Question about Nespresso Le Cube
Le Cube cup lights flash on and off alternately!
Bought a new magimix le cube, but when I turned it on and after the on/off button light stayed lit, the two cup lights start to flash on and off but no matter how long I wait the cup lights do not stay on but keep flashing from one to other etc. David
  • 1 more comment
  • seb7569 Dec 10, 2008
    Same problem...please need help
  • bdeblij Dec 26, 2008
    I have exactly the same problem, although my machine is two years old!
  • mark1001 Dec 30, 2008
    mine is year old and has same problem.
    first times it helped to Reset: keep ' large' button pressed, then turn on and keep large button pressed for 10 sec.
SOURCE: I lost power and now I get blinking lights on my le Cube 185
I had a similar problem where both Small and Large cup buttons on mine blinked intermittently. I did a reset of the large and small cup flow levels based on the following and it seems to work fine now:
1. Switch off power 2. Press and hold Large cup button 3. Switch on power while still holding down large cup button
See if that solves your problem.
Posted on Jun 22, 2010
SOURCE: le cube
Run an entire tank of water through the machine to clear out any remaning descaling solution. Once the tank is empty, you can turn off the machine, and it will exit the descaling mode automatically. Leave it off for a minute or two and then turn it back on, and it should run normally. Remember that the power light will blink while it is warming up when you first turn it on.
Posted on Nov 03, 2008
SOURCE: Le Cube: Water does not flow after tank in Le cube ran dry....
Open the lever (the one on top of where you put the pod, and keep pressing it backwards until water comes...
Posted on Oct 04, 2010
SOURCE: After descaling le Cube two flashing buttons won't stop so can't
I had the same issue. This is what a did:
Turn off the machine
Remove the tray/container and leave it outside
Turn on the machine and this time the power button should be flashing (preheating) then hold both cup buttons for 3 sec and it will be back to normal opertion....
For some reason the sensor needs to read that the tray/container is out of the machine...
Posted on Feb 05, 2011
SOURCE: I have a Nespresso Le
how can I reset my Le Cube? Volumes have changed.
Posted on Feb 06, 2011
Nespresso magimix
Check the relay on circuit board
Jul 20, 2014 | Nespresso Le Cube
Very slow water flow, barely filling tea cup
It could be a problem with an air bubble or with scale deposits.
It is recommended that you first run a descaling cycle using the proper descaling product. Do not use vinegar as it can damage your machine. Information on descaling can be found here:
http://www.nespresso.com/fileadmin/shared/_img/manuals/Nes_DescalingKit_CBU_internet_081216.pdf
To find more help with your product go to the website below:
http://www.nespresso.com/#/no/en/coffee_machines/selecteur_gamme/machines-le-cube/le-cube-nespresso-auto-d180---110-v-1
Feb 28, 2011 | Nespresso Le Cube
Hi, My Nespresso LeCube doesnt make full espresso or coffee anymore. It only fills the espresso cup less than 1/3 and its very diluted. Appears the rest of espresso falls into the drainage area. I have...
I had the same problem. First, unplug machine for two (2) minutes. Then re-plug and as on/off switch is flashing- press and hold large cup button for 3-5 seconds (no light should show/flash from this button while you hold it down. The on/off will continue to cycle through its normal startup, after it completes you should be reset to factory settings and good to go. Good luck to you, this maneuver saved me.
Sep 11, 2010 | Nespresso Le Cube
May 18, 2010 | Nespresso Le Cube
The small and large cup buttons are alternatly
I had the same problem and was told it needed to be repaired by Nespresso and the cost would be 115 euros.
Jan 07, 2010 | Nespresso Le Cube C185 Espresso Machine &...
Aug 24, 2009 | Nespresso Essenza C100 Espresso...
May 16, 2009 | Nespresso D290 Espresso Machine
Le cube
Nov 01, 2008 | Nespresso Le Cube
Where can I download the manual?
The manuals are available on the Nespresso website (www.nespresso.com). Click on the "machines" section, and then choose the le cube. Click on the details page (https://secure.nespresso.com/precom/sima/fiche__NESPRESSO_Le_Cube_D185__N_D185_1_us_en.html) and you should see the link for downloading the manual. You can also download the descaling instructions as well.
Aug 06, 2008 | Nespresso Le Cube
Nespresso Le Cube Logo
3,347 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
