Question about Bose 901 VI Main / Stereo Speaker
Bose 901 repair...
I'm not sure which series I have, but I have a set of 901s. One of them has what appears to be a short in the wiring somewhere, and I need to take a look at the wiring between the diodes and the drivers. I have had liitle success in finding a guide for accessing that wiring. Is it possable without disturbing the vacume?
    Problem Solver:
  • 9 Answers
Bose 901s series 1-6 are all wired in the same way. that is nine one ohm full range drivers wired in series to produce around 8 or 9 ohms. No way it can be a short, think of the old christmas lights that were wired in series , one light went out, they all went out. I would check the wiring first to make sure no loose connections exist. The only way to access the wiring is to remove each driver from the cabinet. If all wires are intact, You may have a damaged driver. A simple test with a ohm meter will tell you. set to lowest ohm setting, each driver should read 1 ohm. If your speakers dont have the air tubes in back, you have series1 or 2 removing the drivers will not affect the vaccum, just replace the gasket material around the drivers.
Posted on Jan 07, 2009
I have a Bose Acoustimass 6 Series III the receiver is Yamaha 3066, this system is a 5.1 surround sound. Then I bought a pair of Bose 901 Series VI Direct/Reflective speaker system with active equaliz
The setup is possible, but with several compromises. First off, to use the active equalizer, you'll need to insert this into one of the 2 channel AV channels limiting your listening with the equalizer to stereo only. The acoustimass subwoofer acts a driver/power regulator for the little cube speakers. It probably will not be able to drive the 901s at the correct level when attached to the Acoustimass unit as front left/right speakers. You could try running a dedicated set of speaker leads to the 901s which may work and still allow surround sound, but you'll lose the equalization capability on the 901s.
Jan 21, 2015 | Bose Audio Players & Recorders
Bose 901 equilizer connections to sansui G901DB
It sounds like you may have only the 901 loudspeakers, and not also the companion 901 equalizer box. You must install the 901 equalizer properly--using the tape monitor loop of the G901 receiver. If you of not, the 901 loudspeakers will perform poorly.
Jun 17, 2014 | Bose 901 VI Main / Stereo Speaker
Is there any way to hook up a sonos zp120 to the bose 901's without using an amp
No speakers will run without an amp.
The Active Equalizer must be somehere in the Line Level path between any source and whatever amp is exclusively driving Bose 901's, which makes the ZP120 useless as a networked music delivery system becuase everything IT outputs would be 901-encoded - unless you had 901's in every room.
The Sonos neither knows nor cares what processes are applied to the signal before it arrives through the Line Level inputs but the digital audio/ethernet route lacks anywhere to insert ANY analog processing, so 901's will not work with the ZP120 if the music originates elsewhere.
I'm not so sure how the claimed 55 watts would work out for 901's. I'd take that specification with huge grain of salt as this unit only weighs about 5 lbs.
This link leads to the multi-lingual manual...
http://www.google.com/url?sa=t&source=web&cd=8&sqi=2&ved=0CF4QFjAH&url=http%3A%2F%2Fwww.abt.com%2Fdocuments%2F20166%2FZP120_Setup_Guide.pdf&rct=j&q=sonos%20zp120%20manual&ei=nwV7TpjcLumIsgKfm7WzDQ&usg=AFQjCNEp4MtETHn2IZLqk9fVXn4QPsV9iQ
Sep 21, 2011 | Bose Audio Players & Recorders
I am setting up 4 bose 901s to my home stereo and am unsure how to connect my components to tha 901s active equilizer. the 4 901s are connected to 4 marantz ma 500 amplifiers. the amplifiers are...
Hi -
Sony CD player Red / White RCA - > CD input RCAs on the Arcam.
From the Arcam Preamp Output RCA's, go to the Bose "Input". From the Bose "Output", you need RCA splitters to make them into four outputs to run your amplifier connections.clmrt5000_2.jpgclmrt5000_3.jpg
Jan 15, 2011 | Bose 901 VI Main / Stereo Speaker
I have a set of 901 IV with no equializer, I am
As far as I know, any equalizer will work. There is a guy on here that might know more about them, but I never had the Bose equalizer and I have Bose speakers for 35 years. The guy at the electronic store back then sold us a little equalizer at first, we graduated from that a long time ago, and now on the 3rd or 4th one. No problem, works great, sounds better than ever. Hope this helps.
May 11, 2010 | Bose 901 VI Main / Stereo Speaker
I am looking to upgrade my receiver to an audio video receiver that will hook up to a blue ray via HDMI. I want to use my 901's forthe front speakers. Can you recommend a mid priced (<$600) AVR that...
Good day,
Congrats on your new AV receiver. I own an awesome Yamaha mid-priced AV surround sound system with HDMI, BR disc player, and all that stuff. However, I'm old school and use my 901 Series Vs with a Yamaha RX-797 'two-channel' receiver. To get to the point, I have some bad news. Mid-priced (mp) AVRs, or any AVR for that matter, will not work with 901s because the active equalizer (EQ) requires either a 'tape monitor loop' or 'pre-out / main-in' connection to work properly. You've probably been told the 'why they won't work' by now and it is very true--I know from experience. Most of today's AVRs do not include a 'tape monitor loop' or 'pre-out/main-in connection for the EQ connection, thus, killing all hopes of using 901s. I truly love my 901 Series Vs (since 1985 and still kicking) and love true 'stereo' for playing my music. Again, 901s are useless with today's AVR equipment (as I know it). Just don't let your 901s collect dust--they are truly marvels!! Go with a set of good 'standard' speakers for the AVR system and buy yourself a decent stereo receiver or amp for the 901s--that's how I do it!! I've tried Onkyo, Rotel, Sansui, Poineer amps / receivers--all of them. I can tell you this--for the common, working man/woman, nothing, I mean nothing available can match-up with Bose 901s like a Yamaha RX-797 (200W)--not to mention the sound quality-wow!!! And this unit is very reasonably priced for such awesome performance and high quality build. Just know that all is not lost. You can still use your 901s--I cna't listen to music without mine.
Aug 24, 2009 | Bose 901 VI Main / Stereo Speaker
Bose 901 mk11 no sound . i have checked all connections, swapped speakers over.
since that u swapped l/r speakers already,it might not be ur speakers,if u wanna make sure ur 901s are working,feed a 1.5 v battery power to ur speakers,,(device a connector,piece o wire ,etc) if the speakers makes ticking sound upon contact,u got continuity.now..ur eq..make sure it its working,,(see instruction manual)lastly..confirm that ur amp which is powering ur 901s is emitting sound.(hook up a different speaker)
Apr 14, 2009 | Bose 901 VI Main / Stereo Speaker
Bose 901 equalizer hookup
how do I hook up the bose 901 EQ to a yamaha DSP3090??
Nov 08, 2008 | Bose 901 VI Main / Stereo Speaker
Bose 901 and Tube amp
Yes! When the Bose ~Steve901 first came out that was the amplifier of choice -like the McIntosh classic amps. The 901s have their own equalizer as that speaker system is a phased-array,
Nov 05, 2008 | Bose 901 EQ1915 Home Equalizer
BOSE 901 ACTIVE EQUALIZER
i, trying to hook up a powered subwoofer to my hafler dh 110 and dh 500 running a bose 901 series v active equalizer and series v 901s any info would be appreciated
Mar 15, 2008 | Bose 901 VI Main / Stereo Speaker
Bose 901 VI Main / Stereo Speaker Logo
301 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
