Question about Whirlpool GHW9400 Duet Washer
F06 error code on Whirlpool duet washer
My wife posted this challenge. Here's some additional photos. My email is 22@byu.net or bryged@gmail.com or cell; 801.735.9555 Comment by bryged, posted on Nov 08, 2008 I heard a noise that sounded like a bug zapper. Now, I get the F06 error. The tub does not spin. Here's the photos. HELP!
  • 6 more comments
  • bryged Nov 09, 2008
    Is the wiring harness the white housing box to the right of the motor (in the pic)? I looked at this white housing and could not figure out how to open or access it. Is there a connection I should pay particular attention to?
  • bryged Nov 10, 2008
    I opened the access panel (pic included). I also took a pic from the front at the motor to the right of the white box (is this the motor control board?). We wiggled cables, unplugged the top 2 and plugged back in. Same symptoms. I heard clicking noises from that box. Water flows in, Motor does not spin. Timer counts down. Eventually the F06 error appears. 801.735.9555
  • bryged Nov 11, 2008
    You are awesome to be helping me through this mess. Where do I acquire the control board and is it an easy install? Also, would it be benefitial to hook up an ohm meter - if so, is this easy to do and read to determine if the motor is good or the cu blown? I have one - never used it before, but I'm willing!!!
  • gogogadget42 Dec 16, 2008
    I have an F6 error code and washer will not go into spin cycle but water will empty out of pump.I did open pump and cleaned out some loose change but still am having the same problem. HELP
  • tcarter656 Jan 14, 2009
    I have a Duet that is displaying an F06 fault code
  • hayesd Jan 15, 2009
    My washer was purchased in Oct of 2007 and it has been displaying the F06 error code for a couple of months. Not every time, but every few loads. Usually I can put the dial over to the Rinse/Spin or the Drain/Spin cycle and it will finish. This morning that did not work. Am I going to have to replace the control board? How much does this cost?
  • Anonymous Mar 07, 2009
    yup, POS
  • Anonymous Mar 09, 2009
    F6 error code ... how do i fix it?
  • 4 Answers
I have the whirlpool Duet 9150 with the same issue. I removed, reseated and reconnected every connector at least 4 times with the same random result of F06 to the point where it no longer finished the load. I then removed the motor control board again and sprayed it down with electronic cleaner along with all connections by disconnecting them , spraying them down and then reconnect and connected a few times to ensure good contact. I then tried again and the F -06 code came back. I then ordered the board for $ 150 online . When the new board arrived 4 days later, my wife tried the washer one more time and it worked. I have performed over 2 dozen loads . The board was never replaced. It appeared that spraying the board and connectors worked.
Posted on Mar 24, 2009
    President:
  • Whirlpool Master
  • 2,651 Answers
F 06 is a in issue with the motor control board, check the wiring harness attached to the board next to the motor in your second to last pic you sent.
Posted on Nov 08, 2008
  • 1 more comment
  • Ron Coons
    Ron Coons Nov 09, 2008
    yea to the right of the motor, is the right one, however youll acess the harness better form the front of the unit, try removing the 3 screws from across the front of the bottom. and drop the acess panel it will be right there
  • Ron Coons
    Ron Coons Nov 11, 2008
    NEVER in seven yrs had a bad motor( iguess it could happen) every f06 issue was remidied by repalcing that motor control board.. and yes that is it
  • Ron Coons
    you can get part from sears. com or direct from whirlpool, you will need ENTIRE model number as ther are 2 boards dependig on which model you own
I also had code F06 I unplugged and plugged all of the connectors on the motor and on the motor control unit several times insuring that i had a good connection on all connectors, I then plugged in the washer and ran a load. this simple fix seems to have solved the problem. I have since ran several loads with out a problem.
Posted on Oct 13, 2012
2 Suggested Answers
SOURCE:
bemoreonline
  • 4 Answers
SOURCE: f06 error
The Duet washer is a good machine, just unfortunate Whirlpool engineers used oxidative circuit board coatings. All the circuit board connections are oxidizing causing the machines to have faulty connections. We have fixed the problem using this information.
UNPLUG the machine first . Take the top off (3 screws in the back) , remove the mother board box from the frame housing and remove the lid. Now you can see the circuit board.
Carefully remove ONLY one (clip plug-in) at a time. Scrap with a (knife or sandpaper or steel wool ) the edge connector where that plug was, on the circuit board removing the oxidated metal (it may not look oxidated but must be cleaned), Next put ( vaseline or mineral oil) on the edge connector where that plug was, NOTE: Vaseline or mineral oil is a non-conductive oil and will not effect electronic operation but will prevent further oxidation and the erratic operation of the mother board will cease.
Now do the next plug and repeat until completed.
NOTE: We recommend only one plug at a time so you do not get confused where each plug belongs.
Put the cover back on the mother board box and reattach to the frame, then put the lid back on and screw it down. End of any F error problems.
Posted on Nov 11, 2008
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    Fh error code wirpool duet washer
    Display shows F20 or FH - Front-load washer ' Whirlpool ...
    https://www.whirlpool.com/...fh-front-load-...
    Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
    whirlpool duet error code FH - Appliance Repair Forum
    forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
    Jan 5, 2009 - 10 posts - ‎1 author
    ... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
    1 post
    Dec 5, 2014
    Whirlpool Duet Washer HF Error Code
    Jun 10, 2013
    FH Error Code on Whirlpool Duet Washer
    Mar 11, 2013
    FH error code
    Sep 13, 2008
    More results from forum.appliancepartspros.com
    Stumped on error code FH for Whirlpool Duet front load washer .
    Jan 08, 2016 | Washing Machines
    My Whirlpool Duet is showing error codes f06 and e02 and wont unlock door or run cycle, what can I do?
    Janice,
    Here is a link to a website that gives the F06 code, but I cannot find the other code.
    http://www.appliancepartspros.com/repair-help/whirlpool-fault-codes.
    Scroll down towards the bottom to find the Duet fault codes.
    Jul 28, 2015 | Whirlpool WFW94HEX Duet 5.0 cu. ft. Front...
    Error Code 01 F06
    Your fault is mentioned here.
    An F06 fault code in a Whirlpool Duet washer (the Kenmore HE3/4t's are also made by Whirlpool) usually means a motor-related problem. It usually pops up when the drum won't rotate at all or only very sluggishly. Here's the excerpt from the Whirlpool Duet Service Manual on this:
    http://fixitnow.com/wp/2008/10/28/whirlpool-duet-washer-with-an-f06-fault-code/
    May 10, 2015 | Maytag Dryers
    Whirlpool duet front load washer, F06 error
    FROM WHAT I CAN FIND OUT YOU HAVE A DRIVE MOTOR PROBLEM,
    IF YOU TYPE IN YOUR SEARCH BOX (WHIRLPOOL FAULT CODE F06) there are several several sites that tell you how to fix it
    Nov 25, 2012 | Whirlpool Duet GHW9150P Front Load Washer
    F06 error
    "F06" is a motor speed error. The following link explains how to diagnose and troubleshoot:
    http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
    I would first determine is the motor windings are good, then take voltage readings on the MCU. In general, the most common failure is the MCU. That is not to say that this is your problem. You need to follow the recommended advice provided in the link and rule out all possiblities. I hope you find this information helpful. Let me know if you require additional assistance.
    Nov 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet dryer error code E1 keeps coming on after a few minutes of running shuts down dryer.
    E1=Thermistor open
    post your email and i will send you the steps to fix and check it too much to type here
    Aug 05, 2008 | Dryers
    Service manual
    Whirlpool GHW9150P front loader washer keeps stopping mid cycle witht he F06 code. I can get through an entire cycle if there are only two or three items in the washer. My thought is it needs a new motor drive. would you agree?
    Apr 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Washing Machines Logo
    22,602 people viewed this question
    Sal De
    Marvin
    Marvin
    Gerry Harvey
    Gerry Harvey
