Question about Vizio L32 32 in. LCD HDTV
Wavy shadow on right side of screen
We have a dark gray wavy shadow on the right side of our vizio 32" screen. It started as an irregular vertical wave approximately 2" x 8" and has grown and darkened to cover nearly 1/3 of the right hand side of the screen. It is most visible when the picture is a bright background especially white.
  • Anonymous Jan 15, 2009
    I have exactly the same problem with my Dell Ultrasharp 24 inch monitor. Sorry I can't be of assistance. I bought it used so I don't know if the problem developed over time or was always there.
  • bowen9 Jan 15, 2009
    I have exactly the same problem. A squigly grey vertical shadow on the right side of my Dell 24" Ultrasharp. I bought it used so I'm not sure if the problem developed over time of if it was always there. Sorry I can't be of assistance. I'm looking for a solution as well.
SOURCE: Wavy red lines or red pixelation, not sure what it is
Go to Vizio website and buy the extending warranty, you need to have your TV replaced since the problem is with the screen itself.
Posted on Dec 16, 2008
SOURCE: Vertical Red Line
I had a bright red 1" wide vertical line on the right side of my Vizio P42HDE as well as an equivalent Green line on the left. Sometimes a Blue line would appear adjacent to the red line. Had this TV sinc Oct. 2005. Based on internet research, I opted to purchase an LG 6871QCH060Q board (upgrade to the 6871QCH038A and the 6871QCH038C). Picked the board up on Ebay for $100 + $10 shipping from ShopJimmy parts.
From start to finish, this took about 2 hours to repair. Tons of screws to remove. Took me a while to figure out that the video connection unit in the back is completely modular and needs to be removed before attempting to remove the back cover. Once the cover was removed, I was surprised that I could not see where the replacement board was located. Turns out, you have to go one level deeper and remove the audio board and digital board followed by metal bracket/cover. Once removing the metal cover, the bad 6871QCH038A board was visible. A couple of zip ties will need to be cut as well as several cable connections to get to the 6871QCH038A board. Replaced the board with the 6871QCH060Q upgrade. Make sure to keep the sticky foam rubber isolation pieces and adhere them to the new board. It did take some time to figure out how to disconnect and reconnect all the various types of cable connections. Just take your time. The power cable connector for the 6871QCH060Q board is in a different location, thus I had to reroute the cable. Reassembled and only had 2 unused screws left!
TV workd great. Lines are gone. Have a little burn-in going on where the red line appeared, but still better than forking over $800 for a new 42" LCD 1080P TV. Hope to get a couple of more years out of this Vizio.
One line I found has a general example of LG/Vizio repair manual. Not exact, but close enough...http://www.scribd.com/doc/7580885/LG-TV-Plasma-Training-Manual
Posted on Feb 18, 2009
  • 18 Answers
SOURCE: my vizio tv,VX37LHDTV10A darkened and shows
This may work for you. My Vizio went black except for the blue channel rectangle in upper right corner; I couldn't change the channels or power off. I called Vizio, was told I needed a hard reset, and this fixed my problem: I unplugged the TV; held down the on button for one minute, then plugged it back in. It works fine now.
Posted on Apr 03, 2010
SOURCE: vizio p50hdtv10a no picture, gray screen
This could be several things. It could be the main board 3850-0042-0150 or the plasma controller board 6871QCH083A.
Depending on what you actually see on the screen it may as well be bad Y sustain board (although less likely).
Unless someone has seen that particular issue in that particular model (or other that share the same deffective component) it will be anyone's guess which is the exact module. They all can be causing what you describe.
Since TV shuts itself in one minute I'm leaning towards the main board.
I'm afraid you'd have to either experiment or bring it to a service center that will either have such a TV and can try or will experiment on your behalf. Just make sure you do not pay for boards they experiment with. I know some of the other TV service shops in our area (and without a doubt elsewhere too) do that.
A TV service center (just as anyone with regular contacts with eBay) can resell incorrectly ordered part and end up losing $10-$20 on it which , if split between customer and technician, I think is completely fair. Just make sure you don't end up paying for a board that was ordered and turned up not the one in fault.
bobby
www.coppelltvrepair.com
Posted on Oct 31, 2010
SD Tech
  • 14553 Answers
SOURCE: vizio lcd flatpanel tv with dark background
If half screen is affected it will be either a board (LCD and Plasma have different names) but in those one board drives each side of the screen unit--worst case is the display panel itself which is fatal from a cost point of view.
Posted on May 25, 2012
Cause of dark spot on 1/4 of & vertical streaked shadows on the rest of screen?
Sounds like panel fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 19, 2015 | Televison & Video
Any idea on what is causing these issues with Vizio TV? Black lines horizontal, shadow vertical.
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD TVs will be similar, irrespective of its screen size and brand.
Jul 27, 2015 | VIZIO M701d A3R 70 Inch 1080p Smart
Shadow on right side of screen
Can you please give little details of shadow on right side?
Is it Vizio L32 lcd tv or any other model?
These info will help me to diagnose problem.
Thanks.
Nov 28, 2010 | Vizio L32 32 in. LCD HDTV
I have a 37in. vizio flat screen. It has a black shadow in the left center of the screen. It's there at all times.It's about 7in.x 3/4in.it runs vertical.any ideas?
wish the news was better for you, the convergence chip or the color engine has faulted and burned the screen This will be an expensive repair unless it has extended warranty
Please rate my help++++Thanks for using FIXYA
Nov 20, 2009 | Vizio L37 Television
Have a Vizio P42HDe purchased in 2005. Right half of screen is fine. Left half is series of small vertical bars (various colors). Sometimes they go away and all of screen is okay. Any ideas?
I bought mine in Jan 2005 and today it did the exact same thing....doesn't go away. Seems like a 5 yr. lifespan on these.
Will try a Panny for Christmas !!
mikebc580
Oct 12, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Dark shadow-like vertical streaks thru LCD screen (Sharp)
Hi, I have a Sony Grand Wega LCD Projection TV that has a blotted gray streak across the front of the screen. I only use a damp cloth to clean the window and that doesn't seem to help. It really shows up on light pictures and is unnoticed when the picture is a little darker. What can I do to fix this problem???
Aug 19, 2009 | Philips 32PF5531D 32 in. LCD Television
Shadows on screen
Try moving a medium powered magnet (not one for picking up heavy objects and not a refrigerator holding one) over the distorted area. If that doesn't work, try a more powerful one. This worked for my Toshiba LCD. Good luck!
Jan 04, 2009 | Sylvania 6626LCT 26 in. LCD Television
Dark vertical shadows
No,you can't. This is very common. I bought a new tv and i noticed right away that it had the problem you are mentioning. I took it back for an exchange and the next tv did not have this problem...until a year later. Now,of course it does have this problem,but it is out of warranty.
I think they make televisions very poorly today.
Apr 27, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Vizio L32 32 in. LCD HDTV Logo
82 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
