Question about Panasonic KX TC901W Cordless Phone (KX-TC901-W)
Handset doesn't turn on; press a button, beeps and turns off
My fully charged (with new battery - only 3 months old) phone stopped working. I think I was playing with the channels to see if I could get better reception... did I accidently press a security lock or something? If I press any button and then it turns the on/off lite on (no dial tone), flashes about 10 times, beeps back three times and turns off. I tried it in other jacks and does the same thing.
From a different brand portable phone - - it worked for me! "If you experience difficulty with placing/receiving calls, a lost security code may be the problem. The handset cannot communicate with the base. Unplug AC adapter. Disconnect handset battery for 10 seconds. Reseat the battery and then place in base. Replug AC adapter."
Posted on Oct 22, 2006
My CL80101 will not register, what to do?
1. When the new handset says "Connecting..." and goes
nowhere else, enter *331734 [menu] and it will soon
beep and display "Not registered"
2. To register the new handset to your base: on the base
press the "Handset Locator" button and hold it until the
"in use" light comes on ( ~ 4 seconds ), then release the
button and set the new handset into the base phone
cradle. After ~ 30 seconds it will beep and display
its "Handset #" (next in sequence).
3: Note: the base handles a maximum of 12 handsets.
If your system was fully populated ( ie, a handset is
already # 12 ) you will have to clear all the handsets
from the base and re-register them all in sequence.
( it is the only way to 'rescue' the places occupied
by the lost handsets ).
To clear the base of all registrations:
1. Press and hold the the "Handset Locator" button
until the "in use" light lights and then starts to blink
( ~ 10 seconds ), release the button --
then press it again briefly while the "in use" light
is still blinking.
2. The base will beep and all handsets will display
"Not Registered"
3. Follow the instructions above for each handset
in turn: press "Handset Locator" ~ 4sec
( in-use light on ), set handset into the base
cradle, etc.
The manual is available from: www.manualslib.com
but does not fully describe these procedures.
Good luck !
Apr 21, 2016 | Lands Phones
How do I register new handset for AT&T cordless phone el51359
1. To de-register the orphaned handsets from their old base:
When the orphaned handset says "Connecting..."
and it will soon beep and display "Not registered"
press the "Handset Locator" button on the base and hold
it until the "in use" light comes on ( ~ 4 seconds ),
then release the button and set the new handset into
the base phone cradle. After ~ 30 seconds it will beep
and display "Handset #" (next in sequence).
is still blinking.
2. The base will beep and all handsets that were registered
will display "Not Registered"
in turn to re-register them:
press "Handset Locator" ~ 4sec ( in-use light on ),
set handset into the base cradle, etc.
Good luck !
Dec 30, 2015 | AT&T Lands Phones
How to register additional handset for AT&T EL52300
Easy to do, even if the new handset is used & orphaned from
its original base...simply de-register it from the old base and
re-register it to your base.
1. To de-register the orphaned handset from the old base:
When the orphaned handset says "Connecting..." or "Out of..."
is still blinking.
Good luck !
Mar 04, 2015 | AT&T El52300 Cordless Phone
At&T EL52300--one phone reads 'out of range-move closer to base.' I did--it doesn't help. Battery OK---What do I do?
It appears that the one handset has become orphaned and
must be de-registered and then re-registered.
is still blinking.
Good luck !
Oct 17, 2014 | AT&T El52300 Cordless Phone
Deregister procedure for at&t el52400 handsets
is still blinking.
Good luck !
Mar 21, 2013 | AT&T Lands Phones
Base el5200 will not reconize new hand set
To deregister the new handsets from their old bases and re-register
them to your base, try this for each new handset...
1. When the new handset says "Connecting..." and goes nowhere
else, enter *331734 [menu] and it will soon beep and display
"Not registered"
2. To register the new handset to your base: on the base press
the "Handset Locator" button and hold it until the "in use" light
comes on ( ~ 4 seconds ), then release the button and set the
new handset into the base phone cradle. After ~ 30 seconds
it will beep and display its "Handset #" (next in sequence).
3: Note: the base has a limit to how many handsets it can handle,
I believe it is five handsets maximum for the EL52300.
If your system was fully populated ( ie, a handset is already # 5 )
you will have to clear all the handsets from the base and
re-register them in sequence ( it is the only way to 'rescue' the
places occupied by the lost handsets ).
1. Press and hold the the "Handset Locator" button until the
"in use" light lights and then starts to blink ( ~ 10 seconds ),
release the button -- then press it again briefly while the "in use"
light is still blinking.
"Not Registered"
3. Follow the instructions above for each handset in turn: press
"Handset Locator" ~ 4sec ( in-use light on ), set handset into
but does not describe these procedures.
Good luck !
Mar 01, 2013 | AT&T ATT EL52500 DECT 6.0 5-Handset...
Phone says no link to base reconnect to mainbase ac addapter
The instructions worked after the additional KX-TGA402N handset was fully charged and I kept pressing the menu/ok button of the additional handset to advance from initial settings to the handset registration mode.
How do register an optional accessory handset to my existing main base...
Feb 08, 2013 | Panasonic KX-TGA402N 3 Pack KX TGA402N 3...
Uniden xdect 7015 won't turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Jul 28, 2012 | Uniden DECT 6.0 Cordless Telephone...
Out of range or no pwr at base
It sounds like the handset has "lost" its registration with the
base ( or a replacement handset is being introduced ? )
Either way, the handset displaying "Out of range..." is now
orphaned and must be deregistered and then re-registered
to the new/current base.
enter *331734# (menu)
is still blinking.
Good luck !
Oct 14, 2011 | AT&T TL32100 Cordless Phone
Unable to register, not asking for password
See below for complete instructions but think you have missed out part 2......
Reregister the handset or add additional handsets.
1. Remove all handsets form charging or Main base unit.
2. On on Main base unit, press and hold Page button for 10 seconds until beep. ( Not paging beep )
3. On 'unregistered' handset press and hold Redial & Calls buttons ( Top left and top right ) until 'bs-' appears.
4. Enter handset number ( eg: bs-1 ) then the pin number( could be 0000 but check your manual ).
Cheers
Monty
Feb 16, 2008 | British Telecom Freestyle 2200 Trio...
Panasonic KX TC901W Cordless Phone (KX-TC901-W) Logo
151 people viewed this question
Top Panasonic Lands Phones Experts
Henk de Ruiter
Henk de Ruiter
Marvin
Marvin
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
