Question about Yamaha HTR-5730 Receiver
Reciever power we turn it on and it stays on for a second and then goes off. What could the problem be?
  • 3 Answers
It is going into protection mode. If you feel comfortable with directions look for the service manual and get the codes that are causing the protection error then you can find out how to fix it.
Posted on Dec 05, 2008
Sanyo p42840-06 channel menu comes on then goes off led power stays on.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Dec 07, 2016 | Sanyo Televison & Video
Harmon/Kardon AVR 146 wont stay on when hit power
Probably was damage buy a power surge, Internal damage to (Reciever)
Nov 03, 2012 | Harmon Kardon Harman Kardon Avr 146 5.1...
I have a denon 1909 reciever.
The unit is going into protection mode. This means that a problem was detected and the unit shuts down to prevent further damage. Examine the speaker wires to be sure that they are not crossed. If they seem OK, remove them and attempt to turn on the unit. If the unit behaves the same, then the problem is internal to the receiver. The most common cause of this is shorted output transistors. These are relatively inexpensive. Expect a parts cost in the $30 range. Add in the local labor rate for the entire repair cost. Dan
Jun 06, 2009 | Denon Audio Players & Recorders
Reciever wont stay powered on
I fear that there's no easy fix. Sounds like the power supply or the board which controls it is bad. If you're not an electronics repair person, it'll need to go to a repair shop.
May 02, 2009 | Audio Players & Recorders
Yamaha rx-v461 not working
you have a faulty circuit somewhere, whether its in speaker wiring, or power source, i dont know, but your reciever has an automatic circuit breaker in it for protection, and a faulty circuit will trip it, i would assume it is a power source problem since it wont turn back on, check wiring, plugs and look around, and smell for burnt, or hot components.
Jan 21, 2009 | Yamaha RX-V461 AV Receiver
I have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray...
same equql problem....?????
Can you help?
i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. Can you help? thanks thanks
Dec 21, 2008 | Televison & Video
Will not stay on 11 meter turn it off comes back on 10&12 meter will not transmit am or ssb recieve ok. rci 2995dx.
Hello janetsue, If this radio has the blue or green screen LCD face then this is a default that is built into the radio. It depends on how the radio was "converted" when it was bought new.
It will not key up on 10 or 12 because of the default. A little more info supplied would be real helpful,,,, Let me know, Mechanic
Nov 01, 2008 | Ranger RCI-2995DX Base Scanner
Unit powers up for about two seconds and then dies.
Are all the speakers connected?
Most A/V amps will go into standby if the speakers arent detected
Dec 15, 2007 | Yamaha RX-V730 Receiver
Yamaha HTR-5730 Receiver Logo
121 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
