Question about Dell Wireless Keyboard Optical Mouse w0147
Hav Targus USB cabled Mouse (Model AMU2604EUK )connected to DEL Inspiron M1530 have to pull out and reconnect mouse to activate when Pc is in sleep or rebooted .... is there a fix ?
    Genius:
  • Dell Master
  • 1,102 Answers
Check your mouse settings in control panel
make sure they are set correct
Posted on Jan 26, 2009
Il mio pc non mi installa i driver del mouse veramente nessun progamma come mai?
Se il tuo mouse ? stato fornito con un disco di installazione, allora prima di tutto scollega il mouse, fai un reboot del PC (Spegni e riaccendi), prova a installare i programmi forniti con il CD e poi collega il mouse solo alla fine (Eventualmente prova su una porta USB differente).
Fammi sapere se vedi dei miglioramenti.
Saluti
Mar 13, 2011 | Targus PAWM001U Mouse
My brother and I have the AWE01us1 chill hub. Initially it worked fine. We have a wireless microsoft mouse and USB adapter is connected to 1 of the 4 USB ports. Occasionally the mouse stops working...
When I typed AWE01us1 chill hub in my search engine I came up with Targus as the manufacturer of the chill hup not the laptop. Before buying products I would read customer rates and comments on the products. My public library has a free link to consumer reports, or Amazon.com has product ratings.
I'm also getting mixed info regarding the mouse, is the mouse wireless, stopped working, and you somehow overrode the wireless with a USB cable and that stopped working. I'm assuming the mouse worked fine before the installation of the chill hub. If you read the reviews on Amazon, I'm seeing other types of USB problems. Try returning the chill hub and purchasing another brand. You may have to call customer support for the laptop. Let me know if this was helpful.
Dec 06, 2010 | Targus Computers & Internet
I have model CE 0560. New batteries are in. Pressed the dricer button which lights up. The redlight on the bottom of the mouse is on and flashing. The controls on the mouse do not respond.
You will need to follow the manufacturers instructions on setting up the mouse. Here is a copy of the instructions for download (Below is a viewable copy). Based on what you indicate, it is possible that the drivers are not loaded for the usb reciever or that one of the installation steps was not done correctly or completely. Please review the instructions and start from the first step.
Here are the instructions:
Targus Wireless RF Mouse USER’S GUIDE Making Your Mobile Life Easier.® Visit our Web site at: www.targus.com Features and specifications are subject to change without notice. © 2004 Targus Group International and Targus, Inc.. 400-0111-001B
System Requirements To use the RF mouse, your computer must meet the following hardware requirements and run one of the operating systems listed below. Hardware • PC with a Pentium® processor or equivalent • USB interface • Mouse • Receiver • 2 AAA batteries • Three inch USB extension cable • Carrying pouch Targus Wireless RF Mouse Operating System • Windows® 98/Me/2000/XP NOTE: The third button and the scrolling wheel only work with the operating systems listed above. If you use the RF mouse with a different operating system, it will lose its enhanced features and function as a standard, twobutton mouse.
Connecting the Mouse Receiver To connect the mouse receiver: 1 Plug the USB receiver into an available USB port on your computer. 2 Your computer’s operating system identifies the receiver and begins installing the default driver. Follow any on-screen procedures to complete the default driver installation. Using the RF Mouse Installing the Batteries 1 If the mouse is on, slide the on/off switch on the bottom of the mouse to the “off” position. 2 Remove the battery cover from the top of the mouse by pressing the battery cover hinge located on the bottom of the mouse and sliding it off. NOTE: The battery cover is also the top cover of the mouse.
Targus Wireless RF Mouse 3 Insert the supplied batteries, making sure that the positive (+) and negative (-) ends of each battery match the polarity indicators inside the battery housing. WARNINGS: When replacing the batteries, you may use alkaline or other heavy-duty NiMH batteries. Never use an alkaline with a NiMH battery in a device. Avoid mixing new and used batteries in a device. 4 Slide the battery cover back into position until it “clicks” firmly into place. 5 Turn on the mouse be sliding the on/off switch on the bottom of the mouse to the “on” position. The optical sensor, located on the bottom of the mouse, glows red. Establishing a Communications Link The RF mouse has 256 identification codes that allow the mouse and its receiver to operate without interference from other radio frequency devices. After your computer detects the USB receiver and the driver software is installed, you must establish a communications link between the mouse and its receiver BEFORE you can use the mouse. To establish this link, you need to set the identification code so that the mouse works properly. To do this, follow the instructions below: Make sure that your computer is turned on and has detected the USB receiver before you establish a communications link. 1 Press and release the link button on the receiver.
Targus Wireless RF Mouse Receiver The USB connector rotates 90 degrees to facilitate easy connection to your computer. The receiver’s status light blinks when the receiver is activated. 2 Press and release the reset button, located on the bottom of the mouse. You are now ready to use the RF mouse. Mouse Power Management To power the mouse on and off, slide the on/off switch at the bottom of the mouse to the desired position. efafd91.jpg
Mouse When power is on, the mouse goes into "sleep mode" after 8 minutes of no use. To activate the mouse, touch the sensor strips on the side with your hand. To save battery power, turn off the mouse while traveling or when you’re not using it. CAUTION: Turning off the mouse will require you to synchronize again the next time you turn it back on. 90° rotation Status light Link button Sensor strips Low battery indicator
Targus Wireless RF Mouse Operating Hints For optimal performance and RF reception: • Place the receiver at least 8 inches (20 cm) away from all electrical devices, such as your monitor, speakers or external storage devices. If necessary, use a three-inch extension cable to keep the receiver away from the computer. Plug the receiver into the extension cable, and the extension cable to the computer. • Avoid using the RF mouse on a metal surface. Metals, such as iron, aluminum or copper, shield the radio frequency transmission and may slow down the mouse’s response time or cause the mouse to fail temporarily. • The RF mouse will enter a suspend mode at the same time your computer does. To activate the mouse, touch the sensor strips on the side of the mouse. • If your computer has a metal case that contains aluminum or magnesium, use the RF mouse to the side. The display panel may interfere with the radio frequency signal if you use the mouse directly in front of the computer. • Never use the RF mouse on a glass or mirrored surface as these surfaces will cause the mouse to fail temporarily. • To maximize battery life, use the RF mouse on a white, or light colored surface. Dark surfaces cause the mouse’s light emitter diode (LED) light to glow brighter, which causes the battery to discharge more rapidly.
Targus Wireless RF Mouse Sleep Mode • The mouse’s sleep mode feature activates after 8 minutes of non-operation. • To wake the mouse from sleep mode, touch the sensor strips on the side of the mouse. • When the battery charge is running low, the battery indicator light at the end of the mouse glows blue.
Targus Wireless RF Mouse Troubleshooting What do I do if the RF mouse does not work? • Make sure that the polarity of the batteries is correct. The positive (+) and negative (-) ends of each battery must match the positive (+) and negative (-) connections in the battery housing. • Check that the receiver’s USB connector is firmly attached to the USB port on your computer. • Verify that the device drivers are installed. • Make sure you have established a radio link between the mouse and its receiver. See “Establishing a Communications Link” in sections above
Feb 08, 2010 | Targus Wireless Optical Notebook Mouse...
Targus mouse not recognized
What is the OS of your computer? This Targus mouse would work with Win 98, Win 2000 and Win XP. Vista was not mentioned. And if you are running Windows Vista for you laptop, then that could be the reason why it was not recognized by the computer.
Is this the wireless optical mouse? If yes, you need to follow the steps below to isolate the problem:
1. Connect the USB receiver into different USB ports of the computer.
2. Replace the batteries with the fresh ones.
3. Try connecting the mouse into different computer to see if you've got a defective mouse.
If you've tried everything and got the same problem, you may need to refer to the manufacturer, because I'm not sure if this mouse is a Plug-n-Play device or if it needs a driver.
Have a great day!
May 26, 2009 | Targus PAWM001U Mouse
Model PAKP003 Won't work
You will need to reset the id code on the the receiver as well as the device. Here is the direct link to the manual with the detailed instructions (please, cut and paste to your browser):
http://www.targus.com/us/Downloads/PAKP003_UG.pdf
The Targus link to the product itself:
http://www.targus.com/us/drivers_manuals.asp?SKU=PAKP003U
Good luck
Feb 03, 2009 | Targus PAWM001U Mouse
How to set up and use targus wireless computer mouse model#amw26
Under the mouse there should be a usb stick attached to the mouse which most likely should slide out from the mouse. It also appears that the plastic cover behind the two buttons (this cover has targus written on it) Should come off. After you remove the usb stick there might be a button somewhere on the bottom of the mouse that you should be able to press to get the battery cover to pop up. Then you should be able to pull up on the battery cover and remove it from the mouse. This mouse takes two AA batteries. Once the batteries are installed then plug the usb stick into any of the usb ports on the computer. The computer should recognize the drivers for this mouse (if you are using Windows 2000, XP, Vista, or Mac OS X [or higher]). If the drivers are not immediately recognized then restart your computer and the computer should then recognize the mouse. If this still does not happen then let me know. Also there is software that can be downloaded from the Targus website for the tilt wheel as it has some added capabilities that can be set using this software. The link for that software is here ------> http://www.targus.com/us/product_details.asp?sku=AMW26US
I hope this helps, and enjoy that mouse, it looks pretty nice!
Sep 20, 2008 | Computers & Internet
Help mouse problem
Click Here to download the User's Manual. It may just be going into sleep mode.
The Targus Wireless Optical Notebook Mouse features an ergonomic design with built-in power management allowing for travel or everyday desktop use. The physical on/off switch, combined with a touch sensor for sleep mode, enable optimized power management capabilities. The thumb-size USB receiver with 90-degree swivel provides flexibility in limited workspace. The mouse features sensitive optical technology for increased accuracy and ease of use.
Jul 27, 2008 | Targus Wireless Optical Notebook Mouse...
My usb
No you require the targus usb receiver to use it
Jul 24, 2008 | Targus Wireless Optical Notebook Mouse...
My targus mouse model pawm001
Yeah, I was kind of confused about this too. Apparently, on the base of the mouse, there is a red reset button. Press it, while simultaneously pressing the black reset button on the base of the USB-connected charger. The laser light should become steady after a moment, indicating that the mouse is in sync with the laptop. If the laser is blinking, however, then the mouse is attempting to become synced. You may have to press the reset button multiple times. Hope this helps.
Dec 21, 2007 | Targus PAWM001U Mouse
How do i get my mouse to connect
The power switch is located on the bottom of your mouse. To connect/activate: a) press & release the link button on your receiver. b) press & release the link button located on the bottom of your mouse.
Aug 02, 2007 | Targus (PAWM30Y01UZ) Mouse
Dell Wireless Keyboard Optical Mouse w0147 Logo
172 people viewed this question
Alun Cox
