Question about Lands Phones
Nokia n96, power saver on and i can't change the display brightness, despite taking battery out and turning on again. everytime i go to displaysettings & alter brightness it won't let me. can't find disable power saver anywhere.
  • mattos Feb 27, 2009
    I have exactly the same problem. Phone is stuck in Power Saver mode despite battery being fully charged. Very annoying as backlight goes out after 5 seconds when doing anything!!
  • jokiddys Apr 16, 2009
    I have a N96 and it wont turn on, i have put another bat into it but stil wont go on
Plug the phone charger into phone to start charging, this will deactivate the power saver.
Posted on Mar 18, 2009
  • as89599 Mar 18, 2009
    or press the power button once and press up, there will be option to deactivate power saver
Screen brightness at max but very dark
If it's running on battery power it will dim. Right click on the desktop and choose Display or Personalize. Choose Screen Saver next and then "Change power settings". From there, you can choose screen brightness for running on battery power or wall outlet.
Apr 28, 2015 | Lenovo IdeaPad Computers & Internet
My hp mini 210-1000 boots up well both on battery and adapter but it displays faintly on battery while it display well on power adapter
the problem is that its set in the power saving options. i mean on battery its set to power saver . while on power adapter it changes to hp recomended or high perfomance. So if you want to change it go to the right bottom of your screen and click the battery symbol it should give you the option to 1> change screen brightness 2>more power options. Go to more power options and select "change plan settings" beside the power saver.(not the one beside the other options) and change ur brightness. but its always better to keep it at ur minimum(with what ur comfortable) as its helpful to save battery
Jan 10, 2013 | HP Mini 1000 Netbook
The pc isnot bright and its abit dull
Is this a Desktop, or a Laptop. If it is a laptop, you should click the Battery Icon on the lower left corner of the screen. Once you click that, there should be a few options. They are as follows:
Balanced;
Power Saver;
High Performance.
The Balanced and Power Saver options reduce the brightness of the LCD Screen, as well as it conserves energy while running programs and the like. On "Power Saver", your computer may work slower.
If you want your screen brighter, you can select "High Performance". Also, there is an option to personalize each of the three settings. Simply look below the three options where it displays three blue worded links. Click the one that says "More Power Options". This will take you to another page that displays the three settings and below each setting is an option to Change Plan Settings. Once you click "change plan settings", you can choose precisely how bright you want the screen to be for each setting.
Once you personalize the three settings, you are free to go. Whenever you want to dim the screen you may go back to the battery icon and simply choose between the three modes. Hope this is clear enough. Good Luck! :)
Aug 09, 2010 | Computers & Internet
Computer turns on and boots up , however, the screen is dark
Try going into the control panel and select power options see if there is way to adjust the display brightness or try holding down the "Fn" key and use F7 to increase the brightness
Feb 07, 2010 | Toshiba Satellite A75-S229 Notebook
Phone turns off when Calling out.
There is another way.
Your dad's N96,restarts because of some files is the phone is corrupted and it needs to be formated through software. it might be from images,videos,audios,especially downloads from the internet can cause does damages..
Take it to a repairer to format and restore the memory of the phone and your dad can enjoy his fun again.take care.
Jan 21, 2010 | Nokia N96 Cell Phone
Display issues on the IBM A31
it is done to save power from the battery.
what you can do is to click on Function + <up arrow> key and it will increase the light.
also you can check the power setting:
1. right click on your desktop and go to properties
2. go to Screen Saver
3. click on Power
4. check the settings under "Battery"
Dec 30, 2009 | IBM ThinkPad A31 Notebook
How to remove the shortcut menu in nokia n96i&#1567;&#1567; i really hate it everytime i put on a picture in the background...the menu takes half of the pic view!!!!!!!!!!
Go to settings , there select phone settings.Now go in Display settings.There you will see "Active Desktop".Just turn it off and you will be able to see whole screen clear.
Oct 12, 2009 | Nokia N96 Smartphone
Cant switch off power saver
ya u have 2 go display settings and customize it. in here power saver and customize time as ur wish u can save power.
Jul 14, 2009 | Lands Phones
Nokia n96 switch off automatically
hello
1_ can you save your formation in other phone .
2_that code format your phone for Nokia only
3_ *#7780# if you know your security numbers use it. if you don’t know it use 12345
4_ other numbers *#7370# and the security n ......
and look if the problem is solve it
because after this . you have like a new mobile
Jan 28, 2009 | Nokia N96 Smartphone
Lands Phones Logo
760 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
