Question about Epson Aculaser C1100 Printer
PCU Dear Labatt. I also out of the blue recieved the message to replace my photoconductor unit I see in your post that the same trick will work on the Epson C1100. I've nearly completely dismanteled my PCU. I just can't seem to find anything that even remotely resembles a fuse. I've tried short circuiting the contacts with foil and then wire. Hell, I've cleaned out the waste toner compartment. No success. I also see someone else posting about a "kill chip". Checked out that thingy too. The one chip in my PCU is green and round. About the size of a mint. I Googled the number on it and it turns out to be a varistor of some sort. Is this the "kill chip"? Please help. I've done about 2500 prints with my PCU and really don't want to replace now
  • 3 Answers
The kill chip on my C1100 is actually on the side of the photoconductor. Open the top lid, pull up the orange handle on the right, and pull the photoconductor out. The killer chip is on the left hand side of the photoconductor. It is possible to buy new chips for about £15. I tried this, and it quickly died :( genuine photoconductors should last for thousands of pages, so are worth the money.
You really need to keep an eye on the photoconductor gauge on the printer screen on your computer. Mine got very low, and I hadn't noticed. Best to be prepared !
Posted on Nov 21, 2008
My printer sends me this message E 511 service required what does this mean?
error E511 services required mean part of photosensor that is transfer belt is not being detected
1. power the printer off, wait for 30 sec, and then power it on.
2. remove the photoconductor unit
3. check and clean the photoconductor and transfer belt.
4. clean the TR0 sensor in the printer
5. resolve any toner spillage inside the printer
6. reinstall the photoconductor,close all the covers and then power the printer off and on
if it dosnt work
To check whether the problem is with the printer or the PCU, if possible either try another PCU in the printer, or test the PCU in another printer you know to be working.
I think I it should work.
Mar 11, 2011 | Epson Aculaser C1100 Printer
I have several of these ricoh 1515 copiers all working fine and then posting a need photocunductor error. Is this some preset error that comes after so many copies like HP got sued for or is the...
Hi, the "Replace Photoconductor" message does come up after a preset number of copies, typically about 60,000. The photoconductor will still continue to work fine, and even with the message displayed the copier should run like normal. The message will keep flashing until you replace the photoconductor, and then it will automatically detect the new unit and the message will disappear.
Jan 21, 2011 | Ricoh Aficio 1515MF All-In-One Laser...
Savin 9927dp photoconductor ?
THE MAINTENANCE PROMPT COULD BE TURNED OFF BUT THAT IS AGAINST THE MANUFACTUREERS RECOMENDATION. THE PCU
WOULD LAST A LITTLE LONGER BUT IT WILL START DUMPING TONER AND DEVELOPER IN TRAY1 IF IT ISNT ALREADY THAT JUST ADDS TO THE CLEANUP TIME AND COST THE PCU WAS DESIGNED TO MAKE 60,000 PAGES.
May 06, 2010 | Office Equipment & Supplies
How to replace image unit ricoh aficio 220
Do you mean the photoconductor unit? To replace the photoconductor (PCU), open the front cover and the right side covers (the duplex door and the main side door). The PCU sits to the right of the toner bottle -- it is a black unit that has the blue cylindrical drum facing the right side of the copier.
On the upper left side of this unit is a ridged tab. Push this tab in and slide the PCU all the way out of the machine. Open the box with the new PCU and remove all of the tape and paper, then slide the new PCU in where the old one came out of. When you shut all of the covers, the copier will recognize the new PCU.
Apr 23, 2010 | Ricoh Aficio 220 Laser Printer
AFTER PHOTOCONDUCTOR REPLACED PAGES ARE BLANK
IF you replaced the entire PCU, make sure you pulled the plastic tabs from the unit and removed the protective paper from the drum area. I don't remember if the new PCU comes with developer pre-installed.
If you replaced the drum/developer, it is common for the lower developer unit drive gears to wear down and break off some of their teeth.
Hope this helps.
Jun 30, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Replacement parts
I have same printer and C1100 also.I looked for the photoconductor parts.Opened photoconductor unit in pieces n reassembled it. there are 2 parts where useless toner is kept in PCU empty them by unscrewing these two parts.The the photoconductor rod is very sensitive and if it needs to be changed I advice buy if not new then refurbished one complete PCU.I know someone who do refurbished PCu and in it uses new photoconductor rod.other then Photocconductor rod all is long life if you empty those two pockets in PCU.refurbished will cost you 70 GBP and if you are looking for that part then so far I am unable to locate it in the market n 70 GBP is not bad for almost new like PCU.
Jan 19, 2009 | Epson ACULASER CX11NF All-In-One Printer
ACULASER CX11NF Photoconductor reset - chip?
The reset chip will not provide you with a long term solution to your problem. The photoconductor unit is now full of waste toner and the photoconductive drum, prime charge roller and wiper blade are all worn, this is the cause of the message. Your only real and the correct solution is to replace the Photoconductor unit with a new one. Remember that this is part of the consumable set for this printer and is therefor costed in as part of the cost per page.
Should you proceed with the replacement chip, you will be opening yourself to deminishing quality print and eventual failure of the unit.
Gremlin11
Jul 24, 2008 | Epson ACULASER CX11NF All-In-One Printer
No function on my printer is working
E-511 error message is related to the Photoconductor Unit. In order to resolve your issue, there 3 things that I'd like to suggest.
1. Take out the Photoconductor Unit and turn it upside down check if the white tabs restract. If it doesn't you need to replace the PCU otherwise just put it back in
2. If reseating the PCU doesn't resolve your issue, try a different PCU
3. Lastly, warranty options if your product is within the 1-year warranty from the date it was purchase contact Epson Tech support they'll be more than happy to send an onsite tech support to fix it otherwise visit their website support.epson.com and look for a repair center in your area
Jun 18, 2008 | Epson ACULASER CX11NF All-In-One Printer
Worn Photoconductor Epson C1900 laser Printer
hi this solution has already been covered in full lengths. Epson c900 and c1900 are similar. have a look at my posting on this. photoconductor reseting by Labatt in this forum. read from the start.
http://www.fixya.com/support/t146110-epson_aculaser_c900_photoconductor
Jan 29, 2008 | Epson AcuLaser C900 Printer
Error Message: Replace Black PCU
I'm not sure how to obtain one, but "Black PCU" stands for Black Photoconductor Unit, and according to a manual for a different Ricoh printer model, it should be fairly simple to replace if you can find one.
Nov 10, 2006 | Ricoh Aficio CL2000 Laser Printer
Epson Aculaser C1100 Printer Logo
288 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
