Question about SAMTRON 55V 15" CRT Monitor
Intermittent Display Samtron 45Bn 15 in CRT. Display is intermittent. Steadies up when the 3-pin plug on the backside is manipulated or its underside gently tapped. I want to know how to open it and what to look out for/what repair is possible.
  • 65 Answers
If you have the skill for take off the cover,take off the metal shield and cables until you reach the board,have a 100watt light on,a solder hot iron in one hand and a few rings of tin in the other, obviously take off the plug and left it over a few meters,and waited a few minutes to give some capacitors discharge time,.............it's easy !!! resolder the joints that like dark,mainly see the big transistors,(or IC)that have like rings on it's pins, and thats all. I tell you its easy okay then you have to "rebuild" your monitor back.don't make shorts pleeease.
Posted on Jul 10, 2007
When I switch on my computer, Windows XP start loading and then my Samsung Samtron 45Bn monitor's screen goes blank and the green light keeps flashing every 0.5 secs.
It sounds like your video is set to the wrong resolution. Try booting into safe mode by pressing F12 at the start of the boot process. If you get into windows that way, then adjust the display to something you monitor can display like 1024x728@32bits. The monitor can only display a certain amount of pixels and if you set the video card to high you will lose visual. Hope this helps.
Mar 19, 2011 | SAMTRON 55V 15" CRT Monitor
Shrinking of the display
The DB15 VGA (Video Graphics Array) connector contains however 15 pins in three rows of 5 pins each. These five pins carry the color and synchronisation signals, also a digital I2C interface for two-way communication between the video controller and monitor. The common 15-pin VGA connector found on most video cards, computer monitors, high definition televisions which support VGA connections. The following schematic diagram and table shows respectively connector and pin assignment of DB15 VGA.
Pin
Name
Function
6
7
8
9
10
11
12
13
14
15
RED
GREEN
BLUE
n/c
GND
RED_RTN
GREEN_RTN
BLUE_RTN
VDC
GND
n/c
SDA
HSYNC
VSYNC
SLC
Red Video
Green Video
Blue Video
not connected
Signal Ground
Red Ground
Green Ground
Blue Ground
5 VDC supply (fused)
Signal Ground
not connected
DDC/I2C data
Horizontal Sycn
Vertical Sycn
DDC/I2C Clock
Aug 10, 2009 | SAMTRON 55V 15" CRT Monitor
Samtron 45bn power regular on/off
just replace the FBT FEA830 and check
Feb 11, 2009 | SAMTRON 55V 15" CRT Monitor
Samsung (samtron 5Ei ) rebooting & EMI problem at times it is O.K.
Check 5 v at 7805 output and change Memory IC (EEPROM).
Check SMPS o/p voltages
Sep 20, 2008 | SAMTRON 55V 15" CRT Monitor
Desktop screen is stretched abnormally
please trie and double check the resolution on the screen that its correct.
Also check so you dont use too much Hrz on the monitor/settings.
Jul 14, 2008 | SAMTRON 55V 15" CRT Monitor
Samsung 45bn H output transistot over hating and burning out after a fewminits
THE MOST ECONOMICAL SURE FIRE FIX IS TO REPLACE YOUR MONITOR WITH A QUALITY LCD SCREEN IT UTLIZES 50% less electricty AND RUNs A LOT COOLER.
IF THE HORIZONTAL OUTPUT TRANSISTOR IS BAD MOST LIKEY THE POWER CONTROL BOARD IS GOING BAD you may also have a bad resistor or diode allowing to much current on power control board
Jan 16, 2008 | SAMTRON 55V 15" CRT Monitor
SAMTRON 55V 15" CRT Monitor Logo
100 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
pankaj rautela
pankaj rautela
Richard Lilja
Richard Lilja
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
