Question about Garmin Rino 530 GPS Receiver
Compass on Rino530 "Sight and Go" problem
I just purchesed this unit and on the compass page, I pull the menu down and the option for sight and go seems to be disabled. I cant find any where in the unit to enable this feature?? Any Ideas. Thanks, Kenny
I would make sure the compass is turned on. When it is off navigation tools are hard to use.
Posted on Jan 22, 2009
What is difference between prismatic and surveyor compass
There is the explanation from Wikipedia. Hope this helps. A surveyor's compass is a specialized compass made to accurately measure heading of landmarks and measure horizontal angles to help with map making. These were already in common use by the early 18th century and are described in the 1728 Cyclopaedia. The bearing compass was steadily reduced in size and weight to increase portability, resulting in a model that could be carried and operated in one hand. In 1885, a patent was granted for a hand compass fitted with a viewing prism and lens that enabled the user to accurately sight the heading of geographical landmarks, thus creating the prismatic compass.
May 22, 2013 | Cars & Trucks
Are usually compass adjusters certified in the states?
With no your United States Adjusters abilities to mend your region via several type of sight bearings, next proceed to a brand new list of factors, after which a third to evaluate your own lessons along with compass, then you could go to a compass maker "who is actually certified along with insured" and possess your own compass looked at along with swung for your boat. I'm unsure they'll carry out the task if your compass seriously isn't created by them. in the area we have now Ritchie Nave who I have generally applied along with who We employed in your military services ahead on-board along with approve your deckle's perform. (We would as well as the maker did) it is generally particularly cost for the substantial boat. (And which is taking out your underway expenses)I am sure the different manufacturer's have got related programs, but if you navigate to the web page down below along with verify your assistance area you will discover PEOPLE along with Nations to obtain your own compass looked at United States Adjusters.
Nov 29, 2012 | Samsung SGH-D500 Smartphone
My detector is in compass mode. how do i put it in highway mode?
Press the Menu button and the unit should show "COMBO" if it does then the Radar and compass is turned on. If it only shows "COMPASS" then press the dark or City button to have the "COMBO" displayed. Then wait a few seconds and the unit will exit menu and save your setting.
Dec 15, 2010 | XTR695 Radar Detector
Compass reading on GPS 60cSx about 30 degrees too high
Calibrate the compass (Main menu --> Setup --> Calibration --> Compass), follow the instructions on the screen.
Also, see page 50 of the manual.
Calibration must be done outside - stay clear of any large metallic object (e.g. car).
Mar 11, 2010 | Garmin GPSMAP 60CSx GPS Receiver
I just purchased a Garmin Etrex Summit GPS receiver. The function that I most need is the Sight 'N Go, but when I access the pointer page options list the Sight 'N Go option is 'greyed out', although the...
It is greyed out when the electronic compass is off. Switch it on by holding down the top right button for 2 seconds. A confirmation message flashes up on the screen.
Apr 19, 2009 | Garmin eTrex Legend GPS Receiver
The orginal compass was deleted.
Tom Tom changed the software (one of the upgrades you get through Tom Tom HOME) to remove most of the compass functions but the manual still refers to setting it up so it appears as a menu item when you first operate the unit but then subsequently disappears if you update the unit software as it did on mine.
It is talked about in some of the Satnav forums but there don't appear to be any solutions.
Sorry that is not much help.
Peter
Mar 05, 2009 | Tomtom ONE 3rd Edition GPS
Reset the cpmpass in the evic system
If you don't have a users manual, you can download it and go to page 177, it explains it there.
Nov 19, 2008 | 2006 Chrysler Pacifica
Etrex vista cx
Hi, the DOT (Direction Of Travel) arrow will only appear on the Compass page when you are navigating.
  1. Go to the 'Main Menu'
  2. Select 'Find'
  3. Select 'Waypoints'
  4. Select a waypoint
  5. Select the 'Go TO' button
Once you are on the Compass page you should have the DOT arrow as long as you have a sat lock.
Jun 22, 2008 | Garmin eTrex GPS Receiver
Garmin HCx GPS unit
The Vista HCx has an electronic compass. You don't need to be moving for it to work, but you do need to calibrate it. To calibrate the compass:
  1. Go to the Main Menu
  2. Select Setup
  3. Select Calibration
  4. You will be asked "Which Sensor Would You Like To Calibrate", select Compass
  5. You will see a page that says "To Calibrate Compass: Slowly Turn Two Full Circles In The Same Direction While Holding The Unit Level", select Enter and do this.
You need to hold the unit level for the Magnetic Compass to work correctly. The specs for a properly calibrated compass are +/- 5°
May 15, 2008 | Garmin eTrex Vista HCx Handheld GPS...
Sight n go as described on page 16
Make sure you are outside with a good bunch of satellite and it should work.
If not go to the compass page and restore defaults.
Calibrate your compass if you have one,
Mar 24, 2008 | Garmin eTrex Summit GPS Receiver
Garmin Rino 530 GPS Receiver Logo
95 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
