Question about Samsung SGH-D900 Cellular Phone
No ring on incoming call
The speaker icon has a cross on it. I have tried the setup function, then Sound then Incoming calls menu
It shows vibrate and melody
standard tone
level 5
I though with this the phone will vibrate and ring, but it does not.
I seem to remember that it was one touch solution to mute or unmute the incoming call bell but I can not remember how now.
Can anyone please help
I had the same problem and went searching on line till i found the answer, press the # button it takes the mute off or puts it on.
regards patty
Posted on Mar 04, 2009
My iphone 4 only vibrates, and does not ring on incoming calls.
The iPhone, along with many other phones, has two speakers. The first is the on ear speaker and the second is the speaker at the bottom for playing music and ringtones. The speaker at the bottom could be broken so to check this, just try and use your headphones to play music. If that doesn't work either then it must be a setting on the phone so in that case just have a bit of a play with the sound settings.
Apr 16, 2014 | Apple iPhone Smartphone
How do I adjust the volume,too LOUD?
Hello jinniq51,
i have some tips on how to do it hope it helps :D
Settings
In this menu, you can adjust various phone
settings. To reset some menu settings to their
default values, select Restore factory set.
Tone settings
Select Menu > Settings > Tone settings and from the available
options:
Ringing tone-To set the tone for incoming calls
Ringing volume-To set the volume level for the ringing and
message alert tones. If you set Ringing volume to be level 2 or
above, your phone rings with the ringing volume ascending
from level 1 to the level you have set when there is an
incoming call.
Vibrating alert-To set the phone to vibrate when you receive a
call or a text message
Message alert tone-To set the tone to sound when you receive
a text message
Warning tones-To set the phone to sound tones, for example,
when the battery is running out of power
Apr 15, 2011 | Nokia 1600 Cellular Phone
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
Ringtone.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
Volume
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
Jan 25, 2011 | Samsung T239 Cell Phone
The phone vibrates when an incoming call is recieved but there is no ring tone with general selected. Even when I am using the tones menu all I get is the phone vibrating and no sound ?
The phone's speaker is either damaged or it has a loose/bad contact pad connection. Other than that, you need a qualified technician to look at it.
Follow these:
  1. Remove the covers.
  2. Remove the battery.
  3. Remove the crews on the front of the phone using T6 screwdriver.
  4. Lift the board from the housing.
  5. Hold the board from the edges.
  6. Clean the contact pads on the board using a cotton bud with alcohol.
  7. Clean the speaker terminals and lift it up to ensure it makes contact with the board when assembled.
  8. Check the continuity of the speaker using a multimeter. If it reads open, replace the speaker.
  9. Reassemble the phone in reverse order.
Note:
Nov 20, 2009 | Nokia 6700 Classic Cell Phone
On incoming calls all it does is vibrate
social.microsoft.com/.../8306e39b-6e42-4db0-a318-36fd49d59601
Jun 23, 2009 | Motorola Mobility MoroKRZR K1m Cellular...
HTC Touch doesnt ring on incoming call
Hi. First thing, you can check your sound settings, by tapping Star Menu, then Settings, then Sounds & Notifications, and through that page, you can check if your incoming call alert is on (just sound, or vibrate and sound), you can try to change the ringtone to see if your current ringtone is damaged or not. (Since other sounds are alright, there shouldn't be any problem in your hardware or in the sound volume levels) Hope this helps.
Jun 14, 2009 | HTC Touch P3452 Smartphone
The phone does not ring - ringer is off.
firstly read the operations manual for that phone look on how to adjust the settings of your phone it probably sure was indicated there, because the way i see from what you posted it has no internal circuitry prob. it just needed an adjustment.. hope this advice helps... ;-)
May 24, 2009 | Panasonic KX-TG2343 Cordless Phone
E815 motorola phone
do a mater reset of your phone
initial setup menu-master reset
code is 000000
Aug 18, 2008 | Motorola Mobility E815
Samsung SGH-D900 Cellular Phone Logo
397 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
