Question about Philips DIRECTV H20 DTV Receiver
DTV H20-600 The receiver does have the ECO 2.0 sticker on it. I also cannot find the LM317 IC or a TIP42C transistor. Where are they located? Do you have a schematic? I powered up the receiver after it being unplugged a few days. I was able to watch the weather channel in HD for about 35minutes then I got the error 771 searching for signal. Seems like the problems is related to powering the LNB. Thank you for all your help.
  • rjrusek Nov 11, 2008
    Thank you for your help. I will try to locate the voltage regulator but will most likely contact DTV to get the unit replaced. I just like to fix things myself for the pure education of it.
    Thank you,
    R.
  • 2,335 Answers
I do not have an schematic for this receiver. This receiver might not use LM317 or TIP42C but a different voltage regulator, try to locate where the 20 volts line from the power supply and follow it to anywhere near the LNB tuner circuitry. This type of IC is normally mounted on a heatsink.
Lastly if you are a subscriber, give you satellite service porvider a call to get a replacement.
Posted on Nov 10, 2008
I have receiver Aiwa AV-D58U.output is good but not audio out
Most of the time find it is not the output transistors. When you replaced them did you adjust the bias etc correctly. Do you have audio driving those transistorts? if not it may be one of the ic;s
Dec 06, 2014 | Aiwa Audio Players & Recorders
Dct6200 can't find the serial number?
usually a sticker on the bottom of the box, sometimes on rear.
if it is to hard to get at or the sticker is missing try this:
1)turn everything all on as if your watching it
2)locate the d-pad, power button, and select button on the face of the box.
3)push power and right away start mashing select over and over
4)you should end up with a white screen and black text (a kinda debug screen)
5)use the d-pad to select #5 unit address and security
6)little over halfway down "host serial #" is your boxes serial number.
fyi: you can use the cable remote instead of the buttons on the box.
Aug 20, 2013 | Arris DCT6200 DTV Receiver
I have a Kicker KX-200.2 amplifier and need to know what transistors belong in the Q-15 and Q-18 locations on the main circuit board.
I have a 450.2 amp and Q15 has a tip42c transistor, and Q18 is missing from my amp (the reason I have the internals exposed..), but I'm fairly confident that it's a irfz44v mosfet chip. Hope that helps.
Oct 18, 2012 | Kicker KX1200.1 Car Audio Amplifier
My kenwood 107VR keeps turning off on its own, after about 3 secs it shuts off and the light blinks.
If you are sure your speakers are good. This unit has a protect circuit keeping the unit from turning on. This recevier uses an ic instead of output transistors. A ic incorperates transistors,resistors,capactors in one assembly for size and costs. There is a number right on the front of the ic ,you can go on-line to buy the ic is is fairly easy to put in as long as you can desolder and solder in.
Apr 17, 2010 | Kenwood VR-209 Receiver
Need codes to program my remote for a dirct tv box
http://www.directv.com/DTVAPP/global/contentPageIF.jsp?assetId=P4380052#h:1020.989
there is the website to find the codes. you have to know the model of the receiver first. this can be found in 2 places if there is a door that you can open on the front of the recever, it would be on a sticker there with the model # or it could be on the back of the receiver on a sticker there. when searching for codes look under "SATELLITE SET TOP BOX"
Apr 01, 2009 | Hughes SDHBH DirecTV DTV Receiver
My Onkyo TX-SR701 receiver is shuts off after a minute. it flashes protection then shuts off.
unsold all the power transistors,if it is power IC amplifier unsold also then turn on TX-SR701 receiver if doesn't shuts off after a minute then the problem is solve there is a defective transistors and power IC.
i hope it may help,
regards
Sep 07, 2008 | Onkyo Audio Players & Recorders
Directv h20 receiver has low volyage to the lnb.
Check inside the receiver for a defective LM317 IC or a TIP42C transistor, but before that you should check for proper voltage from the power supply to that IC.
LM317/TIP42C control the switching of voltages that power up the LNB, you should be getting 14 volts for vertical channels and 18 volts for horizontal.
Good Luck.
Mar 08, 2008 | Philips DIRECTV H20 DTV Receiver
Level But not quality
If you only get level signal on the traxis 1500, it means that you may have a defective LM317 IC or a TIP42C. This part is mounted on a heatsink.
Try checking the LNB frecuency as well and make sure you have the same settings as your Pansat.
Good Luck.
Feb 25, 2008 | Televison & Video
1996 Sony 32" Trinitron - Suddenly lost picture and sound
The most common problem with TV was the failure of the Horizontal Output Transistor, this will also damage 2 transistors in the power supply and a resistor in the power supply also. (From memory): Horizontal Output location # Q501, 2 power supply transistors Locations Q601, Q602, and resistor Location R607. Also solder the Horizontal drive transformer, you can find it by following the circuit board from the base of the Horizontal output. Some models used an IC instead of the 2 transistors in the powersupply, it will have six legs and check like 2 transistors. Good Luck.
Jun 04, 2007 | Sony KV-32S26 32" TV
Hr10-250 dtv HD receiver
First, verify the oscilador circuit of the power.It´s normal the IC is damage or the mosfet.
Second, desconect the principal board and verify if has tensions on secundary part.If positive,the problem is on principal board.
Walter.
Apr 26, 2007 | Directv HR10-250 DTV Receiver
Philips DIRECTV H20 DTV Receiver Logo
307 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
