Scanning on Aficio 2232c from Windows Vista PC
I downloaded the recommended twain scanning software from Ricoh for the Afickio 2232c to my Windows Vista PC but it doesn't appear to have a built in user interface.
Any suggestions on how I can make use of this twain software to scan from my PC?
  • jureneck Nov 08, 2008
    Thaks very much...I wil give it a try.
  • 2,794 Answers
Goto www.ricoh-usa.com and download desktop binder.  Restart your computer.  Then use the setup options to link the copier to desktop binder.
Another way to do it is to skip the twain software altogether and use  a shared folder on your computer.  Your 2232 can link to that folder if smb is installed on your copier.
The way to find out is to press the user counter/tools button.  Select key op tools.  Go to address book management.  Select new program.  See if folders appears.  If it does press the button and select the browse button to see if it can find any computers on your network.
Your computer should have a shared folder with no restrictions to it.  Windows firewall should be turned off.  You copier must be connected via ethernet cables.  Firewall protection should only be on the router.
Posted on Nov 08, 2008
I want scan a page from ricoh aficio mp2500.how?
first install twain driver to ur pc and just open the microsoft world and go to the insert tab and then selct picture then 'from sacanner or camera'
or goto start-programs-microsoft office tools-documebt image scanning
Apr 23, 2010 | Ricoh Aficio 2015 Copier
Ricoh Aficio 2018D - previously used a scan router software to scan to file on Windows server. Now being told Windows server 2008 is not compatible. We are using scan to email but very cumbersome. Is there...
No, all the newer machines have imbedded scanning. The scanrouter software was an old product and only supported through 2k3 server. I would setup an old PC with the scanrouter and whatever platform you were running before and use it just for scanning. You can install it as a service so it will run on its own.
Feb 02, 2010 | Ricoh Aficio 2018D All-In-One Laser...
Need instructions to set-up email address
There is no email or scan to email function on the Ricoh Aficio 450. I believe it only has ISIS or TWAIN scanning as an option.
Oct 20, 2009 | Ricoh Aficio 450 Copier
How to Link Scanner from ricoh aficio 1232c
Download Twain Driver from ricoh site and you can use any softwere that suports twain scaning i use microsoft scan that comes with office 2003
Oct 18, 2009 | Ricoh Aficio 1232C Color Copier
Aficio 1013f scan? How to scan documents and than save it on my pc or send them via mail? I need help because my aficio have italian titles on it.
This is a loaded question. the 1013 can be either a network scanner (nic) or a twain scanner. this will depend on the type of hardware interface that is on your machine. Network scanning is the preferred method. I noticed that your model is a1013f which leads me to believe that it may not be equipped with the scan hardware. You need to look at your control panel and verify the scan button is there
Oct 12, 2009 | Ricoh Aficio 1013F Copier
I want to do scanning on Ricoh 2015
You can either install the Twain Scanning driver - printer driver disc or use Scan to email function.
Good luck and please rate me, thanks.
Jan 16, 2009 | Ricoh Aficio GX3050N Printer
Problem in scanner when scan
Try adding the scanner's IP address in the scnhosts file in the TWAIN folder. Format is similar to the windows hosts file. You'll see a commented out sample entry, just modify that to suit your needs.
This may or may not work for you; we had it working under this configuration but then it stopped for no apparent reason. also note that scanrouter isn't supported under vista. Only advice I've been given so far is to revert to sending scans via SMTP - not ideal!
Jul 02, 2008 | Ricoh Aficio 2018D All-In-One Laser...
325 people viewed this question
k24674
