Question about Dryers
Hotpoint aquarius tdc32p not heating up replaced old heating element but still not heating
I had the same problem which turned out to be the thermostat.
You can fix it at home easily with only a screwdriver.
UNPLUG FIRST!
  1. Remove the strengthening bar on the back
  2. Remove the small cover in the centre of the rear
  3. Remove the funny shaped cover from the rear (NOT THE WHOLE BACK PLATE) This will give access to the heating element and the 2 thermostats above it.
  4. Take off the thermostat with a green dot on and look at the bottom metal plate. If it's concave, bang it on the floor until it pops back out. (Seriously)
  5. Re-fit the parts in reverse order and you done!
Posted on Jan 09, 2010
  • marting095 Nov 28, 2010
    Fantastic info !! Really worked, I had worked out the thermostat was open circuit and had come inline to order the part. This saved me time and money. Cheers !! Had to bang it pretty hard but it popped out after a while !!
Hummin noise hotpoint TDC32P dryer
That noise is usually associated with a failed AC motor that turns the dryer drum.
Dec 01, 2016 | Hotpoint Dryers
Hotpoint dishwash not heating the water but it not the eliment
Check and see if during the heating cycle there is voltage to the element. If not, you will need to replace the control board/module. from serial number 41011 part no is c00143209, to serial no 41011 part no is c00143207
Apr 21, 2014 | Hotpoint Dishwashers
Tdc32p condenser dryer has low heat only
It could be, also is the condenser taking the water out ok into the drawer, if not they could be a blockage in the pipes and a pump underneath the dryer may be blocked or faulty.
this could be the cause also.
Sep 14, 2009 | Hotpoint TDC32 Electric Dryer
Can anyone tell me how to replace the heating elememnt on tumble
open back pay attetion to where you take the old one off just streach it out around the clips
Feb 17, 2009 | Hotpoint NWXR473EV Dryer
Dishwasher Hotpoint 7885 Aquarius Ultra Plus
sounds like the heater for sure. engineer job.
Jan 25, 2009 | Hotpoint Aquarius WD640 Front Load...
Dryer
maybe heating element or possibly stats. take back panel off and check
Aug 12, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Changing the thermostats on a TDC 32 P
your stats are at the back of the dryer take the metal cover off at the back u should see your stats straight away the cover should be the one that sticks out more than your back casing m8
Aug 27, 2007 | Hotpoint TDC32 Electric Dryer
Dryers Logo
161 people viewed this question
Top Dryers Experts
