Question about Dell Inspiron 2200 Notebook
Re-installing Windows '95
I reformatted the Dell Inspiron 2200 and reinstalled Windows 95 but it didn't load the perpherials like the cd/dvd and usb ports so I can't continue installing the software and upgrading???
  • 5 more comments
  • irish45792 Nov 08, 2008
    I reformatted the drive by starting it from a 3 1/2 disk with CD support which must have loaded a temp cd because after restarting there was no cd drive. How would I enable in the usb in the Bios? Also I did install Windows '95 with USB support feature. Windows 95 is installed but I have ? in all my Perpherial setting. This is a laptop I'm trying to fix up for my granddaughter. I have reformatted many hard drives without ever having this problem so I'm thoroughly confused!!!
    Thank you for your help!!!
    Thank You!!!
    I brought up the BIOS and the USB seems to be enabled. When I go to Device Manager the is an Exclimaination Point in The PCI IDE Controller and says there is a conflict which I don't know hoe to resolve. There are all ? marks in the Other Devices which are the PCI Card, etc...
    Thank you again!
    Right now my network configuration is empty.
    Yes, you have been very helpful and I have to buckle down and try all your suggestions! The trouble is I have nonw of the disk that came with the computer so is there a better way of wiping clear the hard drive and reloading the system? I want to installl the Windows XP but have to go through the Windows '95, 98 then the Windows XP.
    Again, thank you!!!
    Thank you for the step by step as that is so helpful! I have to do it another day as I have to get back to doing other things around the house! But again, I thank you so very, very much for your help!
    Have a good week-end!
  • irish45792 Nov 12, 2008
    Thank you for all your help with working this week, I haven't had the chance to work on the computer!!!
    Have a great evening!
    Mary Jo Borneman
  • 903 Answers
Check your bios settings for the usb ports they may be disabled in the bios. Enable them.
Your CD Drive should have been enabled if it allowed you to run windows 95.
Check your make and model numbers for the hard ware that you need to run and post back a comment and I will see what drivers I can find for you.
Posted on Nov 08, 2008
  • 3 more comments
  • Debs
    Debs Nov 08, 2008
    when you restart the laptop press either F2, F1 or delete depending on which your bios is set. Try F2 first. If it goes into bios then look for usb support. Make sure that it is enabled, then press f10 to save and exit and restart your computer. I will look for drivers for your laptop and get back to you.
  • Debs
    Debs Nov 08, 2008
    if you are connected to the internet on the laptop then go to this link
    http://driverscollection.com/?H=Inspiron...
    and then click on. or just click on the blue link below. It will check the laptop for drivers that are needed or outdated.
    Click here to Update All Your PCs Outdated Drivers
    hope this helps
  • Debs
    Debs Nov 08, 2008
    It sounds like you need to reinstall the chipset drivers for your laptop in order for everything to be recognised. If you have not go the chipset program then go to here
    http://support.dell.com/support/topics/g...
    and click on contact, and ask them for chipset drivers. There is a link on the page to downlaod chipset drivers but these are specifically for XP. If you let them know that you are running windows 95 they should be able to guide you on resolving your problem.
    In the mean time try right clicking on the question marks individually and click on properites and click on update driver to see if this helps. If not you definatley need the chipset drivers that are avaiable on the site above.
    I hope I have been of assistance to you.
  • Debs
    Debs Nov 08, 2008
    No you should be able to do this from a dos disk. (But you may still need the chipset drivers after)
    insert a blank floppy disk, go to 'My computer' right click on floppy and click on format in the options click on create msdos startup disk.
    Once you have done this, eject the floppy and go back into the bios settings and under boot option select floppy 1st cdrom 2nd and harddrive or ide 3rd.
    Then put the disk back into the floppy drive and reboot your machine again.
    This should load the necessary dos files onto your computer to enable you to fdisk and format the harddrive.
    Once the disk has loaded you will have an A:
    Type in fdisk
    This will bring up options to view, delete, create etc....
    You need to delete the existing partition and then press esc.
    Back to the options, now choose create partition and select the c: drive for the partition
    If asked if you want to use all of the space say yes,
    Then the partition will be created,
    If at any time you are asked if you want to enable large disk support say yes.
    Once the disk has been fdisked you will then need to format it,
    reboot again this time when the A: comes up type in format C:
    If asked are you sure you want to do this say yes, when it has finished it will say something about a label or press enter for none, press enter. Then load the cdrom for XP and type in D:setup
    if this does not bring the setup on the screen try just typing in Setup.
    This should start loading windows. If asked if you want to use CDrom support say yes then press enter to start the setup.
    When setup has finished it will restart your computer, make sure you take out the floppy disk before it boots.
    When asked again if you to boot from CD this time do not press anything because it will take you through the whole process again. Just let windows start on its own and then remove the cdrom.
    I hope this helps.
  • Debs
    Debs Nov 08, 2008
    if you can get CDROM to work you can just install XP over 95 it will format the pc for you.
Dell Inspiron 530s/531s desktop, Win. Xp home...Windows stops responding at the ''Loading Personal Settings'' cannot boot in safe mode.
try to boot in "Last good known configuration settings" by restarting your pc and then press F8 before windows appear and then select the boot option i mention above. if this not work since you said that it can't boot to safe mode, your other option is to repair the windows or else reformat it. when you repair the windows you must have windows xp home edition cd installer, you load it to your cd/dvd rom and then restart your pc and press F2 or DEL button before windows appear in order to go to setup bios settings. in bios settings, you choose boot order setup and setup first priority to cd/dvd and press F10 by saving the changes and then press any key when you see the prompt so that it can boot up to windows xp home cd installer and then follow screen instruction that you arrive to windows repair option.
Mar 27, 2010 | Dell Inspiron 530 Desktop Computer
If i restore my insp. 2200 to factory settings what exactly will be on it/
Your computer gonna be reformatted like it was when it was new. you get a new installed computer. all programs that you have installed gonna be gone. your computer gonna be as new.
if you run restore remember to save your data to a external media as usb disk or networkdevice because all information you have on your computer gonna get lost.
Also you need to reinstall all programs like office, firefox skype or other program you want installed.
The advantages with restore is that you computer becomes as it was when you bought it = faster then today.. remember to install all windows updates before you begins to install any other programs.
Hope I maid it clear for you what happends :) Good luck..
Nov 01, 2009 | Dell Inspiron 2200 Notebook
How do you reformat a computer
Assuming you don't mean the BIOS...
It suffices usually to reinstall Windows or whichever OS you intend to use. You let the installation program format the partition (watchout you loose all data which was on that partition)
Jul 28, 2009 | Dell Inspiron 1525 1526 24x CDRW/DVD Combo...
Dell Inspiron 2200 cant connect to internet
go to support.dell.com and download the modem driver to an external media (cd, thumb drive, etc.).
then right click 'my computer' and go to properties then device manager. you should be able to go to the modem and update the driver from a specific location and then point it to the external media you have downloaded the driver to.
Jul 11, 2009 | Dell Inspiron 2200 Notebook
Error code 1046: new hard drive, still problems
since the keyboard and dvd are on different controllers it may be the motherboard but then I have seen weird things when memory goes bad. I would download memtest on another computer and burn it to cd and run it from bootup and test the memory first. If not the memory then motherboard is a likely answer
Jun 29, 2009 | Dell Inspiron 2200 Notebook
Unable to reinstall xp on my inspiron 2200 laptop, cd drive hangs
it sounds as though you may have a bad sectors or clusters on the HDD the best solution is going to be to replace HDD
sorry i couldn't be of more assistance
May 05, 2009 | Dell Inspiron 2200 Notebook
Lost all drivers for my dell inspiron 2200. HELP PLEASE!!
I think you should use someone else's computer to download those software. That will solve your problem.
Apr 26, 2009 | Dell Inspiron 2200 Notebook
No bootable devices on my Dell Inspiron 1150
My Laptop Inspiron 2200 With Windows XP only boot with the C drive when I remove the CD-DVD-CD drive. Otherwise ,I am asked to go to Bios to reconfigure the booting order.
The CD-dvd can not be pick-up by Plug and Play .
As a result I can only use the Laptop without the CD-DVD
When I reconnect the DVD it will not boot.
I have inspected every single pin in the DVD and from the Motherboard I can not see any damages
What do you think is the problem?
Mar 09, 2009 | Dell Inspiron 2200 Notebook
Dell CD/DVD shows up in 'My Computer' but doesn't recognize CD's
the cd player could be bad it doesn't seem to be reading anything. or your windows needs reloading because you have other programs overwriting each other and windows.too much on the drive defrag it
Dec 27, 2008 | Dell Inspiron 2200 Notebook
Dell Inspiron 2200 Notebook Logo
56 people viewed this question
Alun Cox
