Question about GE Profile PDS22MHR Bottom Freezer Refrigerator
GE PROFILE BOTTOM FREEZER
I have a 5 year-old GE Profile TCX18PACBWW refrigerator that is having the same problem that it previously had. The problem is the freezer will freeze, but the frig becomes steadily warmer. Eventually, the freezer will give up, too. After following a friend's advice, I resolved this problem (I thought!) by unplugging the frig for two days. I then wound up mopping puddle after puddle of water from my kitchen floor! When it was finally dry, I plugged the frig back in and it was fine... for two weeks. Now, the milk is ever-so-slightly warm and I feel the problem is returning. I don't know whether to repeat the unplugging (and waste food again), call a tech, or buy a new frig! Any ideas?
bobotfel
  • 236 Answers
SOURCE: GE Profile CF24W-PL
Defrost the unit.
Posted on Jan 03, 2008
MNTECH
  • 1543 Answers
SOURCE: GE Profile Artica Refrigerator
OK, it sounds like you have a defrost problem. When left unplugged for a few days the frost melted off the evaporator (the cooling coils behind the freezer wall) but after you ran it again, the coils blocked the air flow again, usually happens after a week or so, depending on # of door openings, humidity in home, etc. Most likely you have a burnt out defrost heater.
Posted on Aug 28, 2008
  • 13 Answers
SOURCE: GE Profile Refrigerator (Model #20) w/freezer on the bottom
If the problem disappears (for a while) when the freezer reaches 32F, then I know what the problem is.
The GE Profile refrigerators (and likely other models as well) often don't defrost properly, especially in humid climates. So they can develop ice buildup internally, especially if the air vents at the back of the freezer are blocked by frozen food. Once that happens, that ice can interfere with the cold air circulation booster fan that runs when the freezer temperature is too warm. Then you get a LOUD buzzing noise from the fan blades, as they bang into the ice.
The immediate "solution" is to be sure nothing blocks the air vents, and then to melt the ice that interferes with the fan. You can turn the fridge off for a while (with the food removed so it doesn't spoil), and/or get a hair dryer and heat the inside back of the freezer, until the ice melts and falls away from the fan. (Just be careful not to block the nozzle of the hair dryer, or it may burn out from overheating!)
But the ultimate solution is to buy another refrigerator, one that is NOT a GE! And that makes me sad, because GE used to make GREAT refrigerators. My last GE refrigerator is nearly 20 years old, and still works well, and it does so QUIETLY.
Posted on Jan 04, 2009
  • 105 Answers
SOURCE: GE Freezer Leaking
Open the freezer door, remove the bottom tray, smash the ice on the floor with your fist to remove it. Now get a glass of hot water and pour it into the trough which is at the bottom of the back wall of the freezer. Allow a few minutes for the ice to melt then remove it with an ice pick or scrrewdriver. Once the ice is out, pour more hot water into the trough. Now take a long tube ( an old washer fill hose works perfectly) and stick one end in the hole in the trough. Now fill your mouth with warm water and blow it very hard through the tube. Once the drain is clear, pour some hot water and a very little amount of bleach through the hole.
Posted on Apr 07, 2009
Sea Breeze
  • 4655 Answers
SOURCE: GE Profile Side by Side frig leaks
Here is a lot of information on one page so take in the part that will help you stop the problem. Also you can contact me if you still have problems. Thanks Sea Breeze
appliancepartsse@yahoo.com
Click on link below
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Posted on Aug 17, 2009
Have GE profile refrigerator. It is 3 years old.
OK check the Thermistor, the actual temperature sensor element, and or thermostat if it uses a separate feed.
Sep 10, 2011 | GE Refrigerators
Bottom freezer door left slightly ajar for approx. 24 hours on a GE Profile fridge. Now, freezer and fridge are at 28 and 54 degrees respectively and will not return to normal. What are possible...
Hi do you notice any frost in the back of the freezer? If you do not this is a bad motherboard, I would recommend calling GE directly if under 5 years old they will fix at an extremely discounted price if it over 5 then the board costs about $175.00-200.00 to buy.
Sean
Mar 28, 2011 | GE Profile PDS22SBRR Stainless Steel...
Freezer temperature fluctuating way up and down. 0 recommended. 11 degrees right now. 18 earlier. Food defrosting. Ice cream soft. GE Profile bottom drawer freezer. Only 3-4 years old.
Your problem could stem from an issue with the defrost timer, the compressor or its attachments (e.g.: relay, capacitor, etc.), or the freezer/evaporator fan motor. Contact an appliance service company.
Feb 10, 2010 | GE Profile PDS20SFS Bottom Freezer...
45 degree ref and -5 freezer...unplugged.... just vac back and bottom...dust out of unit...only 2.25 years old
check the damper door between the freezer and refrige to make sure it isnt iced up and staying shut
Dec 15, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE fridge is warm and broken; the freezer is cold though.
Air circulation problem. Evaporator fan in freezer moves some air to refrig. Either fan is not working or air passages are blocked with ice. If ice found, then a defrost component failure has occurred. Fix what you find.
Sep 19, 2009 | GE Profile PDS20MFS Bottom Freezer...
PDS22SBRLSS Ge Profile bottom freezer
hi is the fan motor running in the freezer. is there frost built up on the freezer wall did you pull fridge from the wall and clean the coils by the compressor
Sep 29, 2008 | GE PDS22SBRLSS Bottom Freezer Refrigerator
Open Questions:
See all GE Profile PDS22MHR Bottom Freezer Refrigerator Questions
GE Profile PDS22MHR Bottom Freezer Refrigerator Logo
135 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
