Question about Cooler Master Centurion 5
Computer powers off and must be unplugged from wall before it will power up again
I have a Gigabyte motherboard in a CAC-T05-UWI case. Occassionally the computer will power off and refuse to power on again. Unplugging the power cord from the back of the PC and waiting a few moments before reconnecting fixes the problem. The problem is infrequent so its an annoyance rather than a major hassle (so far) but does anyone know just what might be causing this? Thanks in anticipation.
  • Graham Saint Oct 23, 2006
    Hi Sandrew,
    I probably didn't give enough information in my initial post but I'm pretty sure its not a heat problem. There are several fans already in the case and the IDE cables are tucked well out the way. Taking the side panel off makes no difference.
    The real clincher, to me, is that when the problem occurs you can't get the machine to restart by pressing the power button on the front of the case no matter how long you wait (the first time this happened I left the machine overnight before trying again in the morning). But after you've unplugged/replugged the power cord it will come back up straight away.
Hello, gsaint.
You might want to ensure that the CPU is being cooled properly.
If the problem is intermittent, the adhesive might need to be clean off and replaced, although this sort of problem typically happens when a motherborard is at least a couple of years old.
Posted on Nov 30, 2007
I had similar problems with my Gigabyte mobo--the board was unfortunately toasted somewhere within--it cost me my RAM (2 gig), and fortunately only the board got the damage beside that. You're lucky, the mobo is shutting you down--mine didn't. It also took Gigabye 5 months to get a new mobo to me-I built a new computer in the mean time--the Gigabye mobo sits in storage--I am afraid to try it again. I hope this helps, Lyla
Posted on Sep 09, 2007
    President:
  • 2,961 Answers
Please check your processors temperature (h/w monitor, 'Hardware Monitor') in the bios settings, and refer to your mobo manual, sounds like an overheating problem. Try running your pc with the side off, for a few days see if it occurs again, check fans for being clogged up with dust, if overheating is the problem,check ide cables are'nt blocking air flow and fit a case fan, very cheap to buy
Posted on Oct 23, 2006
4 Suggested Answers
  • 13433 Answers
SOURCE: BRAND,MODEL NUMBER,FEATURES AND COST OF POWER
Hey,
this case will fit any ATX powersupply
for example this one http://www.newegg.com/Product/Product.aspx?Item=N82E16817182044
Let me know if you need anything else.
Thanks,
Ekse
Posted on Feb 21, 2009
  • 54 Answers
SOURCE: brand,model number,features and cost of power
What is your question?
Posted on Feb 23, 2009
DickCanFixIt
  • 948 Answers
SOURCE: power supply compatible with cooler master cac-t05-uw
Power supplies are not matched to a case. Any one you buy will fit in the case. You need to make sure it has the correct power capacity and plugs for your motherboard, video card, and anything else you will have plugged into it.
Posted on Mar 27, 2009
GIGABYTES GA-965P-DS3 motherboard cost features
Ref:
GIGABYTE Motherboard Socket 775 GA 965P DS3 rev 1 0
May want to look on the board to find out what version it is and select the right one in the link.
Jul 07, 2014 | Cooler Master (CAC-T05-UW) (CAC-T05-UWA)...
Wat power supply is compatibe wit a cooler master cac-t05-uw
It all depends on the equipment you intend to put in the case to meet your power requirements.
Sep 04, 2011 | Cooler Master (CAC-T05-UW) (CAC-T05-UWA)...
Power supply compatible with CAC-T05-UW
It uses standard ATX power supplies, get the best you can afford . Just make sure it has enough power for the components you are going to put in this case.
Aug 04, 2011 | Cooler Master (CAC-T05-UW) (CAC-T05-UWA)...
Power supply compatible for cooler master cac-t05-uw
Most brands like HEC, Gigabyte, FPS, Cooler Master, Enermax, Silver stone, Corsair, etc. Will fit in your casing but you must consider your hardware before buying a power supply.
Most power supplies that are priced below $30 generally do not meet the power requirements of the latest processors. To make matters worse, the components used in them are of inferior quality and more likely to fail over time. While they may power the computer system, inconsistencies in the power to the components will tend to cause instability and damage to the computer.
Consider the ff:
ATX12V Compliant
PC Power Supply Wattage
Silent PC Power Supplies
Power Efficiency
Having the right number of connectors
PSU Wattage Calculator Asus
PSU Wattage Calculator extreme
Hopefully this helps..
Thank you for posting..
Jul 08, 2011 | Cooler Master (CAC-T05-UW) (CAC-T05-UWA)...
I have already own a cooler master cac-t05-uw case,gigabyte ga-965p-ds3 motherboard, and seagate st3400620as hard disk drive.. I'm looking for: power supply, cpu, cooling device, ram, and video adapter...
Hi, welcome to FixYa.
Currently, your motherboard only support Intel Core 2 family (not the newest Core i, even the Core i Sandy Bridge series). Here's the list of the supported CPU that your motherboard support.
http://www.gigabyte.com/support-downloads/cpu-support-popup.aspx?pid=2456
For the memory, I recommend you that a very good brand such Team Elite, Corsair, or else. Here's the list of supported memory:
http://download.gigabyte.asia/FileList/Memory/motherboard_memory_ga-965p-ds3_3.3.pdf
For power supply, you can take ThermalTake or CoolerMaster power supply, I recommend you take at least 500W as your power supply.
As for the VGA (video), it's up to your need, but I recommend you to take HIS as their cooling devices is very good.
Sorry I can't give you the model number, there's a lot of it.
Thanks for using FixYa!
Jul 06, 2011 | Cooler Master CAC-T05-UW ATX Mid-Tower...
Which power supply is compartible with cooler master CAC-T05-UW
Hello!
EVERY standard size (150mm width, 86mm height) ATX power supply can be used with this case!
Depending on your motherboard, you should check, though, that the power supply has all the power connctors needed.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Best regards,
Pelu.
Dec 08, 2010 | Cooler Master CAC-T05-UW ATX Mid-Tower...
Need a power supply for the cooler master CAC-T05-UW
I've used Cooler Master, Rosewill, Antec without fail. Warranty 2+yrs, power efficiencies >75%.
Jan 07, 2010 | Cooler Master (CAC-T05-UW) (CAC-T05-UWA)...
Power supply compatible with cooler master cac-t05-uw
Mar 27, 2009 | Cooler Master CAC-T05-UW ATX Mid-Tower...
Cooler Master Centurion 5 Logo
193 people viewed this question
Top Cooler Master Computers & Internet Experts
Computer Links
Daniel
Daniel
Tom Chichester
Are you a Cooler Master Computer and Internet Expert? Answer questions, earn points and help others
