Question about Cycling
Xsport 110 pit bike
I have a xsport 110 and it starts to splutter at mid to full throttle. can you help me?
  • hbomb777 Dec 12, 2008
    tried plug, air filter and cdi but still no better
  • Anonymous May 12, 2009
    i got an xsport the other day what oil does it take ?
Check the 4 stroke oil if it starts to splutter at half throttle
Posted on Mar 06, 2009
  • 55 Answers
Sounds like you may need a tune up. Change the spark plug. Also if your using "bad" gas may also cause a problem.
Posted on Nov 09, 2008
Over revving 110 xsport
110 xport over revving need help have tryed all screws on carb cant seem to sort it out any one no
Mar 14, 2013 | Pit SSR 110CC Pro Beginner Bike
09 TM EN 300,after the bike is warm and ridden for around an hour or so,it splutters and misses under quarter throttle intermittantly..Clean carby jetted well..Electrical issue im thinking?Anyone...
Check the gap on the points and check to see if they're pitted or burnt. You might just need to clean them with some emery cloth or something similar. If they're pitted or burnt, they need to be replaced
Jun 18, 2011 | TM Racing EN 300 Motorcycles
When i hold the clutch in on my 125cc xsport pitbike there is a rattling noise in the engine like a ballbaring rolling round. help!
If it sounds like there's a ball bearing rattling around in your engine there probably is... take off the side cover and investigate it can't get any worse...if you keep riding it it'll only go bang and wreck the whole engine
Dec 16, 2010 | Pit Bike 125cc 4 Stroke Dirt Bike
110 pit bike my pit bike starts but when i pull da
your spring might have broke on your throttle needle take apart have a look
Nov 11, 2009 | RTO Pit Bikes
Hi mt pit bike is spluttering under acceleration i have tryed to adjust air screw with slight difference but it is still not smooth under power. bike is fk1 125 dont know if valve clearence would be the...
Your bike may be jetted too lean. A common problem in these days of overzealous EPA regulations. You can tell if when you've cranked your throttle wide open and it splutters, if you back off on the throttle about 1/8 to 1/4 turn, it clears up. This is indicating that it is jetted too lean. When you close the throttle slightly, the fuel is being metered by the main jet and by backing off on the throttle a bit, you're cutting back on the air, thereby bringing the mixture closer to what the engine needs. Try rejetting the carb, Go up one or two sizes on the main jet, one step at the time.
Now, it could be too rich as well. If it splutters and blows black smoke out the exhaust, it either jetted too rich or the float level in the carb is set wrong.
Take care of the simple stuff first before rejetting the carb. Make sure your spark plugs are the correct ones and they are not fouled from overusage of the choke or enricher. If you allow the bike to "warm up" with the enricher on, plug fouling is common with this practice. I get the bike started and as soon as it will run without the enricher or choke on, I turn it off and keep the bike running with the throttle. Don't foul as many plugs that way.
Nov 09, 2009 | 2008 Yamaha Yamaha G5
I just got a 110 ssr pit bike. is the back brake
It should be below. Not to sound rude, but I think you could have figured this one out yourself. You sound like a smart guy.
Thanks for using FixYa.
Aug 12, 2009 | Pit SSR 110CC Pro Beginner Bike
Aprillia SX125 spluttering Mid revs too
Can you confirm if this has a 28mm Dell'Orto carb ?
I would think that you might be possibly running too rich in mid range between ¼ and ¾ throttle opening in which you could try to drop your needle (raise the clip)by two notches,and if this helps but not eliminates the problem,maybe a slightly smaller main jet.
Please get back to me if you need more help.
Aug 10, 2009 | 2008 Aprilia SX 125
I have a pit bike and it splutters alot when i ride it
my pit bike will not keep it revs for a long time so can some one help me it is my first pit bike
Jan 09, 2009 | Pit SSR 110CC Pro Beginner Bike
Cycling Logo
726 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
