Question about Nu Mark Numark Cm100 4-Channel DJ Mixer System
Loss of sound in Left Channel (Nu Mark Cm 100 Mixer)
I have lost sound from my left (channel) speakers.....right channel plays. I have replaced at least three mixers but continue to have the same problem....what can I do to resolve the problem?
  • Anonymous Apr 19, 2008
    i loss my sound from the left channel tonight.
    i plug two xlrs into my mackie mixer channels.
    thank god i had a monster computer cable to plug into the tape in.
    why did i lose sound though from the left channel?
  • Rommel Cana
    Rommel Cana May 11, 2010
    on your side could it be the amp not the mixer? you just mention 3 mixer
  • 17 Answers
SOURCE: My Numark CD-MIX-2 DUAL CD PLAYER/MIXER COMBO LEFT
I would suggest this problem is caused by the Buffer PCB, filters the audio. Easy fix. Let me know if you need more info. digitalrepair@hotmail.com
Posted on Apr 22, 2010
SOURCE: Numark Mixer Headphone cue broken. Repair or replacement??
my outputs dont have signal
Posted on Jul 12, 2010
SOURCE: Channel 2 doesnt work. Channel 1 works perfectly
did u find any solution with the mixer? I have a similar problem. Channel 2 works great, Channel 1 is sending only the Left side, something like Mono instead of Stereo.
Posted on Oct 09, 2010
dunnbiker
  • 8546 Answers
SOURCE: when setting up a sound card to my m4 numark 3
"PHONO" is ONLY for an old school turntable that would require a PHONO preamp, so that leaves, uh, LINE.
It's more than a matter of gain as Phono cartridges require special equalization to restore flatness to the sound recorded in a vinyl groove.
Posted on Mar 17, 2011
djredskyy
  • 670 Answers
SOURCE: my right channel upfader on
Yes take it to your local numark dealer and they will send it out or fix it right there. sounds like the faders blown.
Posted on May 05, 2011
The output master cable is not connecting properly in the back of the mixer. the left speaker falls out. When I push the plug a bit in it makes contact again. I don't think it's a bad cable... Is this
Check your cable again. Cables for patch panels are DIFFERENT. The tip on a patch cable is smaller in diameter and has a point on it. A 1/4 inch TRS cable's tip is larger and has a rounded tip. If you're sure of your cables, then replacing the jack in the mixer isn't so bad if you're handy with a soldering iron.
Nov 02, 2014 | Nu Mark Numark Dm3050 3-Channel DJ Mixer...
Why does the left channel only play out of one speaker
Normally the left channel IS ONLY on one speaker, the right channel is on the OTHER. Give us some more info, please ?
Jun 09, 2014 | Ecler Nuo 2.0 Mixer - Mixer
Where can i get manual for radio shack SSM-8030 audio mixer?
Does your audio-mixer have "pan" control on each input channel?
Pan the channel from "100%-left" to "100%-right".
What about the main output from the mixer?
Does it feed into a stereo-mixer?
Can you adjust the gain on either the left or right channel?
May 10, 2014 | Audio Players & Recorders
How to connect it ?
Instructions
    • 1
      Place your mixer in a location that will allow you to hear the sound coming from the speakers clearly. The best placement is opposite the speakers, centered between the left and right pair. Connect the power supply to your mixer.
    • 2
      Connect the female end of an XLR cable to a microphone. Run the other end of the cable to your mixing board. Plug the male end into the "Mic" port of an open channel. These channels provide the preamps that will shape the sound characteristics of the microphone signal, processing them for output. Repeat the process for each microphone in your rig
    • 3
      Connect one end of a balanced 1/4-inch cable to the left channel jack labeled "L" found on the "Main Out" panel. Connect another cable to the right channel jack with the "R" label. Connect the opposite end of each cable to the matching left and right inputs on you amplifier.
    • 4
      Power on your mixer and amplifier. Test each microphone connected to the mixer for output.
    • 5
      Adjust the volume of each microphone channel to create a balanced mix. Use the "EQ" knobs to shape the tone and cut out frequencies that are causing squeal and feedback.
    • Audi Performance Chip
Jun 19, 2012 | Behringer Xenyx 502 Audio Live Music Mixer...
Speaker leads shorted on right rear channel of Logitech Z-5500 system
First check the speakers by connecting to front connector if thr no sound then replace the speakers.If you here sound while swap the rear amp IC might be damaged replace the IC .
Dec 19, 2011 | Logitech Z-5500 Computer Speakers
I have mixing analogique yamaha MG2FX4 ana i dont see were is LEFT and RIGHT put of this tabla mixing
I assume english is not your first language, but I think I understand you.
Right first thing is, yes it is marked. You connect the MAIN/Master outputs marked L and R to your amplifier. The tape input is marked L & R too. The stereo channels will be mark L and R but the numbered channels are mono and as we all learnt in our first mixer lesson, to make a stereo you plug left into channel one and right into channel two then pan channel 1 hard left and channel 2 hard right.
If you use a mono source such as a microphone and you want it to come out of both speakers, put the pan control in the center.
Jan 07, 2011 | Yamaha Mg2414fx 24 Channel Mixer With Fx...
No sound from front left channel
Hi, here is a procedure to discover the source of the problem. No sound from the left front channel can have several sources other than the left front channel itself.
Let's assume, for just now, that the speaker is good and the cable to it is good.
Here is a testing sequence to follow:
1 If you have a CD player connected to it. Put a CD in and put it into play mode.
2 reverse the connectors from the CD player to the receiver. See if the sound moves to the left speaker and stops on the right speaker. Or if it plays fine.
3 If the sound reverses channels, That cable is bad. Replace it
4 If the sound is still not coming from the left channel. Check the connections and cables to the speaker. MAKE SURE THERE ARE NO STRANDS OF WIRE TOUCHING THE CHASSIS OR SHORTING TO THE OTHER SPEAKER WIRE.
5 If there were. Correct it. Shut down the receiver and then after a few minutes turn it back on.
6 If it still does not work. check to see if a tiny amount of sound is coming from the left speaker.
If so, turn the music up and see if it pops back on . If that is the case there is a failed resister on the circuit board that is arcing when you turn up the volume. That being the case, it is time to drop off the receiver to be repaired in the service center.
Hope this helps,
Best,
Mark
Jan 04, 2011 | Harman Kardon AVR 330
Channel 2 doesnt work. Channel 1 works perfectly fine and i have been using the mixer for abt a yr and from one day to another channel 2 stopped working.
Feb 21, 2010 | Nu Mark Numark Dxm01 DJ Mixer With Two USB...
Numark Mixer
This sounds like someting is out of phase. Can you describe all of the connections you have to the amp and speakers. Double check them as well to be sure that the positives are connected to the same terminals on the amp and speakers. If that is OK, we'll start looking inside the mixer.
Dan
Apr 07, 2008 | Nu Mark Numark Cd-Mix-2 Dual CD...
Both left and right speakers play audio for right speaker
I think you mean the left channel is out but when you use test tone, the sound comes from left and right channels through the right channel speaker. If this is case, the switching IC is malfuncting. Unit needs service
Mar 15, 2007 | Sony STR-DE545 Receiver
Nu Mark Numark Cm100 4-Channel DJ Mixer System Logo
182 people viewed this question
Top Nu Mark Audio Players & Recorders Experts
Greg Cann
Greg Cann
robert landry
Are you a Nu Mark Audio Player and Recorder Expert? Answer questions, earn points and help others
