Troubleshooting LG mez37413724 flat screen tv It's switched on but it keeps on turning off by itself.
  • Anonymous Feb 03, 2009
    mine shuts off after being turned on also, ussually comes on and everything has a pinkish, purple hue to it then it shuts off. any body know whats wrong with this?
5 Suggested Answers
SOURCE: LG 32 in. HDTV keeps turning off.
I Have the same problem, LG 32" , LC2D a couple of work arounds that work are
1) - never unplug the mains plug
2) - i noticed it does this when the clock time is --:-- , i find that switching to digital tv can stop this,
however these are only tempory fixes and the problem re surfices, as i have found out after having no problem for 12 months, i have accidently unplugged the mains, and now the tc keep turning itself off,
Posted on Jan 28, 2008
SOURCE: LG TV
necesito la pantalla de un tv lcd de 42¨ pues se rompio donde puedo encontrar el remplazo
Posted on Apr 24, 2008
SOURCE: Philips flat screen TV MODEL ID 19PFL5422D/27
I bought the television less than a year ago, so I called Philips Magnavox and they asked for the serial and model numbers. Next thing I know they asked for my name and address and Philips is sending a brand new television to replace it !!! The new one should arrive in about ten days. How's that for service? I'm very happy that I bought Philips and I will do so again. So don't forget to keep all the paper work that comes with your new televisions,especially Model and Serial numbers ! Thanks for asking , Debbie Hoffman
Posted on Aug 19, 2008
ladywinn
  • 5138 Answers
SOURCE: when i first try to
unless you do TV repair take to repair shop.I would first look for defective capacitors on boards and like so many others poor solder connection can cause alot of problems.
Posted on Sep 17, 2008
SOURCE: olevia 26" flat screen
screen suddenly shut off. blue light in the right hand corner stays on but there is no picture
Posted on Jan 20, 2009
Volume keeps going down to zero
Emerson volume keeps going down Questions & Answers ...
www.fixya.com > Forum > Tags > volume keeps going down
Emerson volume keeps going down related problems. Ask your Emerson ... myEmerson TV. It turned itself down to zero and stayed on the screen and wouldn.
Emerson Flat Screen TV volume trouble? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Aug 10, 2011 - My Emerson 32 inch does similar things, volume just goes to 0-100 and stays there. ... Why is the volume on my Emerson flat screen TV not working and how could i fix it? Whats wrong with my Emerson Flat screen tv? Why is the volume on my Emerson flat screen TV not working ...
Jul 13, 2013
My son has an Emerson tv it keeps turning down by itself. Anyone ...
Aug 24, 2006
More results from answers.yahoo.com
Emerson TV problem ' Techlore
Dec 15, 2015 | Emerson Televison & Video
Hello My 60PK550 TV started to turn itself of every 5-10 minutes, I switched it of at the power point and waited, now when it is plugged in and turned on at the power point it immediately tries to turn...
check first the psu unplugging the Y-sus from it if the voltages stay on then you have a Y-sus failure if the psu keeps closing then its most likely the psu itself or your main board
Aug 16, 2014 | LG 60PK550 TV
My LED LG TV 42" turns on/off by itself. Channels do not change.
Sorry to tell ya but your power supply panel or chip is going out! Mine done the same stuff! Freakin flat screens dont last as long as the older t.v's
Nov 01, 2012 | LG Televison & Video
LG TV KEEPS TURNING OFF
Kindly do not keep attempting to turn it on, as you are likely to spoil some other boards/parts/components of the TV. Look for any loose contacts in power out let, RC jack, cable and socket. In order to ensure, it is not caused by the input device, connect a DVD player
and see. Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, I suggest it is better to refer it to a qualified service technician, since the back cover has to be opened for investigation/rectification.
Aug 21, 2012 | LG 50PC1DR 50 in. Plasma HDTV
I have a 3 yr old 42" LG tv that keeps turning off
Please check your capacitors for malfunction. Replace them if needed.
Regards
Feb 08, 2011 | LG 42PC1DA 42 in. Plasma HDTV
LG LCD TV model 42LH70YR switches on and off continuously
eduramagli@gmail.comHELP PLEASEEE!! I`VE THE SAME PROBLEM! MY 42LH70YR SI CONTINUOUSLY TURNING ON / OFF !!
PLEASE IF SB KNOWS HOW TO RESOLVE IT SEND ME AN E-MAIL. IM FROM URUGUAY
Oct 06, 2009 | LG Televison & Video
42 LG plasma no picture but sound. found internal fuse had gone so replaced. Then when switched on it stays on for about 5 seconds and switches itself off again. Replaced power supply and now when switched...
Sounds like it started "Protection Mode" because of a failed electronic part inside the TV. When this happens, the TV will keep turning itself OFF or will not turn ON at all. This keeps the other parts inside from being damaged. Most likely the TV has a power supply related problem. The common part to go bad for flat panel screens circuit board that powers the screen itself. Most manufactures call it a Backlight Inverter Board.
But, I can't say what is 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptom.
You have a few choices:
1. Best thing to do, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, schematics, test points, and part# lists.Usually, cost under $20. Its the best repair guide material for fixing TVs. And most cases the new part cost less than $15 by searching on the internet with the part number.
2. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Jul 20, 2009 | LG 42PG20 42 in. Plasma HDTV
When i first try to turn on my LG flat screen it turns itself of immediately. It then switches itself on and off in rapid succession in a kind of continous loop.
Sep 17, 2008 | LG Televison & Video
Oct 31, 2007 | LG 32LX3DC 32 in. LCD HDTV
Televison & Video Logo
455 people viewed this question
Top Televison & Video Experts
Electro Med Services...
