be stopped by the following two ways;
• Turn the ignition key from the "LOCK" to "ON" position.
• Unlock any of the doors by pushing the unlock (cancel) switch.
The system can be cancelled by these ways at the same time.
If the battery becomes discharged due to the vehicle being unused, for a long time etc., when the battery is recharged or replaced, the system will activate the alarm. If this happens, immediately unlock any of the doors by pushing the unlock (cancel) switch, and the alarm will stop.
Testing the system
1. Set the system
2. Insert a wireless remote control key into the key hole on the driver's door handle, and unlock the door.
3. Open the door, and an alarm will sound.
4. Stop the alarm by pushing the unlock (cancel) switch.
5. Repeat this operation for the front passenger's door.
Good luck.
on Nov 08, 2010 | Toyota Pickup Cars & Trucks
AEG Santos S83168KD1 - The lock light of the water dispenser flashes after the water filter leaked inside the refrigerator. I have dried the refrigerator and replaced the filter but the light is still...
The indicator lamp can be switched off by holding the button for ordinary water (K) pressed in for about three seconds until the indicator lamp goes out. Click on the link below to download the AEG Santos S83168KD1 user manual
http://safemanuals.com/314159.php?k=5311c849edaf9949b74f80cd1a089035&ID=421951&q=AEG-ELECTROLUX S83168KD1
Jun 21, 2010 | AEG Refrigerators
AEG Fault code E202 On opening the door of my microwave combi oven the interior light flashes accompanied by what sounds like a relay chattering and the display flashing between the normal display and...
I would suspect a bad door switch or door switch mount, or possibly a bad electrolytic capacitor on the control circuit board.
See:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
Beyond that, I could only speculate, since I don't have experience or information on AEG products.
Jan 09, 2010 | Electrolux Microwave Ovens
Aeg santo 1688 fridge power/light flashes when door open
Check if the bulb is loose in its socket, you may be able to twist it to tighten it, turn off the power first though.
Oct 13, 2008 | AEG Refrigerators
AEG Santo 1683-TK7 Led's and interior light flashes when door is opened
as rwsummers correctly points out replace this part as from uk i bought it from maplins £3.31 part no N74CN 1UF 275V de-solder the two points on rear of pcb and re-solder new part in place and reassemble turn on power and "voila" works like new. Thanks.
Oct 06, 2008 | AEG Refrigerators
AEG Santo Fridge 3774-6KA
Check the damper between the fridge and freezer. It may be broken or frozen open. If this happens and you have a water reservoir in the fridge then it could freeze and crack - leak and then flood your house... Shut off the water supply until you get the problem fixed.
Jan 20, 2008 | AEG Santo 7085 KG Side by Side...
AEG SANTO 3790-6 KG
hi i have got a fridgefreezer and it keeps beeping and also inside my fridge is warm but my freezer is ok what could this be
Dec 11, 2007 | AEG Refrigerators
AEG Santo 3778-8 KA Temperature Problem
hi tracy, think its possibly better getting a repair guy in as this fault is not streight forward. possibly a fault in the defrost circuit, or freezer fan not functioning, or possibly a leak in the system. all theese areas need testing equiptment.
Sep 19, 2007 | AEG Santo 7085 KG Side by Side...
What does the flashing (warning?) light mean
Oct 22, 2006 | AEG Santo 3888 KG8 Bottom Freezer...
AEG Santo 7085 KG Side by Side Refrigerator Logo
5,655 people viewed this question
Top AEG Refrigerators Experts
Tony
Level 1 Expert
Robert Kulkofsky
Robert Kulkofsky
Chris Huff
Chris Huff
Are you an AEG Refrigerator Expert? Answer questions, earn points and help others
