Question about Intuit QuickBooks Pro 2007 Full Version (299116)
Opening quickbooks recently did a windows update and now my quickbooks won't even open. Went on the website and did the repair of. NET 2.0 SPI and still won't work.
  • rheajane12 Nov 08, 2008
    I tried it but it says there haven't been any changes since that date. It was a week prior to my doing the updates. Now what?
    President:
  • 1,314 Answers
Run a system restore and restore your computer to a time before you did the windows update. If the update caused QB not to open, the restore will remove the update from your computer. To access system restore, click on start, programs, accessories, system tools, system restore...and follow the onscreen instructions.
Thanks and please take a moment to rate as fixya.
Posted on Nov 08, 2008
I am having problems with my QuickBooks Pro 2001 program. It will not update and it will not recognize the drives for a restore.
We would need to know the actual error message it is giving. Sometimes you are dealing with damaged installs, and running Reboot.bat from the program folder will fix it.
Jan 13, 2013 | Intuit QuickBooks Pro 2001 for PC
Quickbooks error code c=343
Solution 1: Update QuickBooks to the latest release.
  1. Update QuickBooks to the most current release.
  2. Try to open QuickBooks.
  3. If you still encounter the error, go to solution 2.
Solution 2: Register the MSXML.dll files.
  1. On your keyboard, press Windows + R to open the Run window.
  2. In the Open field, enter Regsvr32 MSXML3.dll.
  3. Click OK.
  4. If the file is correctly registered you will receive the message: DllRegisterServer in C:\[Windows Folder]\system32\MSXML[Number].dll succeeded
  5. Repeat steps 1-4 but enter Regsvr32 MSXML4.dll for step 2.
  6. Restart QuickBooks.
Solution 3: Reinstall the MSXML.dll files
  1. Open theMicrosoft Core XML Services download page. Download the msxml.msi.
  2. Double-click the msxml.msi icon and follow the on-screen instructions.
  3. Restart QuickBooks.
  4. for more help visit
QuickBooks Technical Support
Jun 26, 2012 | Intuit QuickBooks Pro 2010 Full Version...
UNABLE TO OPEN QUICKBOOKS PRO 2010 I CLICK THE SHORTCUT TO OPEN QUICKBOOKS PRO 2011 AND THE LITTLE LABEL SHOWS SAYING QUICKBOOKS IS OPENING BUT IT SOON GOES AWAY AND QUICKBOOKS DOES NOT OPEN.
This can often indicate damage in the .net framework in windows.
You will probably need to repair the .net frame work, make sure you are logged into windows as an admin, and possibly reinstall quickbooks to resolve this.
Oct 08, 2011 | Intuit QuickBooks Pro 2010 Full Version...
I am getting error codes 6129,0 and 6073, 816 on my quickbooks 2008. What can I do to open the company?
This error can occur when:
  • Data is converted or restored over a network.
  • Several computers are acting as host for the QuickBooks data file.
  • QuickBooks is unable to communicate with the server.
  • There is data damage in your company file.
If the error occurred when you were restoring a company file from a backup or updating a company file to a newer version of QuickBooks over a network:
  1. Copy the backup file (.qbb file extension) or the company file you want to update (.qbw file extension) to a local hard drive.
  2. Restore the backup or update the company file.
  3. Copy the restored or updated company file back to its original location.
If the error occurred when you were trying to open and use a company file:
  1. Update QuickBooks to the most current release on all computers that open the company file.
  2. Close QuickBooks on all the computers with access to this company file.
  3. On the computer you select to host the company file, switch to single-user mode, and then back to multi-user mode:
    1. Open QuickBooks and open the company file.
    2. Choose File > Switch to Single-user Mode.
    3. Choose File > Utilities > Stop Hosting Multi-User Access.
    4. Choose File > Switch to Multi-user Mode.
    5. Choose File > Close Company to close the company file.
  4. On all other computers that will use the company file, stop hosting multi-user access :
    1. Press and hold Ctrl while you open the QuickBooks program and continue pressing Ctrl until QuickBooks opens completely. This opens QuickBooks without opening a company file.
    2. Choose File > Utilities >Stop Hosting Multi-User Access. If that option doesn't appear, the computer is not hosting and no further action is necessary.
    3. Repeat steps 4.a and 4.b for each computer other than the host computer.
  5. Configure the QuickBooks server for multi-user access:
    1. Click the Windows Start button and choose All Programs > QuickBooks > QuickBooks Database Server Manager.
    2. Click the Scan Folders tab.
    3. Click the Add Folder button, select the folder that contains your QuickBooks company file, and click OK. Repeat this step if necessary to add additional company file folders.
    4. Click the Scan button to begin scanning. After the scan is finished, the company files in the scanned folders are configured for multi-user access.
  6. Open the company file in QuickBooks. If you receive the same error message, refer to Settings required for firewalls to make sure your firewall is properly configured to allow QuickBooks access to your company file.
  7. Open the company file in QuickBooks. If you receive the same error message, open a different company file or a sample company file located in one of the folders you scanned with the Database Server Manager.
    • If no company file will open, reboot the host computer and try again.
    • If other company files open without error, the company file generating the error message may be damaged. For more information refer to Verifying and rebuilding QuickBooks company data.
Jun 01, 2010 | Intuit QuickBooks Pro 2008: Windows
Error 1334/ quickbooks pro 2008
Solution 1: If you get the error while launching or opening QuickBooks
Find and open your QuickBooks company file. It has the file extension .qbw.
Double-click the company.qbw file.
Solution 2: If you get the error when updating or repairing QuickBooks
Please see Error: 1334 while repairing or updating QuickBooks for steps to resolve.
Solution 3: If you get the error when installing QuickBooks
Please see Repair or reinstall Microsoft .NET Framework for steps to resolve.
for more help visit
May 17, 2010 | Intuit QuickBooks Pro 2008: Windows
Quickbooks 2010 will not load. The window opens but then disappears. Any hope?
This often indicates a damaged .net framework in windows. Repair the .net, if you have the QB cd, there is a file called .netfix, or download the .net 3.5.1 from microsoft.com, and run the install. It should see the existing .net and ask if you want to repair it.
May 09, 2010 | Intuit QuickBooks Pro 2008: Windows
Cannot open Quik Books 2007
Windows XP:
  1. Uninstall QuickBooks, Microsoft .NET Framework, and Microsoft Visual C++ 2005 Redistributable:
    1. Close QuickBooks.
    2. Click the Windows Start button and select Run.
    3. Enter control in the Open field and click OK.
    4. Double-click Add or Remove Programs.
    5. Right-click your QuickBooks program version and click Change/Remove.
    6. Follow the instructions to Uninstall QuickBooks.
    7. Repeat steps d through f to uninstall Microsoft Visual C++ 2005 Redistributable.
    8. Repeat steps d through f to uninstall Microsoft .NET Framework for your version of QuickBooks:
      • QuickBooks 2008 and 8.0 and later:Microsoft .NET Framework 2.0
      • QuickBooks 2007 and 7.0 and earlier:Microsoft .NET Framework 1.1
  2. Rename the QuickBooks program folder:
    1. Right-click the Windows Start button and select Explore.
    2. Browse to C:\Program Files\Intuit.
    3. Right-click the QuickBooks folder for the version you just uninstalled (for example, QuickBooks 2008) and select Rename.
    4. Enter OLD_ at the beginning of the folder name and press Enter (for example, OLD_QuickBooks2008).
  3. Insert the QuickBooks CD in your CD drive, and follow the instructions to install the program.
  4. Open QuickBooks.
Jul 09, 2009 | Intuit QuickBooks Pro 2007 Full Version...
Cant get rid of Error 15103 Document Viewer
Error 15103 error symptoms can include program lock-ups, slow PC performance, system freezes, shut down and startup problems, and installation errors
uninstall regcure uninstall quickbooks.....run ccleaner and then cold start the pc ...now reinstall quickbooks .....reboot
www.ccleaner.com
good luck
Apr 05, 2009 | Intuit QuickBooks Premier Accountant...
Went to open Quickbooks pro 2008 and received an error code of 80029c4a. It also said there was an error loading type library/DLL. Any solutions? Thanks
Update your Quickbooks, run reboot.bat, restart your computer and then restart Quickbooks
  1. Open the folder containing the reboot.bat file:
  2. Windows Vista: Right-click the QuickBooks icon on your desktop and select Open file location.
  • Window XP:
    1. Right-click the QuickBooks icon on your desktop and select Properties.
    2. Click Find Target.
  1. Double-click the reboot.bat file
Jan 06, 2009 | Intuit QuickBooks Pro 2008: Windows
Quickbooks Pro 2008 Payroll problem
I had to reinstall Quickbooks 2008 on a Windows installation that never had it on there before (virtual machines are handy) and now it works again. I am staying far away from letting it upgrade to latest; that's how my troubles started. I also doubt I will ever shell out money for a more recent version; I upgraded from 2005 to 2008 and it took away the ability to do automatically do IRS 941 forms if you don't pay for monthly payroll services. There has to be better accounting software that doesn't leave users stranded at year-end.
Dec 03, 2008 | Intuit QuickBooks Pro 2008: Windows
Intuit QuickBooks Pro 2007 Full Version (299116) Logo
83 people viewed this question
Top Intuit Computers & Internet Experts
Alun Cox
Chris Larocque
Mike
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
