Question about Cameras
When i connect my fujifilm s1000fd to my mac it doesn't detect it although it i listed as connected in my system profiler?
  • maggiewal72 Mar 06, 2009
    When I connect my Fuji Finpix S1000 to my Mac it doesn't detect it. I'm sure I have the USB hooked up right. Could it be I need to the camera set to a certain mode to transfer the pictures? Help, please!!!
Serge de Montréal,bonjour,hi,here is a work aroud i have the same problem when my s1000fd is connect to my mac os 10.5.7 i can see an usb icon into the caméra lcd but there is no action from the computer,or Fine Pix doesn't launch as describe in the manual.
Here is what i found go to the application folder,you will find (transfert d'images)or in english, image transfert this is the application with a little camera .Connect your camera and launch this application
you will able to transfert onto your hd and after import onto Fine Pix.
Voilà Do not thanks me thanks people at mac Thank you Mac
Bonne journée à tous :)
Posted on May 13, 2009
When I turn the camera on it shows fujifilm then the screen turns black and does not turn back on
Hi Ellen, Either the battery is not taking a charge or the camera is going to require some service.
Jan 25, 2013 | Fujifilm Finepix S1000fd 10.0 Mp Digital...
My imac firewire port in not detecting my firewire sound card
Verify support and download drivers from your sound card manufacturer's website.
Open up Mac System Profiler by clicking the Apple in the top left, then about this mac, then go in to more information. Connect the firewire sound card and see if it becomes detected but is simply unknown. This will be a sure fire way of determining problem is with lack of drivers.
Sep 26, 2012 | Apple 21.5" iMac Desktop
I have a fujifilm finepix S1000fd and it says Card Error with all my sd cards ( They work fine in my wifes Camera)
Hi Tim,
Believe it or not, it is not a good idea to transfer cards between cameras, as each brand or even model, has its own way to format the card and/or to build the system file on it. So... Have you tried formatting the card from your camera set-up menu? Note that your wife will probably have to do the same if she wants to have her card back. Another thought is to buy one card for yourself and it should work right away, although it is always a good idea to format the card prior to its firs use.
Cheers,
V+
Nov 03, 2011 | Fuji FinePix S1000FD Digital Camera
SanDisk Sansa e250 MP3 Player with Mac? Is there any driver to make it compatible with Mac platform? Thank you
NOTE: MAC computers do NOT support MTP modes of USB conectivity in a MP player. A Sansa player in MTP mode when plugged into a MAC computer will NOT be detected or recognized. MAC computers supports Sansa players in MSC mode Sansa players can only be recognized by a MAC if the USB mode on the Sansa player is set to Auto Detect or MSC.
Check in the System Profiler Open System Profiler from the Utilities folder, which is inside the Applications folder. From the Contents column on the left, under the Hardware header, select USB; the panel to the right will show all the USB devices that the computer recognizes. It may not identify them correctly by name, but it should have the right number of devices listed. . Navigate to USB Mode settings. Sansa View - From the Main Menu, select More > Settings/Options > System Settings > USB Mode.
Sansa Fuze and Sansa Clip+ - From the Main Menu, select Settings > System Settings > USB Mode.
Sansa Clip, e200v1 series, e200v2 series and e200R - From the Main Menu, select Settings > USB Mode.
2. Select Auto Detect, MTP or MSC. e200R - PlayforSure is MTP and Rhapsody is MSC
See this tip posted here on this site for a better explanation on the modes - MTP and MSC. Solve your MP3 Player Connection Problem.
Feb 05, 2010 | SanDisk Sansa e250 MP3 Player
I get a 'focus error' message from my fujifilm s1000fd camera. What can I do to fix it? I would like to fix it w/o spending money...
My email address is on my tips page on my profile under" THE ONLY WAY I KNOW HOW PART2.."
I can talk you through it but it isn't easy
Jan 24, 2010 | Fuji FinePix S1000FD Digital Camera
How do I connect my Samsung Jet to my Apple Mac running Osx 10.5.8 for using it as a modem for internet connection.
If your Mac has Bluetooth, you can connect to the phone via a bluetooth connection and use it as a modem. You first need a connection profile on the phone that will allow an IP connection (data) to your phone network, either via 3G or GPRS, though the former is potentially faster.
Then you need to Go into system preferences->Network on your Mac and create a Bluetooth connection profile that may need a user name and password to connect to your phone networks data access point.
Then select the IP profile on the phone, turn Bluetooth on. Turn on Bluetooth on the Mac and select the Bluetooth connection profile in Network on the Mac and click on the connect button, it should then connect and away you go
Oct 23, 2009 | Samsung Jet S8000 Cell Phone
Data cable
Consider getting a card reader instead.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Sep 21, 2009 | Fuji FinePix S1000FD Digital Camera
I downloaded a Sansa video converter and it keeps saying that my Sansa is not connected after i connect it. Can i have some assistance please?
do u have windows or mac system? if mac,
Although MAC OS is NOT a supported operating system, the Sansa player can still be recognized if the Sansa player is only plugged in MSC mode.
See answer ID 207 for instructions on how to put your Sansa player in MSC mode.
See answer ID 1141 for instructions on transferring music to your Sansa player using iTunes on a MAC computer.
Aug 01, 2009 | SanDisk Sansa e260 MP3 Player
My FINEPIX s1000fd fujifilm camera displays zoom error! in red and won't take pictures please help. We put new batteries in and think I have all the settings right thanks ellen Focus Error and lens will...
pls update firmware issue will be resolved most likely and pls rate me fixya for help
http://www.fujifilm.com/products/digital/download/s1000fd/fupd.html
Apr 02, 2009 | Fuji FinePix S1000FD Digital Camera
I have a question about S1000fd auto mode
Early versions of the S1000fd had the problem you are showing. There is a "firmware upgrade" the addresses the problem. Here is a link to it" http://www.fujifilm.ca/x16655.xml .I have checked the newest S1000's and they are all upgraded at the factory, before they are shipped. Yours is most likely one of the earlier versions.
Feb 10, 2009 | Fuji FinePix S1000FD Digital Camera
Cameras Logo
297 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
