Question about Dell Inspiron 9100 Notebook
Inspiron 9100 - will not turn on after power surge
Our power surged about 5 times in a row the other day, after which my laptop will no longer turn on. The battery meter says its full, but even when plugged in using the AC adapter, nothing happens.
What do you recommend I try to fix it?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 49 Answers
Unfortunately your computer is most likely permanently damaged. A power surge can cause all types of damage to any computer but laptops are even more vulnerable. It most likely ruined your motherboard, but could have fried any number of components. You may get someone to look at it for you to be sure but in all probability it would be less expensive to replace than to repair. If you have important data you may seek out a data recovery expert to see if it can be salvaged from the hard drive.
Posted on Nov 08, 2008
  • 903 Answers
Try unplugging it from the mains adapter and take the battery out. Leave the battery out for a full two minutes then replace the battery and try turning on with battery only first. If this boots up okay then add your adapter.
I have a 2004 ford f150 5.4 triton when I take off from park it sometimes stalls and it sometimes has a surging no power, it also has the no power surging takeing off from a stop sign or light at times. ...
maybe a fuel starvation check fuel filter
also check your transmission oil level
and check cable connections to gearbox are on properly and not bad connection hope this helps
Apr 12, 2013 | 2004 Ford F150
Wont turn on
1.Plug the Inspiron's AC power cord into a power outlet and try to power on the laptop again. By far the most common cause of a laptop's not powering on is a dead battery.
2.Plug the AC adapter into a different outlet to check for a "dead" outlet. If you have the cable plugged into a surge protector, plug the cord into a different slot on the surge protector or "bypass" the surge protector by plugging the cable into an electrical outlet. If the Inspiron now powers on, replace the surge protector or have an electrician examine any "dead" outlets in the home.
3.Open the battery bay on the underside of the Inspiron by sliding the battery bay latch release lock upward and the battery bay latch release to the right. Once both latches are released, the battery bay should open.
4.Remove the battery.
5.Purchase a compatible replacement battery for laptop. Be aware that using an incompatible battery can cause damage to your computer. If you have any doubt as to compatibility, the best option is to purchase the replacement battery directly from your laptop's manufacturer.
6.Install the new battery by following the battery-removal procedure in reverse order. Once the new battery is installed, try again to power on the laptop. If there is still no power, seek professional repair advice.
I hope you find it very helpful.
Aug 25, 2011 | Gateway Computers & Internet
I have DELL DIMENSION 9100 SERIES, in the last couple of days i am unable to reboot it using the restore boot sequence, which i tried in vain with no results. What i am getting is it has gone into...
Good probability that the motherboard or other component were damaged in the surge
See if you can boot to Safe mode (F8 at boot) if not then see if you can boot to a WIndows CD
If the system is not completing POWER on testing then check this information
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
Jun 02, 2011 | Dell Dimension 9100 PC Desktop
What does usb device not recognized ?
The best you can do is,
Turn off the PC/Laptop
Disconnect the USB cable from Camera to pc/laptop
Disconnect the power cord connecting the pc/laptop and the wall jack or surge protector
Disconnect the power cord connecting the camera to wall jack or surge protector
wait for 5-10 mins
Connect the power cord of PC/laptop and turn on the pc/laptop and login to your PC
Connect the power cord of Camera to wall jack or surge protector
Connect the usb cable or camera to PC/laptop
It should get recognised and work fine.
Regards,
Shawn
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 20, 2011 | HP Photosmart R847 Digital Camera
Lighting struck house causeing a power surge, now I get nothing out of my computer , no power or lights, what could be wrong with it?
oh oh ... your mainboard is damaged... possible your RAM and hard disk drive as well
if you intend to buy another computer , buy a UPS to go with it .. thsi will never happen again if you protect it against power outs and surges
Nov 01, 2010 | Dell Inspiron 1525 Laptop
Dell Inspiron 1000 won't turn on. It is always
Well if it is always plugged to the wall then the laptop's power jack is the common problem there. You can have a Computer Technician check it and diagnose it for you. Be careful how much you pay, if that is the problem (i'm pretty sure it has to be) you can shop for the part online (ebay is a good place to find them for around ten bucks) and hand it to the computer guy. Otherwise you may be charged a fortune to get it fixed. Next time, use a power surge between the power adapter and the wall's power outlet.
Here's is a brief explanation of what happens with the power jack. Inside of it there are two or three pieces of metal that look like thick wires and what they do is transfer the current to the laptop. Eventually they wear out and break (common cause is having your laptop plugged to the wall continously exposing it to all sorts of power surges). Hope it helps, good luck.
Jan 03, 2010 | Dell Inspiron 1000 Notebook
Ihave a sony KP53S75 TV there was apower surge and now there is no picture. The red light blinks 4 times can anyone tell me about this?
Hi, if this TV was hit by the surge and it was protected by a surge protector, please follow this reset procedure.
The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the problem is still there and the light is still blinking 4 times, this means that the surge has destroyed the Vertical deflection component. in this case, it will have to be replaced.
please rate and have a great day.
Mar 25, 2009 | Sony KP-53S75 53" Rear Projection...
My daughter was on my dell inspiron 1501 laptop, all fine, i asked to use it for 5 minutes, i unplugged it from the adapter and used it in another room, i returned it still on my daughter plugged it back...
The inspiron has known issues with overheating and heatsink fan issues.. Contact dell tech support if under warranty or just buy a new motherboard cause yours is probably dead now.
Jan 18, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 9100 Notebook Logo
87 people viewed this question
Alun Cox
