Question about Kicker KX120.2 Car Audio Amplifier
Protection light I got my amp hooked up, and when i went to turn it on the protection light came on for about 3 seconds, went off followed by the green power light coming on, but still no sound. what do i do to fix it?
  • 132 Answers
Double check the blue stereo input wire to amp is this a new amp if not speaker channels in amp might be blown
Posted on Nov 09, 2008
I had these 12in pioneer subs so I went and bought the new Rockford Fosgate they came out like a week ago my problem is every time i hook them up to the amp the protection red light turns on can you...
if the amps impedance is higher than the speaker, it will trigger the protection circuits, because the amp sees it as an overload, example the amp has 8 ohm impedance specified, and your speaker has 4 ohm specification, that is a clear overload. Bring the subs back to the amp's dealer and have the amp replaced; the one that matches your subs. Hope this helps... ;-)
Feb 03, 2011 | Car Audio & Video
Got a problem with my car amp.Everything was working fine until 2day.Amp goes in to protection mode.Jumps from power to protection indicator every i would say 3 seconds and each time it goes in to...
Ok check the remote wire running from the headunit to the amp should be giving v12 feed whiles headunit is on.
check or change grounding position.
take cover off the amp as the circuit may be over heating.
Sep 22, 2010 | Car Audio & Video
Protection light keeps flashing on and off
try hooking up only the power ground and remote see what happens if protection light is on then u have a problem with amp if it goes off then hook up rca if still off then hook up speaker wire if it turns on then u have a prob with speakers
Feb 02, 2010 | Kicker ZX10001 Car Audio Amplifier
Protection light comes on went the amp is turn on and it stays on for four seconds and then the amp turn on
Disconnect any speaker from the amp then re-power. If it still goes into protection, your amp needs serviced. Shorted output transistors most likely. And check your Sub for shorts as well. If the voicecoil on the sub is burnt, it will short any amp. If you can use a meter, check the resistance on the sub. Hope this helps
Jun 02, 2009 | Kicker KX Series 04KX1200.1 1200w RMS...
Protection Light Comes on
Sounds like you have an ohm problem, Tryy hooking the positive from one speaker to the negative on the other speaker. Then hook the negative from the first speaker to the negative on your amp and the positive from the second to the positive on the amp this will drop your ohm load and the amp should stop going into protection.
Mar 08, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Protection light lights up for a second and turns off and the amp seems like it is not working. It is connected and wired correctly.
disconnect the speakers from the amplifer, and turn the system on again. if the protection light still is active even without the speakers hooked to it, then it is most likely that you have a blown transistor in either the power supply section, or the output section.
Either way, your amplifier will need to be serviced.
Dec 07, 2008 | Kicker Car Audio & Video
Protection light coming on and amp cutting off
yes make sure there both connected properly, check the fuses, the protection light usualy comes on when there is too much power and the amp protects itself from blowing
Jul 16, 2008 | Car Audio & Video
Lanzar Vibe 1200D protection light
You will need to show it to a service technician as it seems the output section has blown so it remains in protect mode. One reason (could be) that the input to the amp was high and may have been clipping for some time before the amp decided it could take it no more
Jan 14, 2008 | Lanzar Vibe 1200D Car Audio Amplifier
My amp wont put out sound
it's blown....probably, check your connections and make sure your presenting it an ohm load it can check the sub with a dmm.
Feb 28, 2006 | Jensen A600HLX Car Audio Amplifier
Kicker KX120.2 Car Audio Amplifier Logo
142 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
