Furnace Model # GU050-2 will not turn on in heat mode.
Have a Hunter thermostat 44155C and when i went to put it in heat mode the heat will not kick in. Have pins on thermostat set for standard, and Heat Gas (hg). When I put the fan into On instead of Auto the fan does kick in but still no heat.
meBNme
  • 334 Answers
SOURCE: arcoair central heat /air conditioning unit
The blower motor kicks on when there has been a 24 volt control failure.
This usually means that a limit switch has tripped.
Most likely that would be a high temp limit switch or a rollout switch.
First, make sure the filters are clean. and the evap coil is clean. If eaither are dirty/clogged, it will partially block airflow, causing the furnace to overheat, causing the high temp limit to trip.
A rollout switch typically trips for three reasons.
1 flame rollout into the burner compartment due to poor airflow.
2 overheating af teh metal plate the rollout is mounted to, due to dirty, old, rusted components.
3 a bad limit switch.
If your unit has an LED light, count the flashes and it will hepl popint out the problem.
(locate the wiring diagram/flash code list, and correspond the flash count, with the code.)
First, check filters.
Posted on Jan 14, 2009
  • 1214 Answers
SOURCE: rheem heat pump. blower will not turn off
The fans are set to delay for 60-90 seconds to remove all heat from the heat exchanger/heater elements.
If the fan runs any longer than 3-4 minutes after the Emergency Heat shuts off, you may have a bad sequencing relay in the air handler.
Posted on Jan 27, 2009
meBNme
  • 334 Answers
SOURCE: Bad sequencer or fan relay?
does ANYTHING come on when set to heat?
Posted on Mar 06, 2009
hiltonjug
  • 612 Answers
SOURCE: I have a hunter programmable thermostat model
Make sure you do not have a jumper between the red and the white. Also make sure the wire is not hanging out from behind the screws. If the heat stayes on no matter what you do. The red wire has to be touching the white somewhere.
The red is your 24v supply to the thermostat
The white is what sends the 24v to the heat side of unit.
Just a thought. If the thermostat has a O/B pin or switch on the back. Make sure it's on O. It should only be ob B if it's a Trane, American Standard or Payne.
Posted on Oct 16, 2009
  • 674 Answers
SOURCE: Carrier 6 wire, installed programmable hunter ther...
Is this a heat pump? Look in the thermostat. You should have something like the following.
Red wire to R terminal
Green wire to G terminal
Yellow wire to Y terminal
White wire to W or W1
Blue or Orange wire to the O or B terminal
Brown wire to C terminal.
Let me know what you have in the thermostat. The wire colors are not always the same.
Posted on May 23, 2010
Is the wiring for my old tstat (hunter 44155c capatible with your honeywell rth6500?
Of course it is. Turn power off to furnace, take pictures of wiring, and install new. Possibly some settings may need adjusted but should be good to go. Good Luck!!
Apr 29, 2017 | Honeywell Heating & Cooling
Furnace will not turn on even after the thermostat is programed. Thermostat is a Hunter 44155c
5 a. Check the Heat/Cool function switch to ensure it is set to the desired position. 5 b. Wait. There may be as much as a 4-minute delay before the system turns on or off to protect the compressor. 5 c. Check the circuit breakers and switches to ensure there is enough power to the system. 5 d. Replace the batteries. 5 e. If applicable, make sure the furnace blower door is closed properly. 5 f. If your system has 4 wires, ensure the jumper wire is installed between the RC and RH terminals.
Feb 03, 2015 | Hunter Dryers
The furnace wont turn on even though it says it is
not all digital thermostats are compatible with the manufacturers circuit control boards in the furnace. Hunter has had this problem several years ago. Other than that you may have miss wired the unit. usually the furnace is used as backup heat (during defrost) or emergency heat if your heat pump konks out. Are you switching to emergency heat for a furnace call?
Nov 24, 2009 | Hunter Fan Company 5/1/1 Programmable...
I have a hunter programmable thermostat model #44155c and Im trying to wire it to my goodman furnace. Its a 7 wire system with a white,yellow,red,green,brown,blue, and orange wire. The ac works fine but...
Oct 16, 2009 | LG LSC183VMA Split System Air Conditioner
Changing a White-Rodgers 1F56-444 to a Hunter 44155c digital.
The W- terminal is for the HEAT RELAY.
Connect the brown and white wire to the WB terminal which is heat relay of the Hunter thermostat.
Aug 09, 2009 | Hunter Fan Company 5/1/1 Programmable...
Switching old thermostat to Hunter thermostat model 44155c
By describing the wires from your new thermostat and your old one, it sounds like your new thermostat is not compatible with your system. If you have seven wires now, then you more than likely have a heat pump system and you have to get a thermostat that is compatible with this type of system. Then you will have the connections you need.
Jul 11, 2009 | Hunter Fan Company 5/1/1 Programmable...
Trouble Installing Hunter Brand Thermostat
on the back of the packaging for the HUNTER MODEL 44155C it states that it is not compatible with heat pumps
Mar 01, 2009 | Honeywell Programmable Thermostat Heater
Air and heat have both been running on Hunter 44155C
There should be a switch on the thermostat.
AC-OFF-HEAT
And another switch
FAN ON-OFF-AUTO
Normally, you just set it for heat or AC and set the fan for auto. If it isn't wired correctly, the switches won't make any difference. It will either run all of the time or not at all.
Feb 17, 2009 | Hunter Fan Company 5/1/1 Programmable...
3 Month baby and need help hooking up thermostat ASAP
The wire colours mean nothing. If your old one didn't have letters or you already disconnected it, you will have to go to the furnace. Under one of the panels there will be a control board to which the thermostat wires connect and this might have the letters printed on it. Trace them back and connect them appropriately.
If you have a furnace that is like mine (a single-stage natural gas one), chances are that R is +24V, C is common, W is heat call, and G is the blower. Y is generally cooling. The furnace could be turned on by connecting R, W, and G together, I suppose, if the above doesn't work... but it won't shut off automatically.
Jan 25, 2009 | Hunter Fan Company 5/1/1 Programmable...
Heating & Cooling Logo
82 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
