Question about Denon AVR588 Receiver
Brand new avr588 receiver is turned on....is on for five seconds and then cuts off to standby
I purchased a new avr588, got it home, plugged everything in, pushed the power button and waited. the screen came up, it said "AV SURROUND", then said "RECEIVER" and then it cuts off with a blinking red light standby button. Can anyone help?
  • sri1007 Jan 26, 2009
    i have same problem - someone help
  • azimsardar May 03, 2009
    I have the same problem with power cutting off and red light flashing and it is not any speaker wires or other devises, how to fix this problem, is there any part that can be ordered and replaced.
  • 3 Answers
Hi donnie025,
I can't believe you haven't received an answer before now.
The red flashing light normally indicates that the protection circuit has been tripped. It can be caused by something as simple as a short in a speaker wire. Even if there is one strand of loose wire that makes contact with the back of the receiver, another wire, etc. it can cause a short. To protect itself the receiver will simply shut down.
1st. I would suggest disconnecting all the speaker wires from the back of the receiver. Then turn on the receiver (obviously you won't hear any sound) and see if the receiver does the same thing. If it does you should try disconnecting all of the source components (DVD player, Cable box etc.) and try again. If it still does it the receiver is bad and needs to be serviced or exchanged if you still can.
2nd. If the receiver stays on after you disconnect, then turn off the receiver and connect one speaker at a time, then power on the receiver at test it after connecting each speaker. This way if it suddenly shuts down after connecting a speaker you know which speaker or wire to check.
Let me know how it works out for you, I hope this helps if you haven't figured it out already.
Matt @ OneCall
www.onecall.com
twitter.com/onecalldotcom
Posted on Feb 28, 2009
Sony tv model no. kv-ha21m80 is on standby mode & its LED is blinking FIVE times blinking
Visit this site. Standby LED blinks to Sony televisions of all types are described in detail there. Usually five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there.
Nov 28, 2012 | Televison & Video
How to reset the recever?
Place the receiver in Standby mode (press the front-panel Standby/On Switch so that the Power Indicator turns orange).
Then press and hold the front-panel OK Button on the Receiver ( not remote ) for at least five seconds until the RESET message appears in the display. Then press OK. The system will go to factory default. All your settings will be lost like FM stations / Sound settings etc: .
Apr 03, 2011 | Harman Kardon AVR 35 Receiver
My receiver stays in standby mode and will not power up. It will turn off but will only turn on back to standby.
Unplug the unit from power and wait at least five minutes. Plug it back in and try it. If that does not work check your operating manual to see if there is a reset that can be performed. This would do a "factory reset" which would hopefully solve the problem. Good Luck!
Nov 08, 2009 | Harman Kardon AVR 240 Receiver
Denon AVR588 receiver auto shuts off
You may reset the unit to factory setting. Hold buttons "Speaker" and "SpeakerB"and turn on power switch. Release buttons after 5 seconds. You will loose all your setting and need to do configuration again.
Jul 07, 2009 | Denon AVR588 Receiver
Denon AVR-2309C1 will not play sound through
Turn off zone 2 then turn your receiver on the main zone on Radio, tune in a station and check for audio. Post a comment and let me know if audio works that way. If you don't have any audio, list your other equipment makes and models as well as how they are interconnected to your receiver (cable type) and I will help you troubleshoot
Jun 28, 2009 | Denon AVR588 Receiver
I have a Denon AVR 1906 Home Theater Receiver and I just hooked it up and then when I turn on the power the power stays on for about 10 seconds and then the power button blinks green and then shuts off....
Try taking out all the cables on the rear, switch the unit on and see if it happens again and if not then you had a cable wrong somewhere, if it still does it it is probably going into safe mode, could be a problem with the output stage chip/s, they usualy auto-off when they sense a problem to prevent further damage.
Jun 27, 2009 | Denon AVR588 Receiver
Sony dav dz100 won't eject dvd
Press standby button to turn on the set, select dvd function then press and hold STOP and EJECT button for five seconds or more to UNLOCK cd slot. You will see UNLOCK in display.
Jan 02, 2009 | Sony DAV-DZ100 System
I have a Samsung HT-z510 home audio and the wireless receiver for the back speakers stays in standby mode. I have set the mode to cinema but it still stays in standby. What can I check next?
Here is how I reset. Key terms to identify: Main unit, remote unit, transmission card, reset button on remote unit. 1. Unplug both units and remove transmission card from rear of Main unit. 2. Wait five minutes. Insert transmission card in rear of Main. 3. Turn on both units. If units do not communicate, there will be a solid red indicator on remote unit...In this case continue with 4. Use remote and turn off main. 5. Point remote at main and enter the following four digits, holding each down for about a second:  0   1   3   5 6. The main unit should turn on. 7. With remote unit on, press and hold down the reset button for 5 seconds.
Nov 29, 2008 | Audio Players & Recorders
Sirius question
Yes it should be very easy with use of the ear phone jack - depending on the model of course but generally all you need is an ac/dc power supply, the antenna connection, and for connection to receiver you can connect via FM or hard wire.
FM: as in your car pick an FM station frequency that is clear (no station on it) lets say 88.1 then set your home receiver on 88.1 and there you have it.
DIRECT: purchase a stereo 3.5mm headphone cable with two RCA male plugs at the other end. A faily common cable found in dollar stores or for five times the price at Walmart/Radio Shack etc.. Plug the 3.5mm plug into the 'headpone' jack of the satellite radio and the RCA plugs into the rear of your home receiver - usually a 'aux/line in plug" or "tape in" plug then turn the knob on the receiver to "aux or tape" selector. Bingo you should hear satellite radio all over the house....if the volume is UP! Take care Frank
Sep 05, 2008 | Sirius Satellite Radio Receiver
Receiver keeps turning off after I turn it on.
CHECK THAT YOUR SPEAKER CABLES ARE NOT TOUCHING.ALSO DID YOU NOTICE THAT THE SPEAKER CONNECTIONS ON YOUR 605 ARE SIDE BUY SIDE NOT ABOVE EACH OTHER?
Jun 02, 2008 | Onkyo TX-SR605 Receiver
Denon AVR588 Receiver Logo
659 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
