Question about Sony KP-57WS500 57" Rear Projection Television
Sony kP-57ws500 picture is distorted not right
Hello, I have a 57 inch Sony and the picture is all off. it almost looks like a pictures looks in 3d but with out the glasses. Now it is also distorted all over the pictures, and has curved lines all the way across the picture.
Sterldortch@gmail.com
  • 7 more comments
  • sterldogg Nov 08, 2008
    I would like to try to fix not all the knowledgeable but I like to try. I also had faint blue lines through the picture
  • freckles272 Dec 15, 2008
    picture looks to be in 3-d I have the same t.v. to you think that this will fix the t.v.?
  • miamihafeez Dec 17, 2008
    I have exactly the same problem as explained by this gentleman. The picture is very blurry and colors are all messed up. I tried to adjust the colors by by trying to adjust the six knobs on the bottom behind the front grille
  • momo09 Jan 06, 2009
    I had the same problem on one of my buddies' tv and I installed the new convergence Ic's but the issue is still there. The autofocus will not work either. I heard there is a pico fuse that also fails. Have you heard of this, and do you know the location of the fuse?
  • jpmt98 Apr 09, 2009
    its look 3D and it's suk...
  • traceylsis Apr 10, 2009
    I have the same problem it is like the picture was meant for three-d glasses i need help.
  • Anonymous Apr 22, 2009
    I replaced both the A and D Board and no change in my screen.  Don't know what to do next any help!!??!?!?!?
  • kkrishindat Apr 25, 2009
    Same issue here as well, also the letters such as VOLUME seems arched on the screen. The screen looks like when you skew your PC monitor settings like it is suckin in a little.
  • emmygal220 Apr 25, 2009
    Looks like it's made for 3d and adjusting voltage in front panel didn't work.
  • 10,594 Answers
It calls convergence problem due to failure of convergence output ICs.
If you want to repair it at your own, let me know if you have basic electronics knowledge and little experience to guide you more.
Posted on Nov 08, 2008
  • Shahid Electronics
    Shahid Electronics Nov 08, 2008
    OK, here we go...
    You need to replace IC8001 & IC8002 mounted Heat-Sink on D Board of TV.
    Below exploded view shows where is D Board in TV.
    IC8001 & IC8002 has same part number as follows...
    8-749-019-08 IC STK392-560
    Above ICs are available in Parts Store and TV needs 2 pieces.
    Please becarefull while working in projection TV as has high voltage inside and electric shock risk is always there. You must know good solder work to remove and install convergence ICs.
    Need further help, let me know please.
    Good Luck.
    Solution offered deserve 4 blue-diamonds rating....what do you think?
I did replace a new IC8001 & IC8002 mounted Heat-Sink on D Board of TV. BUT, this problem didnt work for my TV. i still getting 3D screen pictures. then how do i fix this problems. anyone please help.
Posted on Apr 09, 2009
    Hello averyone,
I have a sony color rear videoprojector tv model kp-57ws500 that when i turn it on its blurry and video or dvd word is red blue yellow almost like in triplicate. after about 45 min. it clears up and works...
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 25, 2011 | Sony KP-57WS500 57" Rear Projection...
Tv picture problesm
hello it sound like convergance ic may be the trouble
regards
shaun
Feb 06, 2010 | Sony KP-57WS500 57" Rear Projection...
It seems the picture is getting out of focus or not as clear. i've noticed it today, but it started a couple of weeks ago. any suggestions on how to get the picture clear/
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 29, 2010 | Sony KP-57WS500 57" Rear Projection...
I have a 57" sony kp-57ws500 rear projection t.v.
the tv he mentioned is not plasma or LCD, it's rear projection with tubes.
brad, you'll have to take off the front panel. there are two phillips head screws behind two small round plastic covers, one at each end of the bottom of the speaker covers. remove those, lift the cover slightly, then pull down. be careful because the plugs for the front panel controls don't have much slack. unplug those and set the cover aside.
there is a rectangular cover to the tubes and focus panel. remove that, set it aside and you'll have access to the focus and alignment controls. the white markings on the knobs are factory reference marks. IIRC, the top is the focus and the bottom is the alignment. use a flashlight to check because it's marked.
make the adjustment as necessary to get a clear picture. =)
Jan 07, 2010 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WS500 convergence drift
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 10, 2008 | Sony KP-57WS500 57" Rear Projection...
Color distortion and arched picture
It is problem of failure of convergence ICs or related circuit. Please confirm model number of your TV that is Sony KP-57WS500 to help you out.
It would be nice if you could past TV snap shot here for easy understanding.
Thank you.
Oct 02, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony 57 inch
Hello
there is two STK packs in your TV, this is what controls your convergence,it should be two big IC on big heatsink and number should start with STK- ______,just replace these STK packs and you can order these from matelectronics.com. Parts should be somewhere around $30 and also make sure that resistors around stk packs don't look like they been hot if they look like they been hot just replace them too, and your TV will be working fine.
Thankyou
May 11, 2008 | Sony KP-57WS500 57" Rear Projection...
need to replace both convergence ICs numbers STK392-560 you can get replacements with free instalation instructions with pics so you can do the repair yourself. Heres the link.
http://servicemanuals.vstore.ca/
Apr 20, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
540 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
