Hi, I bought a usb data link cable in Maplins today and I cant get it to work. The computer says it cant install the softwear. I want to transfer my contacts and pictures from windows xp to a new laptop that has vista. I explained this to the guy in the shop and he said that the usb cable was what i needed. Can you help? Carol.
  • 152 Answers
Usb doesn't support peer to peer connection... actually our computers have host port and you can't connect two host port... how does this cable look... i mean does this have the same kind of connector both sides.,..
Posted on Nov 08, 2008
I tried downloading mp3 music on my nokia 5230 it doesnt work
you might want to check your java scripts, also try master reset see link below --> discussions.europe.nokia.com/.../Nokia-Nuron-5230-how-to-master-reset/m-p/773627
May 03, 2011 | Nokia 5230 Cell Phone
I installed the PC Suite for my LG BL40, but it won't connect via USB and my computer doesn't have a bluetooth device. |Ive tried everything suggested and when I connect choosing Music Sync, it connects bu...
First, syncing is the transfer of data between computer software's that are designed to acquire and share with another entity. The sync function usually is embedded in the computer program. Once the computer recognizes compatible software that has several capabilities including transferring data, a USB connection capacity should be achievable. Usually devices that are designed for data transferability should be capable of acquiring a USB connection either as physical cables or wireless Bluetooth technology. The power to sync is contained in the software program. Once software that has sync capabilities is installed on the computer, any USB cable that is attached to an empty port would display a user message asking for further procedures. For example, USB connections on the computer that has media software's would display device recognizes link requiring data transfer. The solution lies in the software that is relied on for sync capabilities. Acquire Windows Media player, Real One player, or ITunes player as downloadable onto the computer to achieve compatibility.
Important Notes
USB ports are available on all computers as versatile connection links to devices that would require communications. The computers original systems are expected to recognize USB cable connection as manufacturers default. Usually, the computer is likely capable of upgrading several software programs that would least communicate with the USB. For example, the program suit installed has compatibility requirements to perform on the computer as an entity. Also, the program suit requires compatibility with USB connection for another device that would be connected to the computer. Attempt to install media transfer programs that are designed with sync features.
Jan 26, 2011 | Computers & Internet
Where do I connect my camera cabel to my computer?
Some cameras have a multi-use cable which can be used for both data transfer or copy, and video output. Most cameras I have worked with usually have two cables, one for video playback and the other for data transfer or copy to a computer or other device. Most all cameras today use the convince of the standard computer USB access.
Most cameras have a cover made of either rubber or plastic which can be folded back to reveal connectors for mini-USB and video outlets. The appropriate cables must be used to connect to video or a computer or other device.
It is advisable to read your user manual for information on usage of the video and the data transfer cables and the software, if that is what you need.
I also suggest to skip all that and use a card reader, no more hassle. A card reader will give you more freedom without having to install software to see your photos or other files.
Nov 08, 2009 | Canon PowerShot A570 IS Digital Camera
Cant transfer videos to pc
Option 1:
If you want to use the USB cable to connect the Camera to the Computer to transfer the video to the Computer then:
(Applicable for Vista Operating System Only.)
This Camcorder does not support USB streaming with the VISTA Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer.
Refer this Link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
NOTE: As the Camcorder does not support USB streaming with Vista, it is not required to use any Sony Device Driver to transfer the video to the Computer. You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
Option 2:
(Applicable for Windows XP Operating System only):
If you are using a Windows XP Operating System then you have to install the USB Streaming Driver in the Computer from the supplied Software disk with the Computer.
Check this Link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
If you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video.
Option 3:
If you are using an i.LINK cable then:
The Camcorder will flash the DV IN message as soon as the i.LINK/Firewire cable is connected to the Camcorder.
If you are getting the DV IN message then it indicates that the Camcorder recognize the connection.
If you are not getting the DV IN message as soon as the i.LINK cable is connected with the Camcorder then the issue may be with either the Camcorder or with the i.LINK cable.
Try resetting the Camcorder or try with different i.LINK cable. Locate the RESET button behind the LCD screen of the Camcorder. (You will be able to locate the RESET button by opening the LCD Screen. The Camcorder should be switched ON when you reset the unit. Press the RESET button using a sharp-pointed object).
NOTE: Resetting the Camcorder will reset the settings of the Camcorder to the factory settings including date and time. It will not delete any data saved in the Camcorder.
If the issue still persists after resetting the Camcorder and with different i.LINK cable then your Camcorder requires service to resolve the issue.
Good Luck!!!!!!!!!!!!!!!
Sep 17, 2009 | Sony DCR-TRV285E Digital-8 Digital...
Cant get usb data cable to work
As long as you have a memory card installed in your phone, you should have no problem. Use a micro SD card of no larger than 4 GB. Attach the cable to your phone and computer via an available usb port. Your pc will then recognize your memory card as a mass storage device, and you cn drag and drop your files to and from the computer.Make sure your phone usb connection is set to mass storage.
Aug 06, 2009 | LG Vu CU920 Cellular Phone
CONECTION
Sad to say but every data cable needs a disc installer, I also thought that it is possible to use a datacable without an installer it but it is impossible. Yes u can use it...only to charge your phone unit but not to transfer data and files from your computer.
The only thing to use your datacable is having an installer or buying a new datacable, an installer is along with it.
But for better transfer without an installer (disc) needed.
Use a Bluetooth USB Dongle.
A rate for this solution will be much appreciated, thank you!
Jul 23, 2008 | Samsung SGH-P310 Cellular Phone
Transferring data from phone to computer
Hi are the photos on a external memory card. If so use a card reader and transfer the photos to the computer that way. I do this all of the time with mine. Good luck,
May 17, 2008 | Motorola Mobility V500 Cellular Phone
Problem with data transfer
visit samsong site and there u can get proper softwear fr ur phone try it it will work. reply me
Mar 17, 2008 | Samsung C417 Cellular Phone
Hi.. motorola v3 how to upload my pics to pc
You need to buy bluetooth for PC or USB cable for mobile-PC!!!
And you need PC SUITE for your mobile model.
And you will easily transfer data, pictures, music everything!!!
good luck! :+)
Jan 28, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
