Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Hoover steamvac dual v carpet cleaner problem
My machine will not dipense any of the water/solution. i have done everything i know to do. it will **** up when i pour water on the floor but will not dispense it. i am so angry. its not very old at all- not even a year. help
  • Anonymous Nov 10, 2008
    My Hoover steam vac is only one and a half years old and has not been used very often. I can not get it to release water on the wash cycle but it will release soap. It does release water on the rinse cycle. I can't seem to get any answers from the Hoover Company and the recommended repair service had it for 2 and a half months but didn't know how to repair it. I'm at a loss as to how to get it repaired
4 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: Leaking Hoover Steamvac
Either you have a crack in the tank and it is running down the indise of the handle and going out the bottom, or there is a water line off either under where the tank sits or under the top cover.
Posted on Mar 29, 2008
Mine did this exact and it turned out my pump was cracked.
Posted on Mar 30, 2008
  • 3 Answers
SOURCE: Hoover SteamVac Dual V Carpet Cleaner # F7410-900
Turbine assembly is bad. Get part #23 here http://www.vacuumcleanershop.com/hvrmdlf7205900.htm#B2
Not to bad to put in.
You can also find them on Ebay cheaper.
Posted on Jul 01, 2008
I have a 1 year old Hoover carpet cleaner . I went to use it today and it won't start. Everything seams to be in the right position. can't figure it out..
Dual Power™ Carpet Cleaner - Hoover
hoover.com/products/.../dual-power-carpet-cleane...
The Hoover Company
Rating: 3.5 - ‎84 reviews
Dual Power™ Carpet Cleaner. Easy to Empty Tank ... You currently don't haveany recently viewed items. ... 3.5 out of 5 stars. ... The Hoover Dual Power™ Carpet Washer deep cleans on the double. ... 1 Year Limited Warranty .... The rinsing stage is a must and it cleaned a 20 year old carpet that was badly stained.
Hoover SteamVac Troubleshooting: Carpet Washer Loss of ...
? 1:19
https://www.youtube.com/watch?v=6TkcWjuz1zw
Aug 16, 2013 - Uploaded by Hoover
Your SteamVac carpet cleaner should pick up as well today as the day you got it. If you're experiencing loss of suction or noticing that your SteamVac won't . ... Hoover 1 year ago ... thank you! worked and i did not have to wait for call center to open! thank ...This machine is running well almost four years in.
Repairing a Hoover Carpet Cleaner ' ThriftyFun
www.thriftyfun.com/Repairing-a-Hoover-Carpet-Cleaner.html
I have a Hoover f7412900 carpet cleaner and one day the brushes stopped working. ...It was a couple years ago, so I don't quite remember, but it was in the manual, ... Itwon't start back up. ... If it is only 5 months old, it is likely still on warranty. ... Do not try to fix this yourself, as you may void the warranty if you start taking ...
Jan 29, 2016 | Hoover Vacuums
Was sucking up cleaner and water on carpet and suddenly there was smoke and the machine shut down. Is it broken for good?
Patsy,
Depends on what went wrong. How long have you had it? Do you know if it might still be under warranty? Check this link to see if you can find someone close to you that could look at it. for you.
Service Center Locator
Aug 10, 2015 | Hoover F7412-900 SteamVac Dual V Widepath...
I have a Hoover carpet cleaner that leeks the shampoo water onto the carpet, cannot control it
The machine is standing in the upright position with clean water in it. No power to the machine. If water is pouring out, again no power to machine, then the pump is cracked. I don't know the model number so I am thinking this has a gravity fed pump. It doesn't use electricity to work the pump. Once you pull the trigger water starts to flow. If the pump has a crack water will flow all the time. Hope this helps!
Jun 16, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover carpet cleaner dual 5
Try this site for more information on this problem
It may just need a good clean out.
http://hoover.com/support/manuals/?q=SteamVac
Feb 05, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover carpet cleaner won't dispense solution or water. Everything else works.
1.Remove bottom tank and look for pinched hose. 2.Use small screwdriver or toothpick on small holes which disperse solution-remove rotating brush first. These were problems with my steamvac (f5861-900 model).
Mar 16, 2011 | Hoover SteamVac Carpet/Upholstery Deep...
Cleaner was working fine. Emptied the recovery
yes please help0. my carpet is soaked and the machine will not **** up the water
Jul 03, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Water leaking out bottom with hose attached
The water hose plugs into the solution valve-pressure on the side of the noozle(bottom). There may be a water line that has come loose there, you will have to take the top off to get to it.
Apr 20, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Mar 29, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Steamvac Ultra
make sure all parts are snapped in again i did the same thing.......
Mar 17, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
29 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
