Question about KitchenAid Microwave Ovens
The push to open door handle on the model #KCMS 122Yal-0 (1995) built-in microwave sticks and won't open without pulling on door from underneath applicance
  • KitchenAid Master
  • 9,098 Answers
It may be that the push button, cam lever or door latch (or all three) have some grease accumulated on them that's making it sticky to open.
Or the rear surface of the push button or the face of the lever may be so worn that the door latches don't get pushed up all the way anymore.
These door opening parts are all located behind the control panel and pretty easy to get to so you can observe them as you press the button. That way you can figure out which is bad.
At our site, we have a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
You should enter your model number without the dashes: KCMS122YAL0
Posted on Nov 08, 2008
Kitchenaid microwave open door switch does not work
on my microwave, the door sticks some times & I put my fingers under door on latch side & push up, & I can hear it release & open. other than that there may be a broken part. follow the link below.
KitchenAid Microwave Door Won Open
Jan 23, 2015 | KitchenAid Microwave Ovens
What are the Reasons why One touchy door open button is sticking on FGM0205KBB microwaves
Good afternoon friend, thank you for the post!
I understand that you are stating the door open button is continuing to get stuck on your Frigidaire microwave. I would like to ask some additional questions to make sure I can provide additional assistance. First, which button are you referring to that is sticking? When I pulled up your model FGM0205KBB, I do not see a door open button. Could we verify the model number is correct? Once I have that information I look forward to assisting you. -Matt
Aug 08, 2014 | Frigidaire FGM0205KB Gallery 2.0 cu. ft....
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Replace handle on Ewave microwave
you'll have to remove the molding and the handle clips in to place and also has to screws that hold it in place, after that reassemble the door outside trim.
Jan 19, 2010 | Microwave Ovens
Trim kit for a kcms 1555 s
You should be able to find the right kit by calling 1-877-477-7278 with your full model number.
Your complete model number will be KCMS1555SBL0, KCMS1555SSS0, or KCMS1555SWH0 without the spaces.
Dec 22, 2008 | KitchenAid KCMS1555RSS Stainless Steel...
The entire door handle snapped off
I have the same problem- funny when we built we went all Maytag and got a bunch of lousy handles- the stove, micro, fridge, and freezer... I glued the pieces of the handle together and used plumber's putty to fix it. It's MightyPutty, but without the repackaging and cost. Just knead the putty until mixed, fill the cavity of the handle and press on the door where it was... No problem after six months so far.
Nov 30, 2008 | Maytag MMV5207A Microwave Oven
Microwave shuts off by itself
The microwave has a safety door switches (2-3 micro switches)
The door mechanism should hit these micro switches. If you can open the machine, you can see that these micro switch has a holder that you can adjust and tighten to make sure that the hook of the door should activate them.
Mar 30, 2017 | Whirlpool GH8155XJ Microwave Oven
I have a GE Profile Microwave and the handle is broken....
I have the same issue. The Handle broke off my GE Microwave Oven (Model JVM1190SY 001). GE does not sell the handle seperately from what I can tell. I just ordered a new door. It's rediculously expensive. I tried to replace the handle with a nice drawer pull but couldn't find a size pull to match and I broke the plastic cover trying to get access to the screws for the handle, which is why I decided to buy the new door. Hopefully installation is not that difficult. This oven was manufactured in 2001, seems the handles have a 7 year life span.
May 28, 2008 | GE JVM1190SY/WY/AY/BY Microwave Oven
Microwave Ovens Logo
139 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
