Question about Kenmore 62622 Microwave Oven
Power outage now microwave won't work
Just had a power outage due to a blizzard. Have a Kenmore Over the range microwave model #721.62622. Tried plugging and unplugging , checked the wall socket it is good,left it unplugged over night then plugged it back in, still nothing, not even a light....giude says nothing...Can you help???
  • redwolf_id Nov 08, 2008
    Thanks That was it. Checked it all out... and the part is on order should have it tuesday morning...
  • albbbn Nov 15, 2008
    microwave stopped heating
    Scholar:
  • 112 Answers
Most likely blew internal fuse. Pull the top/side cover off and check the line fuse. It should be behind the control panel in that area.
Posted on Nov 08, 2008
My Kenmore elite microwave model 401.88523011 has lost power. The electrical outlet still has power to it. Is there an internal fuse or circuit breaker that may be causing the power outage?
Your microwave has an internal fuse. Usually 10 to 20 amp. You can pick some up at home depot or radio shack. Make sure you get the same amps and volts as the original fuse. Will be printed on your microwave some where usually. And if its one that is part of a double oven deal make sure that you check you're circuit breakers for the kitchen. Good luck.
Dec 16, 2014 | Kenmore Microwave Ovens
Over range microwave model jvm1650wb008 fan works nothing else does
Check to see if circuit breaker is tripped in the electrical panel, or if it is connected to a ground fault outlet, it may have tripped. Sometimes there is one ground fault outlet serving others in series in the kitchen.
Nov 25, 2011 | GE Microwave Ovens
Kenmore over the range microwave oven model 721.80413500 keypad just stopped working. No response when pressing any button, even the light and fan button. Microwave was working fine minutes before.
80% of power problems are caused by ceramic fuse locted under microwave cabnet.Use a tester to see if you have continuity.You may just need a fuse.
Jan 29, 2011 | Kenmore Microwave Ovens
We recently had a power outage & my Maytag Microwave model #CME90108BAE is the only appliance that will not turn on. Is there a fuse with this model?
the fuse is usually mounted inside the unit on the same side as the control panel near the back end where the power cord is.......the cover must be removed to get access to it.
Jun 25, 2010 | Maytag 2.0 Cu. Ft. Over-the-Range...
Kenmore Over the Range 1000 watt Microwave with no power.
I have the same problem now did you come up with anything for this model
Jan 05, 2010 | Kenmore Microwave Ovens
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
I have an JVM 1630,31 it stopped working after a power outage the house got cold and I turned the stovetop on for 5 minutes did I burn something out or was it because of the power outage? I replaced the...
Below refers to the manuals which all contain the wiring diagram.
Microwaves:
 Inside the actual case. It is not consumer accessible. Over-the-range models have the manual behind the grille or control panel.
http://www.geappliances.com/service_and_support/faqs/
Dec 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Various buttons on Kenmore Microwave Oven Model: 87133 doesn't work
On some models hitting popcorn will make the microwave come on for like 2-1/2 Min's.....then shut off....Maybe yours is like that...It's also on high power
Dec 07, 2017 | Microwave Ovens
Microwave
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
Then let us know if the hard reset does not fix it.
But please reply back with your full model number so we can help you.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Sep 15, 2008 | Kenmore 63672 Convection/Microwave Oven
Kenmore Microwave 63252
Microwaves use a special ceramic fuse that has probably been popped by the outage. You have to take the cover off and it looks just like the regular cylindrical glass fuse except this one is white instead of clear. I think radio shack has them. Hopefully the fuse stopped the power surge before it got the front panel controls.
Dec 31, 2007 | Kenmore 63252 Microwave Oven
Kenmore 62622 Microwave Oven Logo
433 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
