Question about Acer Aspire 1414 Notebook
Loss portion of files only.
Upon add/removing programs from the C drive( programs not related to lost files.), a portion of files were either deleted or misplaced.
All file were in same Folder on C drive ad this consisted of Microsoft Picture It , diagrams, Microsoft Word documents and Easyshare JPEG and PNG files.
All files were saved under indivisal folders condenced into one major folder.
Upon opening up the main folder and then each indivual folder, all files listed were no longer present. Upon doing a search via file name, all these files were listed " as moved and unable to locate "
Note: The major folder was not deleted or moved however all files within these folders were moved or somthing and I still cannot locate or recover them.
All programs these files require , Microsoft Picture It , Microsoft Word documents and Easyshare . have not been effected. only this grouped files are effected
What can I do to rescue data deleted by pressing "Shift+ Delete" on Windows 7?
Using Shift+Delete to remove files/folders bypasses the recycle bin which is your normal means of recovering accidentally deleted files. You can go to download.com and search for file recovery programs. Some are available that will search your hard drive and can maybe recover what you lost. It is important to do so as quickly as possible because once files are permanently deleted on the hard drive, the sectors that they occupied are no longer protected and can be overwritten by any program or file.
Dec 25, 2014 | Computers & Internet
Tip
How to Recover Files and Photos from SanDisk USB Drive?
<span><span><img src="maggiena_6.jpg" /><br />SanDisk USB flash drive is widely used for its excellent quality. It gives customers all the power and performance you need to transfer, store and share pictures, tunes and data with easy. Some uses of SanDisk USB flash drive can be concluded in the following aspects: personal data transport, secure storage of data, application and software files, application carriers, computer forensics and law enforcement, backup, etc. Compared with other storage devices like floppy disk, USB carries various advantages for Small size, lightweight, rewriteable and removable. Therefore, it becomes a necessary among business man and students.<br /><br /></span></span><span><span> <p>However, Data loss often happens on USB flash drive as well. Some of them are caused by the products of USB, others due to the false operation of it. Here are some typical reasons that cause data loss:<br /> <p><img src="li.gif" />1. Windows system asks you to format USB drive and you accidently press "Format";<br /><img src="li.gif" />2. Mistakenly or carelessly delete files from USB flash drive and cannot find them in the recycle bin or trash bin;<br /><img src="li.gif" />3. The drive was attacked by virus and files get hidden or deleted;<br /><img src="li.gif" />4. Not properly remove the USB drive from computer when the data was still transferring;<br /><img src="li.gif" />5. The file system of USB drive was displayed as raw;<br /><img src="li.gif" />7. Hardware malfunction<br /> <p>It is really frustrated if you find crucial documents, previous pictures or applications lost. Are there any methods to get them back?</b><br />Data loss caused by hardware malfunction will be very hard to restore. You have to ask the help of professional technician. For other cases, you can rely on some<span> </span><a href="http://www.card-data-recovery.com">USB flash drive data recovery</b></a><span> </span>program to help you. Once loss data, you should stop using USB any more in case the data was overwritten. There we recommend you Card Data Recovery to help you<span> </span><a href="http://www.card-data-recovery.com/">rescue USB flash drive data</a>. <br />Step1.</b><span> </span>Download Card Data Recovery, save it to your computer's desktop and double click on it to open the program;<br />Step2.</b><span> </span>Insert SanDisk USB flash drive into USB port of your PC;<br />Step3.</b><span> </span>Run Card Data Recovery and select SanDisk device from the drive selection drop-down menu. Click "scan" to scan the USB drive and you can find deleted or lost items will be displayed in the task list;<br />Step4.</b><span> </span>Select the files you wish to recover from USB drive and click "Recovery" button. Card Data Recovery allows you to preview files before recovery.<br /> <p>Card Data Recovery also supports recovering data from<span> </span>SanDisk memory card</b>,<span> </span>SD card</b>,<span> </span>mobile SDHC card</b>, etc.<br /></span></span><br />
on Jun 08, 2011 | Computers & Internet
Instructions delete
This describes what Deal4me is:
Deal4me adware how to remove it
First, you can uninstall it through Start > Control Panel > Add/Remove Programs (Renamed Programs and Features in Windows 7)
You will also want to download, install, and run an Anti-Malware utility, such as the free version of Malwarebytes from:
Malwarebytes Anti Malware Pro
Aug 31, 2014 | Computers & Internet
Charging
Accidently deleted photos, music or other crucial stuff on your iPhone or iPad? Improper operation? Broke or damaged your camera and now the data's gone? Or your USB device failed work? Please don't be worry now. A photo recovery software for Windows OS-based computer users that recovers deleted or lost photos, images, songs, movies, and other multimedia files.
Memory Card Recovery Provides Zero loss of Picture/Photo/Video/Audio Recovery. If you want to read more about this program , please click in to learn more and try for free download: http://datas-recovery.com
Related Articles: How to Recover Lost Data from USB Flash Drive/ SD card/ Memory card
Jul 29, 2013 | Motorola Mobility E815
Recover Lost Windows Hard Drive Data
Hard drive data loss is a major problem for all kind of users, if you want to resolve this type of issue, so suggest you get Recover Data Hard Drive Recovery Software that can easily remove or get rid of your all data loss issues as fast as possible.
Do hope it could help you:- http://www.recoverdatatools.com/hard-drive-recovery.html
Jul 04, 2013 | Computers & Internet
I accidentally deleted my computers fonts.... how can I recover it?
check your recycle bin the files might still be in there you can restore them if they are or you could try using one of these file eraser undelete programs
http://majorgeeks.com/Avira_UnErase_d5284.html
What is gone is gone? Far from it! Avira UnErase recovers data that have been deleted from the hard drive - either accidentally or as a result of a virus infection, an uninstaller or defective software. The danger of important data being lost forever is averted with Avira UnErase.
The private, non-commercial use of Avira UnErase Personal is free
http://majorgeeks.com/Free_File_Recovery_d6792.html
Free File Recovery is a small and easy to use application that will help you to restore files that have been accidentally deleted from your computer. This includes files emptied from the Recycle bin as well as images and other files that have been deleted by user error from digital camera memory cards or MP3 players. It will even bring back files that have been deleted from your iPod, or by bugs, crashes and viruses!
http://majorgeeks.com/FreeUndelete_d4407.html
FreeUndelete restores deleted files, including those removed from Windows Recycle Bin. In case of accidental removal of files on a NTFS (1.0 and 2.0) (default for Windows Vista , XP, 2000 and NT), FAT32, FAT16 or FAT12 file systems this is the utility to help.
Supported file systems:
NTFS 1.0, NTFS 2.0, FAT12, FAT16 and FAT32
The recovered files are saved into a new user-selected location to prevent overwriting the deleted files on the original media.
hope it helps
Jul 01, 2011 | IBM Lenovo ThinkStation S20 Workstation...
My itunes just stopped working one day and now i can not reinstall it on my computer
Learn how to completely uninstall iTunes, QuickTime, and other essential software components from your Windows XP PC.
How ToFor Windows Vista or Windows 7, see this article.
Expand All Sections | Collapse All Sections
In some rare instances, it may be necessary to remove all traces of iTunes, QuickTime, and related software components from your computer before reinstalling iTunes.
Use the Control Panel to uninstall iTunes and related software components in the following order:
  1. iTunes
  2. QuickTime
  3. Apple Software Update
  4. Apple Mobile Device Support
  5. Bonjour
  6. Apple Application Support (iTunes 9 or later)
Important: You may see various alert messages if you uninstall these applications in a different order or only uninstall certain components.
For detailed steps on removing and reinstalling iTunes and related components on Windows XP, refer to the following steps:
Removing iTunes Note: iTunes Store purchases or songs imported from CDs are saved in your My Music folder by default and are not deleted by removing iTunes.
  1. Quit iTunes.
  2. From the Start menu, choose Control Panel.
  3. In Control Panel, open Add or Remove Programs.
  4. Select iTunes from the list of currently installed programs, then click Remove.
  5. When asked if you would like to remove iTunes, select Yes.
  6. After the uninstallation is complete, do not restart your computer if you are prompted to.
  7. If other program entries were listed for iTunes in Add or Remove Programs, remove those as well.
  8. In Add or Remove Programs, remove any iPod Updater applications that are listed in the same fashion as iTunes was removed.
Removing QuickTime
  1. Quit QuickTime Player.
  4. Select QuickTime from the list of currently installed programs, then click Uninstall.
  5. When asked if you would like to remove QuickTime, click Yes.
  7. If other program entries were listed for QuickTime in Add or Remove Programs, remove those as well.
Removing Apple Software Update
  1. Quit Apple Software Update.
  4. Select Apple Software Update from the list of currently installed programs, then click Uninstall.
  5. When asked if you would like to remove Apple Software Update, click Yes.
  7. If other program entries were listed for Apple Software Update in Add or Remove Programs, remove those as well.
Removing Apple Mobile Device Support
  1. From the Start menu, choose Control Panel.
  2. In Control Panel, open Add or Remove Programs.
  3. Select Apple Mobile Device Support from the list of currently installed programs, then click Uninstall.
  4. When asked if you would like to remove Apple Mobile Device Support, click Yes.
  5. After the uninstallation is complete, do not restart your computer if you are prompted to.
Notes: Do not manually delete the Mobile Device Support folder located at C:Program FilesCommon FilesApple. Use Add or Remove Programs as described in the steps above.
Removing Bonjour
  2. In Control Panel click "Add or Remove Programs."
  3. Select Bonjour from the list of currently installed programs then click Uninstall.
  4. When asked if you would like to remove Bonjour click Yes.
  5. After the uninstallation is complete do not restart your computer if you are prompted to.
Removing Apple Application Support (iTunes 9 or later)
  3. Select Apple Application Support from the list of currently installed programs, then click Uninstall.
  4. When asked if you would like to remove Apple Application Support, click Yes.
Verify iTunes and related components are completely uninstalled
  1. Restart your computer.
  2. After the computer restarts, open Local Disk (C:) located in Computer or whichever hard disk your programs are installed on.
  3. Open the Program Files folder.
  4. Right-click the iTunes folder, choose Delete, and choose Yes when asked to confirm the deletion. Note: This folder may have already been deleted if iTunes was successfully removed.
  5. Right-click the iPod folder, choose Delete, and choose Yes when asked to confirm the deletion. Click Continue if Windows needs confirmation or permission to continue.
  6. Right-click the QuickTime folder (if it exists), choose Delete, and choose Yes when asked to confirm the deletion. Click Continue if Windows needs confirmation or permission to continue.
  7. Right-click the Bonjour folder (if it exists), choose Delete, and choose Yes when asked to confirm the deletion. Click Continue if Windows needs confirmation or permission to continue.
  8. Open the Common Files folder.
  9. Right-click the Apple folder (if it exists), choose Delete, and choose Yes when asked to confirm the deletion. Click Continue if Windows needs confirmation or permission to continue.
  10. Open Local Disk (C:) located in Computer or whichever hard disk your operating system is installed on.
  11. Open the Windows folder.
  12. Open the System32 folder.
  13. Right-click the QuickTime file (if it exists), choose Delete, and choose Yes when asked to confirm the deletion. Click Continue if Windows needs confirmation or permission to continue.
  14. Right-click the QuickTimeVR file (if it exists), choose Delete, and choose Yes when asked to confirm the deletion. Click Continue if Windows needs confirmation or permission to continue.
  15. Right-click the Recycle Bin and choose Empty Recycle Bin
Reinstalling iTunes and related components After verifying that iTunes is completely uninstalled, you should download and install the latest version of iTunes.
Additional Information iPodService.exe Alert Follow these steps if the message, "Cannot delete iPodService.exe: It is being used by another person or program" appears when you try to delete the iPod folder.
  1. Make sure that iTunes and the iPod Updater utility are not open.
  2. Press and hold Control-Alt-Delete. Select Start Task Manager.
  3. Click the Processes tab.
  4. Locate "iPodService.exe" in the list.
  5. Click "iPodService.exe" and choose End Process.
  6. Quit the Task Manager.
Aug 04, 2010 | Apple iTunes
Internal error 2718 roxio media manager pops up upon startup. I have deleted everything in the registry relating to it. i have used reg cure, system mechanic. I cant open system restore, user accounts or...
Make sure you are logged in to an account with administrator privileges.
Click Start, click Run, type "msconfig", click OK. In System Configuration, click the Startup tab. Uncheck anything relating to Roxio Media Manager. Click OK and reboot.
Be very careful when dealing with the registry. Most registry cleaners do more harm than good if not used carefully. The "Delete everything I find" attitude often leads to a slower computer than when you started.
May 13, 2010 | Microsoft Windows XP Professional for PC
Hard drive is full need more space
From Control Panel go to Add/Remove Programs
Remove programs that no longer useful to you and delete documents, pictures any file that you don't need anymore.
if you don't have nothing to do with removing programs and deleting files, you have to upgrade or add a secondary hard drive, or a external drive will be a helpful to you, move all your files to your external drive this will also counted as your backup files.
Jan 05, 2010 | ASUS (90N804SH021) Hard Drive
Trying to remove norton Ghost
yes it is available download the latest version of norton removal........
if the problem is same then download the perfect uninstaller ......it uninstall that software perfectly........
Dec 30, 2008 | Symantec Norton Ghost 14.0: Windows
Acer Aspire 1414 Notebook Logo
60 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
