Question about RCA D61W130 61" Rear Projection Television
Rca scenium turns off and on
I have an RCA Scenium D61W136D. It is 2 1/2 yrs old and it has just started turning off and on by itself. We will be watching it and then it makes a flicker and a "popping/static" noise and picture goes off, then the power light goes off and then the power and picture come back on and sometimes it continues this cycle or it may stay on for a while and not do it again for a few hours or until the next day. The tv keeps automatically turning off every 5 minutes. It is a RCA Scenium (D61W130). Is there a remote control code to fix this?
  • 2 more comments
  • david8019 Nov 10, 2008
    I have an RCA Scenium model # D40W135D with the same problem as described. The unit will operate normally then shut off and power up, the cycle repeats. Any assistance would be helpful.
  • gannonb Nov 15, 2008
    same exact problem
  • mswartz1 Nov 22, 2008
    I have the same tv with the same problem. No solution yet, sorry.
  • thistle7967 Feb 06, 2009
    I also have D61W130 61In rear projection. I allso turns its self off and on by
    its self and is not watchable. I had it repaired 7months ago they replaced a
    board. Well now it is doing it all over again. my tv is only 3 1/2 years old
I wish I had the idea to install a cooling fan, a local repair shop fixed mine by replacing a power supply component, cost $575 including sales tax. I suspect that a cooling fan would increase the life of the power supply, I will install one!
Posted on Dec 04, 2008
I had the same problem with mine. It was overheating. I installed a small cpu cooling fan on the back of the unit. No problems since. Good luck.
Posted on Nov 29, 2008
61"RCA Scenium modle number d61w136d When turning
You are on the right track, if the lamp is not lighting bright enough it could do this exact thing, the three tries is standard on RCA products, called the 3 strikes and your out---set will try 3 times to make it on and then shut down.
The color wheel while possible usually makes a high pitched fan like sound and with lamp out you should be able to see it to know if missing parts of the wheel or shattered.
12_18_2012_8_04_57_pm.jpgtypical color wheel.
Dec 18, 2012 | Televison & Video
RCA Scenium 52 DLP
you should take it to a tv repair shop to look it over, they charge $50 and they will tell you want the problem is.
Dec 17, 2007 | RCA Scenium D40W20 40" Rear Projection...
My 40 inch rca scenium will turn off for a few seconds and then turn back on all by itself. When it first started it would only happen once and a while now it will happen up 4 times in an hour. Any help...
First try cleaning front Panel contact switches if cleaning them does not work then replace all 7 of them. Call Mats 1-800-628-1118 contacts are your Off/on ch- ch+ vol- vol+ menu button
Nov 22, 2009 | RCA Scenium D40W20 40" Rear Projection...
The humming noise on my rca scenium starts just a
If this is a DLP set, which I suspect it need a new color wheel. Common problem for these sets. If you don't have an extended service plan, about a 300--400 fix, in home.
Oct 09, 2009 | RCA Scenium HD65W20 65" Rear Projection...
RCA Scenium
I had the problem myself with my Scenium, the TV has a prblom with the circuitry and only fix is through an authorized RCA repare facility. Hope its fixed for you soon, awesome tv.
Rate plz
Sep 15, 2008 | RCA Scenium HDLP61W151 61 in. HD-Ready...
RCA Scenium HTV won't turn on
My tv is about not even 3 years old, the bulb was already replaced once and now the tv will not turn on, we replaced the bulb again, but no change... The blue lights come on and flash but eventually turn off.
Jul 14, 2008 | RCA Scenium M50WH187 50" HDTV
RCA model# D61W136D scenium
Sounds like the high voltage transformer is bad. Best bet is to call a service shop. I wouldn't keep watching the set, as this will just cause more damage.
Sep 03, 2007 | RCA D61W136D 61 in. TV/DVD Combo
Rca scenium
you are having a problem in your power supply, standby power supply where the microchip is situated take the set to a tech to have it repair.good luck.
Mar 29, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
RCA D61W130 61" Rear Projection Television Logo
1,088 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
