Question about Sony FD Trinitron WEGA KV-27FV310 27" TV
Sony TV - Loss of half the picture
Sony FD Trinitron; KV-27FV310 (over 2 yrs old) TV was working fine, then all of a sudden....Bam! I could only see half the picture. Horizontal line half way down cutting out/off top of what actually should be seen on the screen. Bottom portion viewing is good. Top potion is black. Never had issues with TV for past two years. Connect to cable.
  • 1 more comment
  • Anonymous Nov 08, 2007
    Watching TV, suddenly lost top half of picture. Top of picture is black. Bottom half is normal, with a bright line separating the two.
  • Anonymous Feb 19, 2008
    Same as above. Half the screen is black with a bright line in the center. Is there a Step by Step instructions on how to fix it yourself. Please advise, as with nowaday prices, one may as well purchase a new TV set for the price you'd pay to get it repaired.
  • Anonymous May 12, 2008
    i have the same problem except my tv was workin the night before and i got up to go to work and i turned on the tv and there it was it mad me so mad so i looked at it after work and i dont no what to do the lines are on the top half of the tv and they are horizantal but it seems to be getting better for some weird reason so HELP i dont no how much longer i can take it with out a tv in my life lol HELPPPPPP
    President:
  • 3,130 Answers
Sarge, it sounds like the vertical output IC went bad on you. If it was a bad connection or a bad capacitor, your picture would have been a straght line across the screen. They call the output section of the IC a push-pull type of amp, so the top half of the sweep IC went out. If you have had some soldering experience, and or experience with solid state repair, locating the bad IC and replacing it is no big deal. If you havent, stay safe and call in a pro to assist you in this repair, as there is alot of high voltage inside this puppy that is still present even if the set is unplugged. It should not cost an arm or a leg to repair this set. An honest repair on a set like this if you take it in should not exced 125 to 150 bucks. Good Luck PS Please dont forget to rate this thread.
Posted on Oct 22, 2006
  • Ed Harman Sep 22, 2013
    My 46 inch Sony Tv experienced the same problems except the top half of my screen is filled with lines while the bottom is perfectly clear. After talking with Sony reps, I have vowed to Never!!!! purchase one of their products again.
    Scholar:
  • 68 Answers
Follow techmans advice. A vetical timebase failure like this is not bad and should not take a Serviceman long to fix, and therfore should not cost too much, if he has the all important service sheet, or circuit diagram and an oscilloscope. Line/horizontal timebase failure is much more serious, as this is the primary source of power and would cost more.
Posted on Oct 23, 2006
3 Suggested Answers
  • 119 Answers
SOURCE: 1/3rd of Bottom portion of Screen is blacked out
sound like you have cloced caption text on, this is not the same as the normal cloced caption, look on your rempte for caption or "cc". if you don't see it you will find it in your menu & turn it off. have a good day.
Posted on Jan 02, 2007
  • 6771 Answers
SOURCE: I have a Sony FD
The set has a vertical deflection problem, the vertical ic and a few capacitors will need to be replaced to restore the tv to normal function.
Posted on Apr 29, 2011
I have a Sony FD Trinitron 27' Model # KV-27FV310. It is approx 8 years old. After turning it on and watching a full screen for a few minutes; all of a sudden, a line came across half the screen;
top half missing is in vertical circuit of set---if it is a 27 inch and this old consider retiring it and replacing----other option is consider having a shop repair it--a rough guess would be as high as 150 dollars parts and labor is possible for your problems.
May 01, 2012 | Televison & Video
My 11 yrs old 25"
No,the tv main logic pcb board have dead components parts on it and also the tv video boad too.This tv must take to tvs shops and get estamate see it is worth the priced to be repair or compair the prices could be cheaper just replace another tv.
Aug 10, 2011 | Sony FD Trinitron WEGA KV-24FS120 24" TV
I have a Sony Trinitron 32 color tv KV 2168MTJ (quite old - 10 yrs old), and the standby light blinks exactly 200 times (just over 3 mins) before it turns on. Once it is on, it works perfectly. What's...
A poor solder connection on B+ is the line, Horizontal drive transformer or at the base of Horizontal Output transistor can caused that. Re-soldering these section can fix it..
Oct 23, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-20FS120
You need to replace its Picture Tube (CRT). Its CRT's defect.
Jul 29, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony tv kv-32fv300
you probably aren't checking this posting out anymore, but maybe someone else will see this and it can help them.
i was having the same problem, did a search and found this solution. worked like a charm!! go here:
http://www.floggingenglish.com/2008/07/22/diy-tv-repair-fixing-screen-flicker-on-a-sony-hd-wega/
Nov 24, 2007 | Sony FD Trinitron WEGA KV-32FV300 32" TV
Sony trinitron kv-27ts20
Posibbly a PTC assy error. This is used for CRT demagnitesation. Pro will provide efficient cure. If you need more info please advice.
Apr 01, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony FD Trinitron WEGA KV-27FV310 27" TV Logo
2,254 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
