Question about Garden
CANT REMOVE HEAD TO CHANGE STRING
HOW DO U REMOVE HEAD TO REPLACE STRING
  • 3 more comments
  • Anonymous May 05, 2009
    can't figure out how to restring troy built tb575ss
  • Anonymous May 07, 2009
    i've tried unscrewing 'clockwise', but it won't budge.
  • Anonymous May 25, 2009
    Can't remove string head to replace string
  • Anonymous Mar 12, 2014
    machine runs but string head won/t turn
  • Anonymous Mar 15, 2014
    How do you remove the end of the trimmer to replace the string
  • 599 Answers
Unscrew 'clockwise'..... the opposite way that you would normally unscrew something
Posted on Nov 13, 2008
How do i remove the head to replace the string on a Murray M2500 trimmer?
How do i remove the hend of the weedeater it is stuck on there. I believe it is stripped
Sep 08, 2014 | Garden
How to replace the spool head
Once you remove the spool cap and the spool, you cannot remove the head from the motor. It is not a replacement part.
Ryobi P2002 Cordless String Trimmer Parts
Aug 31, 2014 | Ryobi Lithium Ion 18 Volt 18v Cordless...
I have a Echo Gas trimmer SRM-210 Rapid feeder dual line. I need to know how to remove the entire drum for the string spool? NOT how to re-string but how to replace entire head/spool, as if I was going to...
In your manual under section 12: Line Head Installation. You will do the opposite of what it says here. The key is to LOCK the gear drive so the flex-drive shaft won't turn WHEN you are removing the trimmer head. They use a special tool (maybe you have it). But a small-shafted Phillips screwdriver or the like can be put in the drive hole to lock the gearing up as well. Look for the hole in the upper plate and align with the notch in the drive housing and grasping the entire string head unit, remove it. Here is your manual, see Section 12
http://dl.owneriq.net/8/854215d5-44e4-4b5d-b773-77b331fd73b3.pdf
Jul 17, 2011 | Echo Rapid Loader, Trimmer Head
I was given a used 31cc trimmer but can't get the spool off to replace it. how do i do this?
A typical trimmer has a small bump knob, an inner spool with the plastic string wound on it and the housing for that which is the string head.To remove the small bump knob, hold string head firmly and turn the bump knob counterclockwise. To remove the head entirely, first remove the bump knob. Next, remove the inner spool with string. What should be left is the spring with the end of the gear shaft showing. Some heads are locked on and some just slip over the end of the shaft. Check the gear drive just above the string head for any holes in the collar. An object can be placed in one of the holes to lock the drive and twist the head off.Ryobi's use retaining clips on the shaft which have to be removed.
May 06, 2011 | Garden
How do I change a valve spring on a v92c with out pulling the head off
to be honest you cant do what you wont to do,,,changing valve springs need the head off,,,,but you could try making a tool to go down into a plug hole to hold the valve up,,, it may work but watch the spark plug threads??? good luck!
Feb 05, 2010 | 2001 Victory V 92 C Deluxe
How do you remove the old string head to add replacement?
untwist the nut at the bottom of the spool head to replace the string
Aug 30, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I need directions to replace string on black and decker cordless 18v grasshog
Go to home depot. look at the floor model and the replacement spools they sell there. Reverse engineer the stringing process or but a pre-loaded spool.
Otherwise,
1. Squeeze the tabs on the side of the head of the unit to remove the spool cover.
2. remove spool.
3. place end of string in small hole in center ring of spool.
4. wide spool with string in the direction of the arrows printed on the spool. DO NOT OVERLOAD!.
5. snap string into notch on spool and cut string leaving 6" exposed.
6. thread 6" of string through hole in side of unit head, replace spool, and replace cover.
7. go cut grass.
Jul 07, 2009 | Black & Decker String Trimmer Cordless 12"...
Homelite strin trimmer head wont rotate
The only way to access the bottom of the metal shaft is to break it. This is fused on at the factory. It sounds like your flexshaft has twisted in two. Remove the flex shaft from the engine end and see if it is in one whole piece or is damaged in someway. If it rotates at the top but doesn't rotate at the string head this is probably the problem. However, Homelite no longer offers just the flex shaft for purchase. You would probably have to purchase the shaft and the tube as a unit.
But if you are saying the spool and string is not turning at the bottom it could be that the cup which holds the string has worn and can not longer be turned by the shaft. Replace the cup that holds the string.
Another possibility is that the shaft have moved forward, away from the engine and just need to be jammed back in, and retightened (the handle grip and the boom clamp).
Jun 17, 2009 | Homelite Mighty Lite Lawn Trimmer
Require Manual for Ryobi PTL 2543 25cc line trimmer
Or sometimes you unscrew a retaining bolt set into a plastic "lug", the spool drops out, refill t with line, replace it putting line through holes in the spool casing, refit the "lug" and tighten it again. I think I have the manual for this though and if so maybe I can send you a link to images on MSN Homepage to help you..
Feb 22, 2009 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
1,879 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
